| Do axles need to be installed in pairs? | |
carguy8888 Junkie
Name : Brian Cohen Joined : 2019-01-07 Post Count : 805 Merit : 8
| Subject: Do axles need to be installed in pairs? Wed Oct 07, 2020 9:16 pm | |
| When I make a right turn I am hearing snap crackle and pop. My mechanic said it's time for a axle. Should I just do the one that needs it or do I need to do both? | |
| Subject: Re: Do axles need to be installed in pairs? Wed Oct 07, 2020 11:35 pm | |
| ...not necessarily. My drivers side axle, I ran it 330 thousand miles. It was a Saginaw. Put in the best axle you can (ask mechanic which ones don't result in come-backs) and keep a log, or write on it in sharpie or paint pen the mileage at install.
If you're doing the work yourself consider replacing the lower control arms at the same time and go ahead and do both axles, hey you needed something to suck up a day, right? | |
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Thu Oct 08, 2020 9:38 pm | |
| All the axles I saw on RockAuto or Amazon I never heard of the names. The one thing I do know is I'm not doing it myself LOL. I just have to make a decision whether I'm going to figure out which axle it is and replace it or go for the gusto and replace both axles and the Gabriel quick struts but that's going to turn into a piece of change. | |
| Subject: Re: Do axles need to be installed in pairs? Thu Oct 08, 2020 9:49 pm | |
| - carguy8888 wrote:
- All the axles I saw on RockAuto or Amazon I never heard of the names. The one thing I do know is I'm not doing it myself LOL. I just have to make a decision whether I'm going to figure out which axle it is and replace it or go for the gusto and replace both axles and the Gabriel quick struts but that's going to turn into a piece of change.
You never heard of the names b/c they're all made in the Far East or Europe. I replaced the Saginaw with an APWI on recommendation from one of the mechanics who works on my car (not lowest price, but basically zero callbacks). | |
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Thu Oct 08, 2020 9:50 pm | |
| I'm going to look up that brand now thank you. | |
71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09 Post Count : 189 Merit : 2
| Subject: Re: Do axles need to be installed in pairs? Sun Oct 11, 2020 1:02 pm | |
| look for GM axels that r rebuilt better than china garbage check with ZZP they sell heavy duty ones for hi performance. https://zzperformance.com/collections/3800/products/stage-1-axles call them see where they r made good luck | |
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Sun Oct 11, 2020 11:33 pm | |
| They look good, I just have to get back to the shop to see which axle it is, pretty sure it's the right side but I don't want to guess. - 71stagegs wrote:
- look for GM axels that r rebuilt better than china garbage check with ZZP they sell heavy duty ones for hi performance.
| Subject: Re: Do axles need to be installed in pairs? Mon Oct 12, 2020 12:29 pm | |
https://zzperformance.com/collections/3800/products/stage-1-axles call them see where they r made good luck Those axles probably are built in China, they are just not necessarily garbage. When I have flown to/from China there are loads of Germans on the planes. Listening to their chatter, a number of them are technologists or tech managers working on one thing or another. German quality at Chinese costs will be difficult to compete against. | |
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Mon Oct 12, 2020 2:47 pm | |
| It says the ZZPs are an aftermarket axle but obviously they're not going to name the vendor. | |
| Subject: Re: Do axles need to be installed in pairs? Mon Oct 12, 2020 7:25 pm | |
| They say they r good for 300HP they have a stage 2 axel also | |
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Mon Oct 12, 2020 9:57 pm | |
| I did see that but my car will never see 300 horsepower. I'll leave that for my trans am. This car is just a different fun daily driver. | |
sarahk99 Special
Name : Sarah Kennedy Joined : 2020-10-20 Post Count : 2 Merit : 0
| Subject: Re: Do axles need to be installed in pairs? Tue Oct 27, 2020 6:26 pm | |
| - Quote :
- When I make a right turn I am hearing snap crackle and pop. My mechanic said it's time for a axle. Should I just do the one that needs it or do I need to do both?
Like this site https://writemyessay4me.org/dissertation with dissertation writing tips
always a good idea to change both at the same time
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Tue Oct 27, 2020 10:07 pm | |
| Ty, it turns out my axle's were ok. | |
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Sat Oct 31, 2020 6:45 pm | |
| The noise left and then returned so I had time to stop by a different and thorough mechanic. He checked everything and the only thing he could find was a small amount of play in the passenger axle "suprise lol". He then was able to inject a ton of grease into it so I guess it was dry. My question is even if the problem goes away there is still that small amount of play which I can't imagine grease will fix so should I replace the axles anyway? | |
| Subject: Re: Do axles need to be installed in pairs? Sun Nov 01, 2020 12:15 am | |
| - carguy8888 wrote:
- The noise left and then returned so I had time to stop by a different and thorough mechanic. He checked everything and the only thing he could find was a small amount of play in the passenger axle "suprise lol". He then was able to inject a ton of grease into it so I guess it was dry. My question is even if the problem goes away there is still that small amount of play which I can't imagine grease will fix so should I replace the axles anyway?
You'll want to replace it - the problem will be that a worn axle will mimic a tire out of balance condition but will largely be unsolvable/recurrent. | |
carguy8888 Junkie
| Subject: Re: Do axles need to be installed in pairs? Sun Nov 01, 2020 5:52 am | |
| Thank you Dr. Albert, I am going to replace both of them with the brand you suggested from RockAuto. Also, I do have a little bit of a vibration in the sixties. | |
HannaCooper Special
Name : HannaCooper Joined : 2021-02-03 Post Count : 1 Merit : 0
| Subject: Essaysbank.com Wed Feb 03, 2021 6:19 am | |
| Really nice site. Thank u for provideng tips and the material about papers and where better buy academic essays on Essaysbank.com | |
| Subject: Re: Do axles need to be installed in pairs? | |
