kennyj4 Amateur
| Subject: Torque Converter Clutch Tue Oct 30, 2007 11:03 am | |
| So, I've done some research on my "Transmission Slipping" code and think I've isolated it to my torque converter clutch.
I don't know anything about cars so can someone tell me how expensive this would be to fix or if there is any way that I can do something to fix it?
I just want power back to my Riviera! | |
| Subject: Re: Torque Converter Clutch Tue Oct 30, 2007 11:22 am | |
| what year is it? and what engine does it have? what is the actual code you are getting? the parts to replace a TCC are not as expensive as the labor. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Torque Converter Clutch Sat Nov 03, 2007 9:46 pm | |
| It could just be a TCC solenoid? A friendly GM mechanic with a 'TECH II' can actuate the TCC solenoid manually a few times and sometimes that can free up a stuck one. Those solenoids (TCC and PCS) are extremely sensitive to dirt. | |
kennyj4 Amateur
| Subject: Re: Torque Converter Clutch Sun Nov 04, 2007 4:41 pm | |
| It's a '96 with 123,000 Series II supercharged engine.
The code I'm getting is a P1870 code. I've read that it could be the torque converter clutch.
How much does it cost to replace a solenoid? | |
| Subject: Re: Torque Converter Clutch Sun Nov 04, 2007 5:38 pm | |
| unfortunately it's kind of labor intensive to replace the solenoids. I was told the trans had to be lowered to get at them. But since I needed a full rebuild anyway I don't know. | |
ericde Enthusiast
| Subject: Re: Torque Converter Clutch Sat Feb 28, 2009 2:50 pm | |
| i didnt have to drop my subframe got out of alot of work:) | |
| Subject: Re: Torque Converter Clutch | |
