| yes found a motor is it a good deal? | |
+7TonySmooth89 1998 Riv urbsnspices IBx1 palermocorey90 AA mr.19982tone 11 posters |
mr.19982tone Member
Name : john Age : 39 Location : syracuse ny Joined : 2008-01-14 Post Count : 52 Merit : 0
| Subject: yes found a motor is it a good deal? Mon Jan 21, 2008 4:56 pm | |
| 88,000 miles 90 day warrinty for $700$ with supercharger? or 1 in pa for $800$ with 32,000 100day warrinty three hours away | |
| Subject: Re: yes found a motor is it a good deal? Mon Jan 21, 2008 5:06 pm | |
| I'd take the 32,000 mile one for the extra $100.
Thread moved to Series II SC Tech _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
palermocorey90 Expert
| Subject: Re: yes found a motor is it a good deal? Mon Jan 21, 2008 6:35 pm | |
| do if u need help with the motor swap just ask | |
IBx1 Expert
| Subject: Re: yes found a motor is it a good deal? Mon Jan 21, 2008 7:52 pm | |
| Definitely take the one with 1/3 of the miles. It's worth the extra $100, because "if you buy cheap you pay twice." | |
urbsnspices Fanatic
| Subject: Re: yes found a motor is it a good deal? Tue Jan 22, 2008 9:31 am | |
| One hundred clams is nothing in the long run, whereas 55,000 miles are....55,000 miles.
Dont buy it if it has a dented oil pan, and make sure it isnt an M62 SC. | |
| Subject: Re: yes found a motor is it a good deal? Tue Jan 22, 2008 9:43 am | |
| M62 SC = Series I 3800 Supercharged _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
mr.19982tone Member
| Subject: Re: yes found a motor is it a good deal? Tue Jan 22, 2008 10:45 am | |
| the one the 32,000 is 3 hours away and my other cars are a 79 caprice coupe witch is of the road for winter..cant put a motor in that car an a 99 jeep cherokee sport not sure if it will fit in the back and be able to get it out. | |
| Subject: Re: yes found a motor is it a good deal? Tue Jan 22, 2008 11:06 am | |
| Look into shipping options, the 32k motor is a STEAL at $800 unless it suffered abuse or has other issues. But then you have the warranty. Maybe one of our other NY members has a truck and some spare time? | |
TonySmooth89 Aficionado
| Subject: Re: yes found a motor is it a good deal? Tue Jan 22, 2008 11:20 am | |
| - urbsnspices wrote:
- One hundred clams is nothing in the long run, whereas 55,000 miles are....55,000 miles.
Dont buy it if it has a dented oil pan, and make sure it isnt an M62 SC. dented oil pan? what would that mean? | |
racinfan Addict
| Subject: Re: yes found a motor is it a good deal? Tue Jan 22, 2008 1:38 pm | |
| - mr.19982tone wrote:
- the one the 32,000 is 3 hours away and my other cars are a 79 caprice coupe witch is of the road for winter..cant put a motor in that car an a 99 jeep cherokee sport not sure if it will fit in the back and be able to get it out.
It should fit in the cherokee, you'll probably have to put the backseat down and leave the spare tire at home. You're just getting the engine correct? As for pan dents, you want to make sure nothing tried to exit from inside the pan (which would make a convex dent). | |
| Subject: Re: yes found a motor is it a good deal? Tue Jan 22, 2008 1:46 pm | |
| A dent in the bottom of the pan would need to be fixed. You don't want to risk the possibility of blocking oil flow into the pickup tube. Not uncommon for an engine to get dropped on the floor a bit too hard and dent the pan. | |
BillBoost37 Junkie
| Subject: Re: yes found a motor is it a good deal? Wed Jan 23, 2008 9:52 am | |
| I know for a fact that an L67 will fit in the trunk of a Bonneville. It should fit in the Cherokee. | |
dennycrane Amateur
Location : PA Joined : 2007-11-07 Post Count : 23 Merit : 1
| Subject: Re: yes found a motor is it a good deal? Wed Jan 23, 2008 1:44 pm | |
You can rent a pickup truck from Enterprise for less than $40 a day with unlimited mileage. | |
mr.19982tone Member
| Subject: Re: yes found a motor is it a good deal? Thu Jan 24, 2008 10:16 am | |
| that cheap but i got the motor with 88.000 on it with 4 months warrinty | |
| Subject: Re: yes found a motor is it a good deal? Thu Jan 24, 2008 11:12 am | |
| Hope it turns out to be a good deal in the end, and I know convenience is always a consideration as well. | |
mr.19982tone Member
| Subject: got the new motor in Sat Jan 26, 2008 7:31 pm | |
| got my new motor in and she runs great not a ting,ping.bang or smoke fired right up i feel like im a new proud parent of a baby girl:) | |
| Subject: Re: yes found a motor is it a good deal? Sat Jan 26, 2008 9:57 pm | |
| good news! just take a look at the mod guide before you go crazy with this one.
btw topic moved to series II engine/tranny section. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: yes found a motor is it a good deal? | |
