 Push clips
3 posters
Push clips Empty
PostSubject: Push clips   Push clips EmptyFri Oct 30, 2020 8:01 pm
I lost one from the passenger side inner fender. Anybody got a source for them? I see a lot of sellers for this generic, but similar, push clip - Link. I couldn't guess if it would work or not.
Merit : 180
Push clips Empty
PostSubject: Re: Push clips   Push clips EmptyFri Oct 30, 2020 9:01 pm
Last I checked, GM. Consider a junkyard run to pull a bunch, the GM OE push clips are pretty good.
Amazon sells "AUTEX" clips, they do work once, basically, when you R&R them they break the plastic is so brittle. I'd take a clip successfully pulled at the junkyard over a new AUTEX clip pretty much any day. Hopefully they will improve over time with feedback from buyers.
See if your GM dealer will give you gentler pricing if you buy packs of them. 10 to a pack.
Merit : 149
Push clips Empty
PostSubject: Re: Push clips   Push clips EmptySat Oct 31, 2020 8:37 am
Any auto body supply will have what you need. Buy a box of them. Bring one to match up.
albertj likes this post
Push clips Empty
Push clips
» Push the Daiphragm Down
» Body clips
» Push Button Ignition
» push button start
» Write-Up: Installing Rockers, Valve Springs, & Push Rods
