Subject: Odd speakers in old cars. Sun Sep 29, 2019 10:42 pm
Not a Riv question, but the 3rd gen Charger forum is even less active than Riviera Performance. My problem is that the rear speaker cutouts are sized for a normal 6X9 on the passenger side, and 5X8 on the driver's side. To make things worse, the screw pattern on the 5X8 is apparently different than what is currently made. But I can't find modern 5X8 speakers anyway, only 5X7 or 5.25x?. I'm not seeing an adapter to 5X8 either. Need suggestions for buying speakers individually, perhaps refurbished, and finding the weird 5X8 size and mounting it. Or perhaps mounting a 5X7 instead. The good news is that I'm making a custom package tray from masonite, and I'd like a speaker that sits on top so perhaps I can mount a 5X7 to the masonite instead of the metal shelf.
Any thoughts?
DeepFrozen Fanatic
Name : Dmitry Joined : 2016-08-28Post Count : 252 Merit : 11
Subject: Re: Odd speakers in old cars. Mon Sep 30, 2019 4:20 am
My thoughts - just use that masonite adapter and mount anything you like (that will fit) - 5x7, 5 1/4, etc. And yes, I think you can mount a speaker to your adapter as long as adapter is firmly bolted to the metal. Threaded rivets, what a wonderful thing. I fell in love with them recently. ... I'm in the process of fitting 6.5" Morel Tempo Ultra 602 in Riviera doors and I hate that moron who decided that 5 1/4 is enough...
Subject: Re: Odd speakers in old cars. Mon Sep 30, 2019 4:22 pm
5 1/4 in the doors is better than one 3x6(?) in the dash. Don't know how I'm going to handle that yet.
Is Masonite strong enough to bolt too? It's only 1/8 thick. Soaking the edge of the screw hole with super glue would toughen it up some.
DeepFrozen Fanatic
Subject: Re: Odd speakers in old cars. Tue Oct 01, 2019 2:25 am
3x6, LoL. I assume you want to maintain the original appearance of the interior? Are there ANY speakers in the doors?
Oh, 1/8 is not good... When I feel that there is not much thickness to bolt into, I use plywood behind the metal to create a "plywood-metal-my stuff" sandwich.
Subject: Re: Odd speakers in old cars. Tue Oct 01, 2019 9:43 am
Masonite's not bad but you can have edge fracture and material failure around holes for stuff such as mounting speakers. Consider using flat washers on both sides of the holes, securing the speakers with machine screws, to be a permanent fix/preventive for that little problem.
Subject: Re: Odd speakers in old cars. Tue Oct 01, 2019 5:01 pm
Nope, no door speakers. The car came with an enormous AM radio and the one highly elliptical speaker in the center of the dash. I wonder if I've still got it - it may be more like 3X8.
I'll use the center dash speaker location no matter what I have to put in it. I could use an adapter and two small speakers, or have the original rebuilt.
Yeah, that sounds like a good idea.
Subject: Re: Odd speakers in old cars. Wed Oct 09, 2019 9:07 pm
A fun look at what I've got to work with -
The extra holes around the driver's side 5X8 match the holes for the 6X9 on the passenger side. Does it sound reasonable to make a spacer to clear the indent for the 5X8 and mount a 6X9 (hanging from the bottom of the package shelf) on the driver's side?
The front speaker can be rebuilt, but I wonder how good the sound quality will be.
Subject: Re: Odd speakers in old cars. Wed Oct 09, 2019 9:44 pm
Subject: Re: Odd speakers in old cars. Thu Oct 10, 2019 1:23 am
Wait a minute... This car has 3 speakers (two of them in the back), and they all are different?
But it still has round wheels, right?
Subject: Re: Odd speakers in old cars. Thu Oct 10, 2019 1:37 am
Thanks! Much better than having the original rebuilt for $85, if the price hasn't gone up by now. Might have to trim some of the frame off to mount it? I'll show the Charger guys.
Have you seen 5 X 8 anywhere?
How do you feel about Boss as a brand?
Subject: Re: Odd speakers in old cars. Thu Oct 10, 2019 1:51 am
The car has the one rotted out 4X10 dash speaker and a gigantic AM head unit with a teeny little face. It does have three holes for speakers, all of which are in fact a different size.
The rims I got it with are aftermarket 14" slotted mags, so it's possible the stock rims were not round.
Perhaps you'll get a kick out of this modern replacement headunit - Link
$661 dollars but it looks like the original when installed.
There's got to be a better way.
Subject: Re: Odd speakers in old cars. Thu Oct 10, 2019 9:45 am
At some point you are going to figure out that you just need to do a web search for the odd-size speakers. They are not hard to get, but I'll give you a couple hints.
1) depending on the installation you may need to trim some of those mounting tabs off the speaker frames. Sometimes the maker scores them so they snap off. You can always take them off with a Dremel having a cutoff wheel.
2) The nominal size of the speaker is what you need to source. From maker to maker there's a bit of variation in what a 3" round speaker actually measures. In other words, just get close.
Also see http://www.turnswitch.com/speakers.htm
Subject: Re: Odd speakers in old cars. Thu Oct 10, 2019 9:39 pm
I've been searching for 5X8's, what I get are 5X7's. A guy on the Charger forum came up with these 5X8's the only ones either of us have seen. I haven't been looking for 4X10's yet myself, but the other guy said he couldn't find them.
The SM Electro-tech site is interesting, and it'd be the way to go if I wanted to keep the stock head unit. I'm told it puts out a staggering 3 watts of power though, so even if it works, it's nothing you'd want except as a curiosity. At $85/hour I doubt SM could rebuild it for less than the price of the Year One unit. I'm thinking that controlling the speakers with a laptop via bluetooth might be the way to go - but I don't know anything about it yet. That means I need to find modern speakers in these odd sizes. Lots to think about/learn about.
Subject: Re: Odd speakers in old cars. Fri Oct 11, 2019 3:13 am
In general - you can make your own mounting plates from Masonite and mount quality smaller speakers in the openings.
Subject: Re: Odd speakers in old cars. Thu Oct 17, 2019 2:19 am
I may have to try duplicating this kickpanel install. It looks like the kickpanels are custom molded. I have no idea how hard that is. I'm seeing a consensus that 4X10 is an inherently bad sounding speaker size. I'm not sure the stock mount has enough depth for a good speaker, but at any rate I'd have to take my whole dash out to install one, so it'd better be good. The kickpanel install sounds like a better solution if molding a new one is doable.
Subject: Re: Odd speakers in old cars. Thu Oct 17, 2019 5:55 pm
Back in the day, kickpanel installs often were speakers in enclosures - you would split the enclosure, mount the base on the click panel and then mount the speaker on the base. Worked fine. A trick thing you could do if you could get it right was to port the speaker thru the base into the fender cavity if that cavity was enclosed.
If you search "kick panel speakers for 60s cars" you will find a large number of choices (and not just for 60s cars).
I had this exact speaker in a 1969 Rambler Rebel I had while in high school/college: https://www.ebay.com/i/332833880789
Modern version? See https://www.ebay.com/itm/NEW-2-Pioneer-Car-Stereo-3way-Box-Speaker-Pair-replacement-surface-Mount-Jeep/202457186587.
Subject: Re: Odd speakers in old cars. Thu Oct 17, 2019 9:29 pm
This link is broken.
Subject: Re: Odd speakers in old cars. Thu Oct 17, 2019 11:23 pm
It probably sold.
Search there for "surface mount car stereo speakers" or "Vintage surface mount car speakers" or some such. You'll find several like this
and some vintage ones. Alternatively try "surface mount boat stereo speakers" you will get additional results that may work.
Thinking about it I'd try hard-wiring in some auxiliary rechargeable smartphone speakers. Some of those little things especially the Altec Lansings sound pretty good and have decent bass if you mount them to an appropriate surface. I'd hardwire both the power and the audio. The non-bluetooth ones are cheaper, start there.
DeepFrozen Fanatic
Subject: Re: Odd speakers in old cars. Mon Oct 21, 2019 2:04 am
It's not broken, just remove that dot at the end of the link, which isn't part of the link. https://www.ebay.com/itm/NEW-2-Pioneer-Car-Stereo-3way-Box-Speaker-Pair-replacement-surface-Mount-Jeep/202457186587
Subject: Re: Odd speakers in old cars. Mon Oct 21, 2019 8:48 pm
That's not bad looking. I suppose they screw into the kick panels? I'd feel a little bad about doing that. I looked into making new fiberglass kickpanels, and it's not too difficult although I'd need a couple new wood working tools.
I'm debating whether I should bother with this now or do a "get it running" pass than do a "make it perfect" pass later. The dash cap is causing other problems, I was hoping to run the wires from a dash-mounted tach down through the center speaker location but that may not be possible if I can't get the speaker grill off. Unless I can individually run the wires through the grill holes. Not a great look, but better than having them come down the front of the dash? I don't know if it's even possible, but I'll find out. Mostly I'm thinking, if I can't make it perfect now I can at least get it running sooner.
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
Subject: Re: Odd speakers in old cars. Tue Oct 22, 2019 2:24 am
JR, Is this a pic of your Charger's interior or someone else's.??? Interior looks sweet. On second thought I guess this isn't yours if your looking at the kick panel installation on this car. I personally can't see the kick panel speaker install at all in this pic.
Regarding the speaker mounts your lucky that what you have hasn't been hacked up by a previous owner to fit different size speakers and a different radio in the dash. Back in the day I used to see many a mangled dash for install of a radio that didn't fit along with the speaker holes cut open to fit 6x9's or some other size. Those guys had no clue what the car would be worth in the future though and I don't think they cared.
Subject: Re: Odd speakers in old cars. Wed Oct 23, 2019 5:14 am
The car was Kenny Wayne Shepherd's "Black Sheep," as seen in the "Fast and Furious" parody "Superfast-"
It was stolen and is probably abandoned on the side of the road in Qatar now, next to a Koenigsegg and a Lamborghini.
Look through the steering wheel, you can see the kickpanel speaker.
Subject: Re: Odd speakers in old cars. Wed Oct 23, 2019 9:13 pm
Damn Kenny's Black Sheep is done real nice. A nice Resto-Mod. Wonder who built the car for him. I guess I can google that and find out.
What did we do before Google.??? Oh, I remember. Lay on the couch licking our nuts and trying not to fall off the couch.!!!!!!!!!! Never mind, that was my Labrador.
Thanks for posting the video. Funny shit there.
And now I see where the speaker is hiding on the passenger kick panel. I think you'd do well making a fiberglass copy and keeping the stock ones in dry storage. Preferably inside the house with all the humidity during the summer.
Subject: Re: Odd speakers in old cars. Wed Oct 23, 2019 11:59 pm
Here are a couple articles in case you haven't found them yet - Link, Link
I love the interior, not so big on the exterior changes. The oversized rallye wheels don't work for me. They're supposed to be an "updated" version of the classic rallye style wheel Mopar used, but IMO they don't look right scaled up to whatever they are.
Shaving the side marker lights is kinda meh. In 72 Chrysler got rid of all the model specific side marker lights and went to one generic light for the entire model range. I can understand wanting to lose it, but I'd graft in the styled light from '71.
I'm not a huge fan of the SE C pillar, but not everyone likes the standard 71-72 c pillar. Chrysler tried a few different versions and never really got it right.
On the plus side, the third gen gives you nice things like stock head rests and shoulder belts.
Subject: Re: Odd speakers in old cars. Thu Oct 24, 2019 6:16 am
I looked into making fiberglass kick panels. It's doable but I'll have to pick up more wood working tools. Sounds like it's not the best winter job too.
