the other difference is T304 is nonferrous - meaning it wont' rust the same way the common stainless for exhausts does. It also will take a polish (probably due to nickel content but I am not sure).
I think he meant "409" instead of 403. That's common for stainless exhaust components. It's relatively cheap, and heat resistant. The only downside is that it will form a light surface rust after a while, which prohibits further oxidation.
304 costs more for the benefit of no surface rust. That's about all you get for the extra money.
If you really like spending money, go with the best - 321.
OK, next question please - all other things being equal in a given exhaust system, what changes in tone happen when a longer resonator is swapped in for a shorter one (assuming same construction, straight thru pipe)?
Name : Codith Age : 36 Location : Villa Park, IL Joined : 2007-02-08Post Count : 3671 Merit : 140
Subject: Re: FAQ: The Exhaust Thread Fri Jul 10, 2009 1:40 am
noisier, less deep sound
I witnessed almost exactly that scenario on a 4cyl ranger
what about a larger diameter but same length resonator. For example, if I were to replace the stock center post-cat piping with 3", and used a 3" resonator of the same length (I'm thinking 6" chamber)?
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8606 Merit : 180
I decided to install sound deadening material in the trunk, but could not find any locally and don't have any trips to say Rochester coming up. So I tried a roll of vinyl stair tread material. It's not Dynamat but it does work. Reduces the resonance a lot.
I also added some fiber padding (similar to what's under the trunk carpet) to the molded side panels in the trunk.
At some time in the future I can pull the vinyl out and put DynaMats in... but what I did dampened noise pretty well. We'll see - am on the highway again Sunday.
I took videos yesterday ( Sunday ) and posted them on YouTube. One is a cold start-idle-rev sequence and the other is a driveby sequence. My YouTube id is TheAlbertj. (surprised?) If the link does not work you can find 'em that way.
Please tell me what you think of the sound.
First video is a cold start - revving to the 4000 RPM limiter - shutoff sequence. Note the condensation on the resonated tailpipe tips.
https://www.youtube.com/watch?v=AlhoW4BWgHs
Second video is a driving sequence. Up a short hill (off camera, around a loop, then back past the camera. Maybe a little lame but the last ~15 seconds gets the point across and I suspect is what you all were interested in. The muffler cans are kinda big and hung low in back. Rob used a Jones resonator, made the mufflers. Shoulda took pictures...
https://www.youtube.com/watch?v=0ClrUs29qS0
It will be most fun if you have computer speakers with subwoofer. The car is not *that* loud - in the videos you can hear the birds in the background (they come with the neighborhood...)
Other than that... gas mileage is up a little probably due to fresh plugs and a little less exhaust restriction combining to convince the ECM to run a little leaner. The old plugs looked normal - some tan-to-brown ash, and a little gap spread (gapped out at .061to .065; I installed them at .060 100000 miles ago). The Magnecor wires appear to be holding up fine after ~100,000 miles although I have not bothered looking at them in the dark to check for coronas because I am not having any misfiring or other problems.
You sure you don't have that backward?
Glasspacks need length to work. If the scenario is having a 15" glasspack and then replacing it with a 30" glasspack, the longer glasspack will be quieter and probably deeper sounding. The 15 extra inches of glasspack is standing in for a piece of straightpipe here. More surface area for sound absorbtion - less sound.
If you mean a real resonator, then it's a different story. But I was thinking of something you might have put on your custom exhaust.
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
When I was researching components for the rest of my exhaust system(I've already installed headers and Magnaflow high flow cat 3" in/out) I was considering using a Magnaflow 4" or 6" round stainless muffler with an 18" long body, 24" OAL and then continuing with 2 1/2" stainless pipe mandrel bent to a Y with 2 - 2 1/4" in/out Dynomax super turbo mufflers with a shell lenthg of 20". Then new stainless tips. Anyone have any feedback on trying this system.
As far as the parts go, that's not too far off from my last dual exit system. I used 2.5" dynomax superturbos and a 3" dynomax race bullet muffler/resonator, which I still use now. All of my pipe was 3" though. I bet with 2.5" pipe back from the cat and the slightly smaller rear/muffler piping, it would be notabley quieter, and more tolerable than what I had, which would be about perfect.
I suspect there will be some drone still but barely. I thought those superturbos made a really nice sound from idle all the way to the top. For me, switching from the 3" dp to the headers made a huge difference in sound, not really any difference in volume, but I wasn't sure I liked it. I don't think it matters what muffler you use as far as that goes though.
Have measured and there is enough room for the 6" round muffler / resonator. Do you think I should use the 6" or 4" ???? Considering the same in / out dimensions what differences in sound would you expect from the 6 - 4".?
When I was researching components for the rest of my exhaust system(I've already installed headers and Magnaflow high flow cat 3" in/out) I was considering using a Magnaflow 4" or 6" round stainless muffler with an 18" long body, 24" OAL and then continuing with 2 1/2" stainless pipe mandrel bent to a Y with 2 - 2 1/4" in/out Dynomax super turbo mufflers with a shell length of 20". Then new stainless tips. Anyone have any feedback on trying this system.
it's similar to what I got, but will have to measure the mufflers for you and comment on composition - Rob made them, which was interesting. Used a combination of fiberglass and stainless steel packing.
For those of you who have not replaced your cat yet - another difference in my system is I used a Walker cat - stainless steel and somewhat bigger than the Magnaflow cat - also about $50 more - it is a little smaller than the factory (AC) cat. Frankly, if you have a factory cat and the case has not softened up on you from outer shell corrosion, I would Definitely Keep It. I looked into my factory cat - it uses one of the Corning (I worked for Corning) thin-wall high performance substrates. IF my case had not gone soft I'd have kept it. As for the rest of you if your cat is not sooted up and it is not making the o2 sensor throw codes, I'd keep it and save the $200. What to do if you are not sure - get a replacement gasket (same as fits the Walker) then take after you cut off the exhaust pipe take a look thru the old cat with a strong light on the other side - like a 60W shop lite, or point it toward a sunny window. IF you can see light thru it when you look straight thru you're fine. IF not then consider putting on a Walker (also a high performance substrate to meet factory specs).
More on my system - for some reason Rob made the "Y" more like a "T" in my system. I did not remember to suggest that he start with an elbow and cut a notch out of it for the inlet. The T is 2 1/2"; he opened the 2 1/4" pipes to 2 1/2" to connect each muffler to the T.
As for your resonator Rick I'd use the 6", definitely. Unless you also want to rip out the interior and put Dynamat on the floorboards (which I will do when the Dynamat from Club RSX that I ordered arrives). The 4" won't drone much but the resonation off the floorboards and trunk might get to you on long trips. The resonation is not at the tone of the muffler, rather it is at an annoying harmonic. Gibson makes a truck resonator I'm thinking about swapping in when I find the time/$.
Finally oh by the way Rick, I'd consider getting the Hooker Maximum Flow mufflers if you can get them for your design.
Finally oh by the way Rick, I'd consider getting the Hooker Maximum Flow mufflers if you can get them for your design. Albertj
I looked at the Gibson website and cannot seem to find a round muffler with the dimensions needed to use as an resonator. The maximum size I measured while under the car was 28" long x 7" round What P/N were you thinking of going with.?
Subject: Re: FAQ: The Exhaust Thread Tue Jul 14, 2009 12:36 am
The Gibson number I am thinking of is 420887 - it is a Race Superflow Muffler; Stainless Steel; 5 in. Case Dia.; 3 in. Inlet; 3 in. Outlet; L-20 in.;
This failing was planning to one of 2 other things:
Plan B is to get an OE stainless resonator from a wrecked Chevy Impala or GM and weld it in. It is similar size to the original Riv resonator. Undecided whether to get the resonator for the 6 or the 8 if I have to so this.
Plan C is to learn a whole heap more about resonator design and then spec one for Ron to build for me (the gold plated solution). I think the key would be to get the right dimensions for the center resonance chamber and build a muffler like the Gibson 789400S - it's a Helmholtz. Is not packed, rather just baffled/chambered. It is 8" not 7" diameter - but the design is interesting. . The muffler would have stock inlet/outlet pipe welded to louvered pipes and would be baffled about 1/3 2/3. The trick is to get the baffle plates the right distance apart for sound cancellation. I could pack the end chambers with a mix of fiberglass and stainless wool to control sound differently.
Subject: Re: FAQ: The Exhaust Thread Tue Jul 14, 2009 12:47 am
#1BearsFan wrote:
When you finally get that exhaust built.... audio/video please!
Second video is a driving sequence. Up a short hill (off camera, around a loop, then back past the camera. Maybe a little lame but the last ~15 seconds gets the point across and I suspect is what you all were interested in. The muffler cans are kinda big and hung low in back. Rob used a Jones resonator, made the mufflers. Shoulda took pictures of the fab work...
It will be most fun if you have computer speakers with subwoofer, the audio quality is pretty good (used a Nikon Coolpix S4). The car is not *that* loud - in the videos you can clearly hear the birds in the background. ..)
TonySmooth89 Aficionado
Name : Anthony Age : 35 Location : Florida Joined : 2007-11-14Post Count : 2410 Merit : 16
Subject: Re: FAQ: The Exhaust Thread Tue Jul 14, 2009 12:53 am
Sounds really good! A little louder than stock but keeps the same general tone. Definitely among the best 3800 exhausts i've heard.
Subject: Re: FAQ: The Exhaust Thread Tue Jul 14, 2009 10:44 am
My son said it's "distinctive, not obnoxious but you don't have to look to know it's Eleanor (my kids named the car shortly after I got it) driving up."
My spouse called me "Rice Boy" when she took her first good look at the exhaust. ("Rice Boy" = someone who thinks decal and trim upgrades along with noisemaker "screwdriver mods" will make a car with small displacement engine, usually Asian, run faster). See http://www.riceboypage.com/; it's a good LOL if this is the first time you've heard the expression. On Riceboypage.com, see cartoon #3 in "The Adventures of Rice Boy" section - 5th hotlink down the center column of the page for the joke about big muffler tips. She quit teasing me after driving it and noting the improved gas mileage numbers.
I admit I kind of miss the burble at idle, although I like the quiet rumble at idle. This exhaust with a downpipe upgrade, cam, rockers, and the Pontiac supercharger pulley - and maybe a standard black-and-tan interior, would have made a fine Wildcat or maybe even Yenko Riviera (see http://www.yenko.net/dealers/yenko.htm, http://www.corvettelegends.com/sunray.htm and http://en.wikipedia.org/wiki/Yenko_Chevrolet).
Gotta run
[it's similar to what I got, but will have to measure the mufflers for you and comment on composition - Rob made them, which was interesting. Used a combination of fiberglass and stainless steel packing. As for your resonator Rick I'd use the 6", definitely. Unless you also want to rip out the interior and put Dynamat on the floorboards (which I will do when the Dynamat from Club RSX that I ordered arrives). The 4" won't drone much but the resonation off the floorboards and trunk might get to you on long trips. The resonation is not at the tone of the muffler, rather it is at an annoying harmonic. Gibson makes a truck resonator I'm thinking about swapping in when I find the time/$. Finally oh by the way Rick, I'd consider getting the Hooker Maximum Flow mufflers if you can get them for your design. Albertj
Albert where is your source for Dynamat. I'm not familiar with Club RSX. And how much did you order and how much does it cost? Thanks for any info. Also, you mentioned increased gas mileage in another post. How much did you gain? Rick
MIleage: measured about 2 MPG. I think all that is happening is that I hit a 'sweet spot' - engine is running leaner (closer to stoich) but I am not pushing it (I burn premium gas, I cruise with a sense of purpose but am not a street racer by any means) so it's not knocking from the leaner burn and not backfiring (there's just enough backpressure to keep the gas in the cylinders). So I am making a solid 27+ (not quite 28) MPG at highway speed (hilly state and federal highways, PM me for speed and details) using cruise control.
Rob's car (a 2001 GP) backfires mildly when you rev it. My car does not, it does what you heard on the video. I do not think he is generating as much backpressure as he could use.
I love watching videos of Rivieras driving on the road. I like to see and hear these cars in action from the outside, probably because I rarely get to see it. Great videos, albertj!
Have taken several highway trips. On the technicals -flowing, tone, construction) Rob's exhaust crafting gets an A+. I'd like a quieter cruise, so I will put in Dynamat or some such first then maybe change out the resonator. The Club RSX Dynamat is backordered; I may cancel and buy this:
http://www.b-quiet.com/ultimate.html
We'll see.
Thanks for the Tip Albert, This stuff appears to be less expensive than Dynamat. I was looking for something to use in the near future. While doing your research is it less expensive and equally as effective? If you use this product please let us know what you think of it. * Which of their products are you thinking of using? Are you going to use a combination of their products, if so which ones?
Albert, Which of their products are you going to use and where. I notice they have different products apparently for different applications, but short of calling them for some guidance I'm not quite sure what to use where. Have you figured it out yet? Thanks Rick.
