 Need 98 Riv under dash panel
4 posters
Yardley
Need 98 Riv under dash panel Empty
PostSubject: Need 98 Riv under dash panel   Need 98 Riv under dash panel EmptyThu Sep 17, 2020 6:24 pm
My panel that covers the underside of the dash above the driver's feet was hacked up. I got a replacement but it is not off a 98 (I'm guessing 99 is the same). There is no way to attach the OBD port without kind of buggering it up. I'd like the correct one.
Does anybody have an under dash panel?
http://www.1badriv.com
carguy8888
carguy8888
PostSubject: Re: Need 98 Riv under dash panel   Need 98 Riv under dash panel EmptyThu Sep 17, 2020 8:06 pm
Do you have the headlight photocell sensor?
Yardley
PostSubject: Re: Need 98 Riv under dash panel   Need 98 Riv under dash panel EmptyThu Sep 17, 2020 8:07 pm
No. And the car I got it from has been scrapped.
carguy8888
carguy8888
PostSubject: Re: Need 98 Riv under dash panel   Need 98 Riv under dash panel EmptyThu Sep 17, 2020 8:11 pm
Damn, thanks anyway. Good luck in your search. Just in case you don't know car-part.com has a listing of every junkyard in the country.
Merit : 149
PostSubject: Re: Need 98 Riv under dash panel   Need 98 Riv under dash panel EmptySat Sep 19, 2020 8:57 am
If it helps, I believe the part number is 25645384. For the lower panel.
https://www.gmpartsgiant.com/parts/gm-insulator-asm-i-p-25645384.html
Discontinued of course, but it might help in your bone yard searches.
71stagegs
71stagegs
PostSubject: Re: Need 98 Riv under dash panel   Need 98 Riv under dash panel EmptySun Sep 27, 2020 3:49 pm
» Removing dash panel?
» front dash panel swap
» Write-Up: Repairing broken seat back on a 95-99 Riviera
» PCM and fuse panel
» Trunk Lid Panel?
