| ZZP trans pan | |
9ty7rivi Enthusiast
Name : terrance Age : 36 Location : San Antonio, Texas Joined : 2015-04-17 Post Count : 138 Merit : 2
| Subject: ZZP trans pan Tue Aug 10, 2021 8:03 pm | |
9ty7rivi Enthusiast
| Subject: Re: ZZP trans pan Tue Aug 10, 2021 8:21 pm | |
| Forgot the best part. It has a drain plug! | |
9ty7rivi Enthusiast
| Subject: Re: ZZP trans pan Tue Aug 10, 2021 9:34 pm | |
| I see that it's "ribbed for her pleasure," but what else is different? Is it deeper-for-her-pleasure too? | |
9ty7rivi Enthusiast
| Subject: Re: ZZP trans pan Wed Aug 11, 2021 8:50 am | |
| HAHA good one! Although it appears to be deeper, I believe the depth is the same because it does hold the same amount of fluid. I will say however the fluid still looks nice and bright red after running the old transmission hard for a few light 2 light pulls! Does not smell burnt like my old pan and Dex III used to treat me. | |
| Subject: Re: ZZP trans pan Wed Aug 11, 2021 12:01 pm | |
| I see now - those are cooling fins. At first glance I thought they were indented into the pan, but they stick out, and quite a bit! | |
9ty7rivi Enthusiast
| Subject: Re: ZZP trans pan Wed Aug 11, 2021 1:40 pm | |
| - Jack the R wrote:
- I see now - those are cooling fins. At first glance I thought they were indented into the pan, but they stick out, and quite a bit!
They sure do! Its like a woman with her hair in the wind! If I were to guess they are at least 2in in length! I'll take a measurement later. | |
| Subject: Re: ZZP trans pan Wed Aug 11, 2021 2:02 pm | |
| It's going on my wish list, but I'm concerned about it scraping. | |
9ty7rivi Enthusiast
| Subject: Re: ZZP trans pan Wed Aug 11, 2021 4:26 pm | |
| - 9ty7rivi wrote:
- Ok. I was a little excited and exaggerated on the length.
This thread is in danger of developing a theme, but I won't go there. I won't go there. Thanks for the pics, that looks safe enough. | |
9ty7rivi Enthusiast
| Subject: Re: ZZP trans pan Wed Aug 11, 2021 5:31 pm | |
| - Jack the R wrote:
This thread is in danger of developing a theme, but I won't go there. I won't go there. I don't know if I want to get that one started. haha Thanks for the pics, that looks safe enough.[/quote] Not a problem! Just here to help out. My goal was to make my riv as efficient as possible! It is my daily. | |
dAriel49 Amateur
Name : Jarred Joined : 2018-10-02 Post Count : 45 Merit : 0
| Subject: Re: ZZP trans pan Sun Nov 07, 2021 9:52 pm | |
| This will be on top of our mod list when we start working on uncle's new Riv project. Close to 230k miles on the clock and it needs some TLC. Got to finish installing the suspension and brake kit from 4Wheelonline onto the Wrangler before we can clear the garage and take her in. | |
| Subject: Re: ZZP trans pan Mon Nov 08, 2021 1:37 pm | |
Looks interesting. IIRC the benefit of aluminum pans (oil and trans) was the cooling and the problem was they'd shatter instead of dent when you scrape something. | |
| Subject: Re: ZZP trans pan Mon Nov 08, 2021 1:57 pm | |
| I'd hate to have my transmission pan shatter. I think I'd rather have my finned pan in steel, for all the good the weight savings of an aluminum pan does on a 4000 lb car. | |
| Subject: Re: ZZP trans pan | |
| ZZP trans pan | |
