| Turn Signal Switch, '95 Riviera | |
tloukaitis Amateur
Name : Terry Joined : 2016-03-01 Post Count : 27 Merit : 0
| Subject: Turn Signal Switch, '95 Riviera Sat Apr 02, 2016 12:57 am | |
| Any ideas on how to repair/replace Turn Signal Switch without spending $200-$400 for a new one? | |
| Subject: Re: Turn Signal Switch, '95 Riviera Thu Aug 25, 2016 12:06 pm | |
| get a good one from a junkyard, although it may take some hunting to find it. Should be $100 or less, maybe much less depending on who you're dealing with. | |
| Subject: Re: Turn Signal Switch, '95 Riviera Tue Aug 30, 2016 11:21 pm | |
| I lucked out and got an NOS one on eBay for my 98 a few years ago, for $50. I think dealer still had them for nearly $400, if not more. Crazy price... but it's a complicated piece. | |
| Subject: Re: Turn Signal Switch, '95 Riviera Fri Sep 02, 2016 2:15 pm | |
| I just replaced mine with one from Ed Morad. I was surprised - it looks identical but feels very different (and works *perfectly* - the old one worked but did not do the tilt-to-pass function at all, this one does). | |
dude834 Rookie
Name : Russ Location : New York Joined : 2016-08-13 Post Count : 17 Merit : -1
| Subject: Question Wed Sep 21, 2016 3:27 pm | |
| Albertj......What is the "tilt to pass function" you mentioned in the post...thanx | |
jbird Fanatic
Name : Jeff Location : Cleveland area Joined : 2013-11-11 Post Count : 368 Merit : 7
| Subject: Re: Turn Signal Switch, '95 Riviera Wed Sep 21, 2016 3:44 pm | |
| Albert, do you know what year that it is from? My 96 will not tilt either, it is "click on" or "click off". Surprised your 98 wasn't that way. It has always annoyed me. Easy job?..
Jbird | |
| Subject: Re: Turn Signal Switch, '95 Riviera Thu Sep 22, 2016 4:56 pm | |
| - dude834 wrote:
- Albertj......What is the "tilt to pass function" you mentioned in the post...thanx
This is where the turn signal lever can be moved just part way in either direction, not all the way to locked left or right. Then you release and your light will blink typically 3 times, enough for a lane change. Not enough for normal turns. My 98 had this, odd that Albert's did not. | |
| Subject: Re: Turn Signal Switch, '95 Riviera | |
