Johnny Malone Amateur
Name : Johnny5 Location : Spfld, Mass Joined : 2012-06-12 Post Count : 31 Merit : 2
| Subject: push button start Mon Sep 03, 2012 9:49 am | |
| Does anybody know how to install a push button start in their riv? I've been search threw the forum with no luck. | |
| Subject: Re: push button start Mon Sep 03, 2012 9:54 am | |
| http://www.watsons-streetworks.com/ignition_switches.html
theyll tell you how to instal it. | |
| Subject: Re: push button start Mon Sep 03, 2012 10:03 am | |
| so i wouldnt be able to just go to the store and get a button wire and relay | |
| Subject: Re: push button start Mon Sep 03, 2012 4:42 pm | |
| - Johnny Malone wrote:
- so i wouldnt be able to just go to the store and get a button wire and relay
of course you could but have you really thought about the problems that would introduce? ..point is, to do it right you have to also have a way to lock out starting if the car is in gear, a way to latch the ignition circuit on when the car has started, a way to command the car off if it is on, and a way to defeat the pushbutton starter if the button pusher is not the driver (that is, either a physical key, a keypad interlock, or an RFID tag with associated circuitry to lock it out). Albertj | |
| Subject: Re: push button start | |
