 96 L67 motor and trans mounts
2 posters
OrangeCat3800
96 L67 motor and trans mounts Empty
PostSubject: 96 L67 motor and trans mounts   96 L67 motor and trans mounts EmptyThu Nov 26, 2020 2:21 am
I just got my 1996 Riviera with L67. I believe the motor mount and trans mounts are slightly worn even with 82k miles... However, AC Delco doesn't even make the mounts anymore. So right now there are only the DEA/Westar/Anchor mounts from Rockauto. Do these mounts last? I've heard some bad stories about them. Or is there any place I can get Delco trans mounts for the car?
My current solution: Use Delco mounts for 96-99 sc Bonnevilles, use the insert and put into the old bracket.
Trans mount: Use the aftermarket ones?
Merit : 149
PostSubject: Re: 96 L67 motor and trans mounts   96 L67 motor and trans mounts EmptyThu Nov 26, 2020 10:41 am
» FAQ: Engine/Transmission Motor Mounts
» Write-Up: Hockey Puck & Casting Front/Side Motor Mounts
» 1995 Riveria Motor Mounts
» Write-Up: Subframe/Cradle Mount Insulators & Bushings
» Strut Mounts
