 CV axle seal
2 posters
Cliff96
CV axle seal Empty
PostSubject: CV axle seal   CV axle seal EmptyMon Dec 07, 2020 7:09 pm
Does anyone know if the cv axle output seal us the same part for the drivers side and the passenger side? I'm replacing the drivers side axle and I only see a seal listed for the passenger side at local parts houses. Thanks
Merit : 149
CV axle seal Empty
PostSubject: Re: CV axle seal   CV axle seal EmptyTue Dec 08, 2020 7:46 am
These look different and one is labelled right,
https://www.rockauto.com/en/catalog/buick,1996,riviera,3.8l+v6+supercharged,1022038,drivetrain,axle+shaft+seal,2336
Cliff96
CV axle seal Empty
PostSubject: Re: CV axle seal   CV axle seal EmptyTue Dec 08, 2020 8:27 am
Yes, thanks Larry. I found the correct part at a local parts house. I just got received the cv axle and I'm going to pick up the seal locally today. I buy a lot of parts from rockauto but I do like to buy some items from the local parts stores to keep them around. If the price difference if a lot though I order from rockauto. I also use rockauto to compare part numbers and verify compatibility. Thanks again
CV axle seal Empty
CV axle seal
» CV axle seal
» CV axle help
» CV Joint & Axle/Shaft Replacement
» Super charger pulley seal?
» Axle Half Shafts
