| | "Top end" gasket set | |
| | Author | Message |
Rp23g7 Rookie
Name : steve brogren Joined : 2021-05-12 Post Count : 14 Merit : 0
| Subject: "Top end" gasket set Tue May 18, 2021 3:45 pm | |
| So. I have had my 96 SC 230,000 mile Riviera for a week now, and I gotta say it runs and drives aswome, except the CEL had been on.
Finally got the Scan tool I ordered, and found I had the P1406, and P0171, so looks like I will be searching for a vacuum leak and replacing the EGR. Oh and a 1441, probably from me overfilling the gas tank.
It has all the records and it's had the coolant elbow, at least one done, ( not sure where the other is) but the one by the alternator is still plastic.
I bought the Dorman metal ones and AC Delco o rings.
But just looking at the injectors, I don't think they have been replaced. So I was thinking of just doing everything, injectors, lower gaskets, SC Gasket, elbows, TB gasket.
Does anyone make a top end kit, or do you need a full gasket set or just buy them individually? | |
| | | LARRY70GS Aficionado
| Subject: Re: "Top end" gasket set Tue May 18, 2021 5:42 pm | |
| https://www.rockauto.com/en/catalog/buick,1996,riviera,3.8l+v6+supercharged,1022038,engine,intake+manifold+gasket,5424
https://www.rockauto.com/en/moreinfo.php?pk=1400339&cc=1022038&jsn=487&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86%2BAYIhFUNxSQbBt9G0BIcUFg1e73oBkDLRl78blzN6Ccld9H9fPqgswKu2eD28c4ecmCmnw6go%2FtdWeMh4RQnGPqGljMOqTcFHZySgVVHseR4tIG2gKPYmXSJgHMY1aWoGUXUkasOiCyPRaxYsrvl47Oxwl9PSdpmil0FZnuoqkvM8R3B%2FwnryyojwEtZkkrle7EPBnjvRU%2FIWKNafnvqUtq3kUOZRtlbwPqaUloLaA3JfJIo9AJ4IsxqOmbDsJuyrPyxEYmD%2FM0Kz6pyq2I52OXzMDWjtRvMl7Xsb&jsn=487&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86%2BAYIhFUNxSQbBt9G0BIcUFg1e73oBkDLRl78blzN6Ccld9H9fPqgswKu2eD28c4ecmCmnw6go%2FtdWeMh4RQnGPqGljMOqTcFHZySgVVHseR4tIG2gKPYmXSJgHMY1aWoGUXUkasOiCyPRaxYsrvl47Oxwl9PSdpmil0FZnuoqkvM8R3B%2FwnryyojwEtZkkrle7EPBnjvRU%2FIWKNafnvqUtq3kUOZRtlbwPqaUloLaA3JfJIo9AJ4IsxqOmbDsJuyrPyxEYmD%2FM0Kz6pyq2I52OXzMDWjtRvMl7Xsb
https://www.rockauto.com/en/moreinfo.php?pk=260723&cc=1022038&jsn=495&_nck=ZExt1ysfqhqWnq%2BEvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86%2BAYIhFUNxSQbBt9G0BIcUFg1e73oBkDLRl78blzN6Ccld9H9fPqgswKu2eD28c4ecmCmnw6go%2FtdWeMh4RQnGPqGljMOqTcFHZySgVVHseR4tIG2gKPYmXSJgHMY1aWoGUXUkasOiCyPRaxYsrvl47Oxwl9PSdpmil0FZnuoqkvM8R3B%2FwnryyojwEtZkkrle7EPBnjvRU%2FIWKNafnvqUtq3kUOZRtlbwPqaUloLaA3JfJIo9AJ4IsxqOmbDsJuyrPyxEYmD%2FM0Kz6pyq2I52OXzMDWjtRvMl7Xsb _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Rp23g7 Rookie
| Subject: Re: "Top end" gasket set Tue May 18, 2021 7:13 pm | |
| so i guess no actual kit with everything. looked at the egr valve, it looks like a 230,000 mile egr valve, | |
| Subject: Re: "Top end" gasket set Wed May 19, 2021 8:19 am | |
| That second felpro kit comes with injector o rings, stat housing gasket, O ring, basically everything you need except the intake to SC gasket. That isn't good enough? _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Rp23g7 Rookie
| Subject: Re: "Top end" gasket set Wed May 19, 2021 10:57 am | |
| Oh guess it does have everything, thsnks | |
| | | albertj Master
| Subject: Re: "Top end" gasket set Wed May 19, 2021 3:42 pm | |
| ...my guess is your LIM gasket is sucking wind, or you have a crack in the exhaust manifold.
While you are under there, look at the oil pressure sender. If it has oil around it, replace it - they tend to spray a mist of oil onto the block for a while before they fail, but when they fail they fail hard and your engine will wizz away its oil in seconds at highway speeds. | |
| | | Sponsored content
| Subject: Re: "Top end" gasket set | |
Similar topics | |
