| Push Button Ignition | |
+597rivman AA SpaceBar Mr.Riviera ender467 9 posters |
ender467 Amateur
| Subject: Push Button Ignition Thu Aug 02, 2007 6:34 pm | |
| Hey guys, I just got a job over at my local radioshack and it turns out that the manager there is an electronics wiz. I mentioned a push button ignition to him and he said it would be no problem as long as I had a wiring diagram. He just went on vacation, but he said when he gets back he can set the whole thing up for me. But where can I find the right wiring diagram? It would be real nice to have the keyless entry where the cigarette lighter is so it is all recessed and just plain sweet looking. Any help on this would be awesome. Thanks again guys. | |
| Subject: Re: Push Button Ignition Thu Aug 02, 2007 11:02 pm | |
| that would be cool. very james bond, maybe have the button on the shift knob like MB. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
SpaceBar Aficionado
| Subject: Re: Push Button Ignition Thu Aug 02, 2007 11:20 pm | |
| What year Riv do you have? Rivman97 has Alldata for the 97 so maybe he could help you out with that. | |
| Subject: Re: Push Button Ignition Fri Aug 03, 2007 8:48 am | |
| As long as the button isn't a Radio Shack one... need to use a very cool-looking one! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
ender467 Amateur
| Subject: Re: Push Button Ignition Fri Aug 03, 2007 3:20 pm | |
| It just so happens that I do have a 97 Riviera. I don't think i would have a radio shack button, maybe one of the covered and lighted switches for a cutoff so that the ignition button wouldn't damage the starter if some idiot tried to hit the push engine button while the engine was already started. Saw some of the lighted push button engine start things online for 30-50 bucks. Not sure if it would make my dash glow a crazy red though. Might be pretty cool though. | |
97rivman Fanatic
| Subject: Re: Push Button Ignition Fri Aug 03, 2007 3:34 pm | |
ender467 Amateur
| Subject: Re: Push Button Ignition Fri Aug 03, 2007 3:39 pm | |
| Sweet.....no idea what any of it means, but my manager should. I should have an update in a week or two. Thanks Rivman! | |
| Subject: Re: Push Button Ignition Fri Aug 03, 2007 4:13 pm | |
| You could build a time-delay circuit that uses a momentary pushbutton switch to provide sustained +12dc for say 2-3 secs. This would let you hit the switch only for a split second and provide the starter with a long enough duration. It would also prevent long starts more than 3 secs. Radio shack has little notebooks on how to build these circuits, written by Forrest Mims (don't ask me how I remembered that). _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
jax95riv Aficionado
| Subject: Re: Push Button Ignition Fri Aug 03, 2007 5:12 pm | |
| Something like the car from Transporter 2 would be cool, that you have to enter a pin to unlock the system. Very James Bond. | |
SpaceBar Aficionado
| Subject: Re: Push Button Ignition Fri Aug 03, 2007 10:57 pm | |
| - jax95riv wrote:
- Something like the car from Transporter 2 would be cool, that you have to enter a pin to unlock the system. Very James Bond.
I want one of those. | |
ender467 Amateur
| Subject: Re: Push Button Ignition Sun Aug 19, 2007 1:51 pm | |
| Could you also provide the power distribution schematic aswell as the fuse block details?
Thanks | |
97rivsc Fanatic
Name : mike Age : 34 Location : appleton wisconsin Joined : 2008-09-28 Post Count : 437 Merit : 0
| Subject: Re: Push Button Ignition Mon Dec 22, 2008 1:23 am | |
| i got the alldata for the 97 also so here they are power distribution schematic fuse block 1 fuse block 1(second half) fuse block 2 fuse block 2(second half) fuse block 3 fuse block 3(second half) hope this helps cuz i really wanted to do the pushbutton start | |
T Riley Guru
| Subject: Re: Push Button Ignition Mon Dec 22, 2008 9:16 am | |
| - 97rivsc wrote:
hope this helps cuz i really wanted to do the pushbutton start well...... This is a year and 4 month old thread.... so MAYBE the OP will get it | |
Sweepspear Fanatic
Name : Dale Age : 63 Location : Minneapolis, MN Joined : 2008-11-04 Post Count : 386 Merit : 11
| Subject: Re: Push Button Ignition Mon Dec 22, 2008 9:59 am | |
| Push button ignition. Everything old is new again. Cars used to have push button ignitions way back when. Now it's considered new technology. | |
| Subject: Re: Push Button Ignition | |
