| | Write-Up: Hockey Puck & Casting Front/Side Motor Mounts | |
| Author | Message |
oldsman105 Enthusiast
Name: Enrique Patino Age: 26 Location: Queens, New York City Joined: 2007-01-24 Post Count: 749 Merit: 9
 | Subject: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Sun Mar 09, 2008 11:30 am | |
98riviera98 Aficionado
Name: Travis Age: 22 Location: Passing you Joined: 2007-02-08 Post Count: 4773 Merit: 7
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Sun Mar 09, 2008 2:22 pm | |
| thats REALLY COOL!!!!!!!!!!!!!!!! |
albertj Aficionado
Name: Location: Finger Lakes of New York State Joined: 2007-05-31 Post Count: 4901 Merit: 100
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Sun Mar 09, 2008 2:24 pm | |
| Looks like an improvement over the OEM gumband strip mounts. Thanks for the writeup.
Albertj |
ewolfe0050 Fanatic
Name: Eric Location: Indianapolis, IN Joined: 2007-07-31 Post Count: 1161 Merit: 25
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Sun Mar 09, 2008 5:14 pm | |
| passenger side mounts are 3" x 3" also. I poured a casting of polyurethane 85 durometer into a capped off piece of 3" ID PVC pipe, coatd the insides with wax, and marked 3.5" up and poured it. Slipps out easily because fo the wax and it's hard enough to machine the hole for the bushing and bolt. I got the poly in blue so it should look good installed. |
ewolfe0050 Fanatic
 | Subject: Write-Up: Rubber Trans Mounts Version 2 Mon Apr 07, 2008 3:23 pm | |
| Here is an idea of how I casted my mounts. Passsenger side mount  Passenger side mount apart... got to bend the tabs for the center to come out. Factory glued it in also so get your hammer ready  I used a generic tube for the bushing. Same length 4" as stock and same ID.  Make template... The hole is off center.   Make sure you coat your template with a release agent. Before you pour.  I used toilet wax to fill any holes or gaps. Dont forget to cover the hole in the side!!! My first pour just came out the hole and covered everything. Thankfully I had everything resting in a baking pan so it was contained for the most part. Pour and wait. I let it set for a good day before I removed the template. Wash off the wax and your set! Here is a photo of the passenger side mount and front mount completed. (I reused the bushing for the front and rear mounts-easy to cut out). The rear was my first attempt and I did not come out pretty- have to redo that one. I have no idea how I am going to deal with the drivers side mount. Pix of that at the end.   Not the prettiest but they should work well. 80A hardness. I would imagine stock is somewhere between 45-50A. Now for the driveres side mount...
turtleman Addict
Name: Codith Age: 24 Location: Villa Park, IL Joined: 2007-02-08 Post Count: 2655 Merit: 89
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Mon Apr 07, 2008 4:10 pm | |
| Eric, would this be something the rest of us could do ourselves? Want to make a few more..? lol |
ewolfe0050 Fanatic
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Mon Apr 07, 2008 4:38 pm | |
| It's actually fairly easy once you get the hang of it. I went through several batches of poly before I got it right. Stupid things that could have been avoided if I wasn't in such a rush. I tried using a clay block to hold the bushing and mount- failed miserably. Forgot to plug the hole in the passenger side mount- big mess when the poly leaked out. Bought the wrong type of poly- cost me lots of money but I have very nice 85B hardness mounts now (they're harder than steel but completely un-usable). Stuff like that... Take your time and they will come out OK- If I was anymore anal I would redo them because you can (barely) see the brush strokes from the release wax application.
You can get the material at www.mcmaster.com. Shore 60A is P/N 8644K24. It will be firmer than stock. The 80A hardness, would be 8644K11. The hardness of a hockey puck is shore 85A for comparison. McMaster has the easiest stuff to use. If you want to fine tune the hardness you can go to Freemans site. |
Name: Aaron Age: 34 Location: C-bus, Ohio Joined: 2007-01-13 Post Count: 14467 Merit: 172
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Mon Apr 07, 2008 4:40 pm | |
| Good stuff, Eric. Thanks for the write-up! _________________ "An intercooled, supercharged, 280 HP Buick Riviera with neck-snapping acceleration and precise handling that proves GM can make something really interesting and competent, if only they would build more than one at a time." - John R. White, Boston Globe
"I think that in any racing engine, the nearer you are to disintegrating, in general the better its performance will be." - Keith Duckworth, Cosworth Engineering
'98 SC Riviera 238k miles 298 HP/370 LB-FT 0-60: 5.79s ET: 13.97 @ 99.28 4087 lb 20.5 avg MPG
3.4" pulley AL104 plugs 180Ί t-stat FWI w/K&N 1.9:1 rockers OR pushrods LS6 valve springs SLP headers ZZP fuel rails KYB GR2 struts MaxAir shocks Addco F/Rsway bars ES links/bushings GM strut brace Enkei 18" EV5s Dunlop DZ101 tires F-body calipers EBC bluestuff/Hawk HP plus SS lines slotted discs ATE superblue fluid DHP tuned Aeroforce Hidden Hitch
2toneRivi Apprentice
Name: Chris Age: 25 Location: BG 562 Joined: 2007-04-24 Post Count: 94 Merit: 0
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Mon Apr 07, 2008 5:45 pm | |
| ewolfe those mounts look nice!!!! can u link me to the exact material u used at the mcmaster.com website pls!!!! |
ewolfe0050 Fanatic
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Mon Apr 07, 2008 6:10 pm | |
| The 80A hardness, would be 8644K11. I bought the release wax from freeman but mcmaster would probably have a comparable release wax. McMaster product is very easy to use for the do-it-yourselfer. I got 4 1lb kits. One for each mount. They have a 10lb kit but it is much easier one at a time- trust me. Freemans site is for the professional- able to fine tune but don't expect the people there to address any questions you might have, they assume you know what you are doing. (more for commercial applications) |
ewolfe0050 Fanatic
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Mon Apr 07, 2008 7:34 pm | |
| An afterthought... 85A is a pretty stiff mount especially a "solid" mount with no gaps in the rubber/poly. For those who do not like vibration they might want to go with 60A hardness. Still stiffer than stock. They do break in after a while- just wanted to warn you guys. |
robotennis61 Junkie
Name: robotennis Age: 50 Location: las vegas Joined: 2007-12-17 Post Count: 3865 Merit: 72
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Tue Apr 08, 2008 1:03 am | |
| thats cool! let us know how they ride! |
ewolfe0050 Fanatic
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Tue Apr 08, 2008 8:18 am | |
| Another easier fix would be to do what some the W-Body people do with their mounts. It would work on the front and rear trans mount but probably not the side mounts. The trans mounts are square with a lot of gap between the rubber . Fill the gaps with poly (I have heard JB Weld will work also). You still have some flex with the rubber still being in place but it will firm up the mount. I think I saw a thread about it at 3800pro.com forum. |
ewolfe0050 Fanatic
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Fri May 02, 2008 2:54 pm | |
| The three mounts are now in. P mount and front/rear transmission mounts. Paul at PRJPerformance was impressed with them especially for my first castings. Other than being a PITA to install (mostly rear trans mount) they fit very well. Once I have a chance to drive the car after the rest of my mods, I will let you know how they perform. He suggested that I start making them available for sale. I am strongly considering it... I have the process down now and If I can make a reusable templete it will be that much easier. I could do it in 80A or 60S hardness. Would anyone be interested? I dont spend too much in material (not including the mounts) so they wouldn't be too expensive and should be in line with some of the aftermarket mounts for other 3800 cars. After a chance to drive with them for a while I will start a poll...just keep it in mind. |
TonySmooth89 Addict
Name: Anthony Age: 23 Location: Florida Joined: 2007-11-14 Post Count: 2411 Merit: 16
 | Subject: Re: Write-Up: Hockey Puck & Casting Front/Side Motor Mounts Fri May 02, 2008 3:02 pm | |
| I'd be interested in the 60A mounts. |
