| Stuck Accelerator and Other New Problems | |
myersty Special
Name : Tyler Joined : 2014-06-28 Post Count : 8 Merit : 0
| Subject: Stuck Accelerator and Other New Problems Sat Jun 18, 2016 12:55 pm | |
| The other day after gassing the Riviera, the accelerator stuck at about 4000 RPM. I had to use the emergency breaks and eventually just shift the car to park at about 5 miles per hour. Shortly after restarting the car, the accelerator returned to normal and I was able to drive home. When starting the car now, the engine idles but when pressing the RPM reaches roughly 3000 RPM a loud wawa noise is made. The muffler vibrates excessively while the noise is made. Any thoughts or suggestions? | |
1997riv Enthusiast
Name : Joined : 2014-11-23 Post Count : 131 Merit : 0
| Subject: Re: Stuck Accelerator and Other New Problems Sat Jun 18, 2016 9:54 pm | |
| Why didn't you just put it into neutral, shut if off, and use the normal brakes to stop it? The throttle on these cars is cable and not drive by wire, so there would have to be something physically affecting the cable or throttle body. The rev limiter in my Riviera only lets you rev to around 3000rpm (if I remember correctly) in park and then revs up and down, which sounds like what you are describing. In neutral it will rev very high before it rev limits. And yes, even the stock exhaust sounds pretty sick nasty when bouncing off the rev limiter . | |
| Subject: Re: Stuck Accelerator and Other New Problems Mon Jun 20, 2016 9:28 am | |
| The only way the accelerator cable could get bound up or stuck is if it's physically corroded on the inside. I'd disconnect the throttle cable from the throttle body and see if it moves freely. If it doesn't, you could try and spray some penetrating lube into the tube until it frees up. | |
| Subject: Re: Stuck Accelerator and Other New Problems Mon Jun 20, 2016 12:09 pm | |
| - myersty wrote:
- The other day after gassing the Riviera, the accelerator stuck at about 4000 RPM. I had to use the emergency breaks and eventually just shift the car to park at about 5 miles per hour. Shortly after restarting the car, the accelerator returned to normal and I was able to drive home. When starting the car now, the engine idles but when pressing the RPM reaches roughly 3000 RPM a loud wawa noise is made. The muffler vibrates excessively while the noise is made. Any thoughts or suggestions?
Starting from the throttle body check the throttle and cruise control cables. Also consider disconnecting the cruise control servo cable from the drum on the throttle body, and pulling the fuse until you can test that system. You will need the factory service manual for the cruise stuff, checking the throttle cable is mostly old-school troubleshooting. Also eliminate the possibility that the gas pedal got caught in one of your floor mats. | |
makemann1 Member
Name : Max Location : Northville, MI Joined : 2012-11-16 Post Count : 66 Merit : 5
| Subject: Re: Stuck Accelerator and Other New Problems Sat Oct 29, 2016 11:27 pm | |
| I mashed on the accelerator to pass the texting driver in front of me and the throttle stuck wide open. Had to put it in neutral, braked to slow down and turned key off. It was dark in the morning, so I couldn't see it clearly, but it looked like the cable was hung up. Is there anything it could possibly be hung up on? Or do you think it just needs some lubrication? | |
| Subject: Re: Stuck Accelerator and Other New Problems Mon Oct 31, 2016 11:35 am | |
| - makemann1 wrote:
- I mashed on the accelerator to pass the texting driver in front of me and the throttle stuck wide open. Had to put it in neutral, braked to slow down and turned key off. It was dark in the morning, so I couldn't see it clearly, but it looked like the cable was hung up. Is there anything it could possibly be hung up on? Or do you think it just needs some lubrication?
Either, neither or both -- fix it ASAP. | |
makemann1 Member
| Subject: Re: Stuck Accelerator and Other New Problems Thu Dec 22, 2016 1:17 pm | |
| - albertj wrote:
Either, neither or both -- fix it ASAP. For record, I took it in and had the problem fixed. From the service invoice: "TRANS SHIFT CABLE STUCK IN. REROUTED TRANS SHIFT CABLE." | |
| Subject: Re: Stuck Accelerator and Other New Problems | |
