| Charcoal canister box. | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: Charcoal canister box. Fri May 08, 2020 6:05 pm | |
| - carguy8888 wrote:
- I would not know if I fixed it. just willing to throw away the twenty on the cap. Not too sound stupid, I did not know this panel existed. I guess I need to look on one of the sides of the trunk?
If you lift up the trunk lining, you'll see the panel. It is secured with about 7 screws. You'll need to pry it up. It has a sticky rubber seal that is reusable, so don't be shy about prying on it. The fuel pump is held onto the tank with a locking ring that engages 4 tabs that are an integral part of the tank. They rot and the tank can leak there. You really should take a look at it just to assess the condition. See the thread below. https://rivperformance.editboard.com/t10875-rusty-fuel-tank-tab-repair?highlight=fuel+pump+rusty+tankThis is what it can look like, https://2img.net/h/i1076.photobucket.com/albums/w441/zeetype/DSC06704.jpg _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07 Post Count : 805 Merit : 8
| Subject: Re: Charcoal canister box. Fri May 08, 2020 6:08 pm | |
| I will do that and report back, ty both. | |
carguy8888 Junkie
| Subject: Re: Charcoal canister box. Sat May 23, 2020 6:44 pm | |
| Thank you both for taking the time to enlighten me. I pulled up the carpet and the access panel. My mechanic said the ring is fine. I had no idea GM put the fuel pump like this. | |
| Subject: Re: Charcoal canister box. Sat May 23, 2020 6:47 pm | |
| You are fortunate. Most of them are very corroded. I would have sprayed some fluidfilm in there to keep it that way.
https://www.fluid-film.com/ _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
carguy8888 Junkie
| Subject: Re: Charcoal canister box. Sat May 23, 2020 8:42 pm | |
| Probably would have been a good idea or at least WD-40. | |
| Subject: Re: Charcoal canister box. Sun May 24, 2020 10:01 pm | |
| - carguy8888 wrote:
- Thank you both for taking the time to enlighten me. I pulled up the carpet and the access panel. My mechanic said the ring is fine. I had no idea GM put the fuel pump like this.
You should see how bad it is on the same vintage Camaro . . . IIRC you gotta drop the entire rear suspension. A lot of people cut an access panel in the floor instead. | |
carguy8888 Junkie
| Subject: Re: Charcoal canister box. Mon May 25, 2020 8:51 am | |
| I know about the trapdoor, I have a 99 trans am convertible. | |
| Subject: Re: Charcoal canister box. Mon May 25, 2020 9:51 am | |
carguy8888 Junkie
| Subject: Re: Charcoal canister box. Mon May 25, 2020 11:08 am | |
| Runs and rides great. 120k stalled auto 3:42 gears, tuned and upgraded suspension. IMG_20191025_170627096 (1) by Brian Cohen, on Flickr | |
| Subject: Re: Charcoal canister box. | |
