| Replacement Ignition Key | |
+4rivi95era albertj Rivieraz Yardley 8 posters |
Yardley Enthusiast
| Subject: Replacement Ignition Key Thu Aug 27, 2020 12:34 pm | |
| Hi all.
I want to have one or 2 ignition keys made. With the chip in it, how do we do that? | |
Rivieraz Enthusiast
Name : tommy z Age : 56 Location : the Burgh Joined : 2019-01-08 Post Count : 227 Merit : 1
| Subject: Re: Replacement Ignition Key Thu Aug 27, 2020 12:43 pm | |
Rivieraz Enthusiast
| Subject: Re: Replacement Ignition Key Thu Aug 27, 2020 12:45 pm | |
| the chip is a resistor i believe the are numbered 1 to 15,if you go to the dealership with your vin # they could tell you or check the resistance urself. | |
| Subject: Re: Replacement Ignition Key Thu Aug 27, 2020 4:51 pm | |
| - Rivieraz wrote:
- the chip is a resistor i believe the are numbered 1 to 15,if you go to the dealership with your vin # they could tell you or check the resistance yourself.
Once you have the resistance, you can have a key cut at a real locksmith, or at a GM dealer (if someone remembers how to use that specific key cutter). My dealer has not charged me much at all for that if I bring my own key blank (maybe the $ goes into the coffee fund ha ha). The keys themselves were so low, low priced on eBay I bought a few - years ago. Not sure now, maybe go check it out. Granted, I think it's been about a decade since I had a key cut. | |
rivi95era Enthusiast
Name : Marc Age : 41 Location : Albemarle Joined : 2014-05-18 Post Count : 110 Merit : 0
| Subject: Re: Replacement Ignition Key Thu Aug 27, 2020 5:59 pm | |
| If you have someone handy with electrical, bypass the pass key using the same resistance method and never need a dealer to copy the key again, and no worries about the system shutting you out if the stops reading the key. There is a bypass for the system, just google passkey bypass. It should come up. | |
| Subject: Re: Replacement Ignition Key Thu Aug 27, 2020 8:42 pm | |
| - Yardley wrote:
- Hi all.
I want to have one or 2 ignition keys made. With the chip in it, how do we do that? Specifically: 1) in the factory service manual there's a table stating what number the keys are. ALSO - the LS1 site has a table up showing the GM part numbers and resistance values for the keys. Resistance value? Yeah, the chip in the key is just a resistor. Using an ohmmeter, just measure resistance by touching the ohmmeter leads to opposite sides of the "chip" (don't touch the key, you'll gen an error. Just touch the then metal sides of the chip) Here is the link to the table: https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/443x468/vatsresistancetable_52efc5aa75d4545f78388f1c256e5962ffddd63f.jpg 2a) you can get a dealer to cut your keys. The dealer can use the VIN to figure out which key, sell you a couple, and how to cut it to fit your original ignition cylinder. HOWEVER, if your cylinder was replaced and not re-set to match the old key, it'll be wrong. Just saying... slip the old key to the dealer if you want the dealer to cut the key... 2b) you can bypass the dealer. The key blanks are available over the internet, eBay and elsewhere -- you just have to know the resistance in the chip on the one you are replacing and then buy the key blanks having the number corresponding to that range. It'll take you less time to do this than it took to read this paragraph. From eBay the blanks will run $10 to $15 each shipped. From gmpartsdirect.com, someting like $22 plus tax and postage. Then with your key blanks, find a locksmith or hardware store that will cut your keys. Some shops won't warrant a cut if they don't sell you the blanks -- tell them you'll take the risk, just to be careful lining up the key in the lathe. By the way - -if your old keys are worn, you may be better off just having the dealer cut them from the VIN. GM dealers have a machine that does this (although it may not have been used in a while... be patient... ). Pretty much every locksmith advertising that it cuts car keys can cut PASSKey II keys properly. What I did: I measured my key chip, bought key blanks off eBay, the dealer cut them for me (my dealer didn't stock them anymore but had the machine), since it was my blanks, they did check the keys to see that they matched the car, and didn't charge me much for the cuts. Your mileage will vary of course. It was not under the table, they had a shop code for just doing the cuts and I got a receipt, but I jokingly tell myself the $ went into the shop's coffee till. Bottom line is, now that PASSKey II has come and gone so to speak, but there are loads of cars with it still on the road, this is not so hard. You *can" bypass the system, you will find instructions elsewhere on this site, and you will also find near there my comments as to why not do that. In your case, it's so easy to get proper keys and your system is working otherwise, don't mess with it just get the keys. Granted, the dealers charge as much as $36 each for these keys - the price on eBay for proper blanks is more like $15 unless you buy several at once, then they get cheap -- shop a bit you'll be surprised. Try using "GM VATS Key # double sided" as your search string. I saw #3 keys for $6 each, quantity one. See what you turn up. | |
Yardley Enthusiast
| Subject: Re: Replacement Ignition Key Thu Aug 27, 2020 10:58 pm | |
| Thanks. I ohm'd out a key. Got 11.76 - whatever the hell that means. I tried it on every ohm setting. I believe that is key #15. I'll stop at a Buick store asap. | |
| Subject: Re: Replacement Ignition Key Fri Aug 28, 2020 6:39 am | |
| - albertj wrote:
- Yardley wrote:
- Hi all.
What I did:
I measured my key chip, bought key blanks off eBay, the dealer cut them for me (my dealer didn't stock them anymore but had the machine), since it was my blanks, they did check the keys to see that they matched the car, and didn't charge me much for the cuts. Your mileage will vary of course. It was not under the table, they had a shop code for just doing the cuts and I got a receipt, but I jokingly tell myself the $ went into the shop's coffee till. ow Bottom line is, now that PASSKey II has come and gone so to speak, but there are loads of cars with it still on the road, this is not so hard.
You *can" bypass the system, you will find instructions elsewhere on this site, and you will also find near there my comments as to why not do that. In your case, it's so easy to get proper keys and your system is working otherwise, don't mess with it just get the keys. Granted, the dealers charge as much as $36 each for these keys - the price on eBay for proper blanks is more like $15 unless you buy several at once, then they get cheap -- shop a bit you'll be surprised. Try using "GM VATS Key # double sided" as your search string. I saw #3 keys for $6 each, quantity one. See what you turn up. I bypass when the system is damaged. I see no reason why it shouldn't be attempt if you know what you are doing. | |
Yardley Enthusiast
| Subject: Re: Replacement Ignition Key Wed Oct 14, 2020 2:01 pm | |
| Follow up. I took the key to a local Buick dealer. They have a box into which they insert the key and it tells them the ohm and the number and all. They ordered me a key and cut it for me. It was pretty cheap.
Thanks! | |
| Subject: Re: Replacement Ignition Key Thu Oct 15, 2020 5:32 am | |
| - Yardley wrote:
- Follow up. I took the key to a local Buick dealer. They have a box into which they insert the key and it tells them the ohm and the number and all. They ordered me a key and cut it for me. It was pretty cheap.
Thanks! Glad you got it sorted out. | |
denim Junkie
| Subject: Re: Replacement Ignition Key Tue Nov 15, 2022 10:52 am | |
| Does anyone use a #10 VATS key in their Riv?I have a blank I can't use. New. Free. BTW, I went to a Buick dealer in Albany to have blanks cut. The young guy doing this job sounded all the world as if he knew what he was doing, but took 4 times to cut the key and it still wouldn't turn in the ignition. They returned my money, but when I went to a professional locksmith shop, they said it was cut too short in some places and too long in others. FAIL. I had them throw that key out after they cut 3 keys that worked the first time (and these are two sided). Guh. | |
| Subject: Re: Replacement Ignition Key Thu Nov 17, 2022 3:26 pm | |
| I wouldn't mind replacing my old keys, but I have no idea what VATS I have. | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: Replacement Ignition Key Thu Nov 17, 2022 4:55 pm | |
| - Jack the R wrote:
- I wouldn't mind replacing my old keys, but I have no idea what VATS I have.
https://www.youtube.com/watch?v=Fpbz5oD0Vec&ab_channel=smallengineshop _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
denim Junkie
| Subject: Re: Replacement Ignition Key Thu Nov 17, 2022 5:25 pm | |
If you have a Buick dealer nearby (or any GM dealer, probably), you can ask to have the key measured with their VATS dufus box. They stick the key in and it tells what number key you have. I have #5 for instance, but that's not the resistance of the chip stuck in the blade. A #5 is 1.12 ohms, or so. You can measure resistance across each side of the key with an ohms meter. I just looked up the ohms value for a #10 key. It says 3.740k. This key I am offering is sealed in plastic, so I have yet to break the seal. That's what yours needs to be if you have a #10 key. You need to measure it.
carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07 Post Count : 805 Merit : 8
| Subject: Re: Replacement Ignition Key Thu Nov 17, 2022 6:03 pm | |
| A locksmith that does automotive work has a machine that can measure the resistance to get you the right frequency for the key. You can also get a key cut by code and it will be just like an original key. | |
Rivieraz Enthusiast
| Subject: Re: Replacement Ignition Key Sat Nov 19, 2022 12:21 am | |
denim Junkie
| Subject: Re: Replacement Ignition Key Sat Nov 19, 2022 7:47 am | |
| So, when someone needs a #10 key, let me know and I'll send it along. I can't use this blank. My car requires a #5 with the current lockset. | |
| Subject: Re: Replacement Ignition Key | |
