 Motor mounts
Rivieraz
Derrick_7666
6 posters
Derrick_7666
Name : Derrick MacDonald
Motor mounts Empty
PostSubject: Motor mounts   Motor mounts EmptyThu Aug 13, 2020 9:27 pm
Hi I'm new to this forum and have been in contact with everyone I can think of about the issue and I hope someone here can help. I have a 97 riviera supercharged with a bad motor mount (not transmission mount). The part was discontinued by GM 13 years ago and never produced aftermarket. What can be done about it? Will a park Avenue mount fit? Please help
Rivieraz
Rivieraz
Motor mounts Empty
PostSubject: Re: Motor mounts   Motor mounts EmptyThu Aug 13, 2020 11:12 pm
welcome derrick_7666, you have come to the right place just hold tight and someone will chime in with help! good luck!
Merit : 149
Motor mounts Empty
PostSubject: Re: Motor mounts   Motor mounts EmptyFri Aug 14, 2020 8:26 am
Google "motor mount rebuilding" Then make some phone calls.
Derrick_7666
Motor mounts Empty
PostSubject: Re: Motor mounts   Motor mounts EmptyFri Aug 14, 2020 6:10 pm
I'll try it, thanks!
Motor mounts Empty
PostSubject: Re: Motor mounts   Motor mounts EmptyFri Aug 14, 2020 10:01 pm
Good info in this thread - Link
I would guess 99 and 97 are the same.  I'm sure AlbertJ will be along to help shortly.
ejulien6
Motor mounts Empty
PostSubject: Re: Motor mounts   Motor mounts EmptySun Aug 16, 2020 8:25 am
I have the same issue. Hoping someone can point me in the right direction.
Merit : 180
Motor mounts Empty
PostSubject: Re: Motor mounts   Motor mounts EmptySun Aug 16, 2020 1:37 pm
Do what Larry said.
For a quick fix I would get a junkyard mount and I would find out why yours went bad -- if you maintain the transmission mounts, the motor mount doesn't fail IME (in my eperience).
Motor mounts Empty
Motor mounts
» What do we do for motor mounts now?
» FAQ: Engine/Transmission Motor Mounts
» 96 L67 motor and trans mounts
» 1995 Riveria Motor Mounts
» Write-Up: Hockey Puck & Casting Front/Side Motor Mounts
