| FAQ: Aftermarket Lowering Springs | |
+55matt270avian th3fr4nchi5e Sir Psycho Sexy bigdave Richouser Johnny5 joshuadalegrimes bmcd9179 stan al_roethlisberger Karma J. Chris Davis 69GSColorado charlieRobinson RidzRiv highwaywarrior Abaddon reboot13 flyineagle96 Eldo 97 park ave Tank BKRIV VJD2 abaucom Hometown Hero Sweepspear SToP 97rivsc parrot5254 joe's riv EatDirtFartDust Rickw deekster_caddy Mr.Riviera mak3 albertj No-Lift Buapo robotennis61 mountainrider 97rivman ewolfe0050 Jack the R turtleman 1998 Riv HirohataMerc Riv in Reno Jason AA T Riley racinfan jax95riv pwmin oldsman105 59 posters |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue Apr 09, 2013 12:36 pm | |
| - charlieRobinson wrote:
- Robo, that is not true.
Front springs are not compatible Rears ARE compatible. Measuring the length has little to do with it. It's the pigtail end that sits in the boot that is different.
Says, moog, CCS, Eaton Detroit, and the guys Scott linked to!
I'm not sure about that.We know that the top of the spring fits.If the upper strut mount has the same part number for 95 to 99 the top fits. As for the bottom,does anyone have an old front strut from a 96 and up kicking about that they can take a pic of so we can compare? | |
charlieRobinson Expert
Name : Charlie Age : 38 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3923 Merit : 31
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue Apr 30, 2013 12:33 pm | |
| Just got a set of those legendary relic Eibachs for $170 shipped! HELL YEAH! FINALLY!
YALL KNOW HOW STOKED I AM ON THIS! | |
69GSColorado Fanatic
Name : Jordon Joined : 2011-07-16 Post Count : 406 Merit : 29
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue Apr 30, 2013 1:41 pm | |
| Is it for real this time? lol | |
highwaywarrior Fanatic
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue Apr 30, 2013 1:50 pm | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue Apr 30, 2013 1:55 pm | |
| So far, yes. I even contacted the seller and said, "YO! ARE THESE FOR REAL AVAILABLE AND READY TO SHIP?'
seller said, "YES!"
So, we'll see! I still have doubt! But damn, this is my 3rd time throwing money at these springs. Hoping for a slam dunk on this one. | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue Apr 30, 2013 2:20 pm | |
| - robotennis61 wrote:
- the strut mount 902998 is the part # for the 95 thru 99 Riviera.
pics
The spring perch that the spring sits in measures 27 inches in circumferance. If the series 2 strut perch measures 27" in circumferance too,then the spring will fit all years. Of course the strut/spring assembly is off the car and not compressed.So if one would want to measure their car all one would have to do is jack the front end up and measure the length of the assembly. The spring measures 11 inches.If the OEM spring measures 12 inches then the CSS spring is in fact one inch shorter. All measurments are of the strut/spring assembled of course. Until someone proves different,there should be no confusion now.The 95 thru 99 springs are identical and interchangable.Front and rear.
That part # is for the REAR strut mounts, which are the same on 95-99 riv's. The FRONT mounts are different 95-97 are moog K5321 and 98-99 are K5337. Look them up. 98/99 springs (and the eibach's) are not compatible with 95-97 struts and associated hardware. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue Apr 30, 2013 2:30 pm | |
| TOLD YOU, ROBO! Young bucks, FTW. Thanks, Matt! | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Wed May 01, 2013 8:33 am | |
| I got shipping confirmation this morning that the Eibach springs are being sent from BC Canada and should be here this time next week.
I still can't believe it. They have to be the wrong springs... they just have to be.. | |
al_roethlisberger Junkie
| Subject: Re: FAQ: Aftermarket Lowering Springs Wed May 01, 2013 10:54 am | |
| Will be very curious how the Eibachs alter the height of the car, as well as ride too of course. Hopefully they won't turn the car into a "skateboard" that lets you feel every rut in the road Let us know. Before/after install pics that show the height/wheel-opening will be very helpful. Good luck! | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Wed May 01, 2013 11:35 am | |
| Eibach's are 1.5"-2.0" drop. These springs have been installed on other Rivs, including Mr.Riviera's, who stated a 1.8" drop. They are a progressive/dual rate spring that start out very close to stock ride, firming up to a higher rate as the springs are compressed a certain amount. Firmer springs are required with lower springs, so the suspension doesn't bottom out. Read through this thread for more details on these springs. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Wed May 01, 2013 11:38 am | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Wed May 01, 2013 11:45 am | |
| Now THAT'S a good deal, and from Canada too! So glad to see you didn't get raped paying $300+ for these springs. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Wed May 01, 2013 11:49 am | |
| I think they are worth $300 so I'd happily bend over for them.. Let's just hope they are the real springs! I will report back next week once they get here.
| Subject: Re: FAQ: Aftermarket Lowering Springs Thu May 02, 2013 5:52 pm | |
| Did the Eibachs come in?!!! | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Thu May 02, 2013 6:02 pm | |
| Not yet. They are 'sposed to be here Wednesday. But I have an extra set of rears. One of the few extra parts I have I am willing to separate with. LOL.
| Subject: Re: FAQ: Aftermarket Lowering Springs Thu May 02, 2013 6:04 pm | |
| Good luck! My fingers are crossed for you! | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Thu May 02, 2013 6:13 pm | |
| - 69GSColorado wrote:
- Good luck! My fingers are crossed for you!
Dude, thank you! I consider the STS Strutbar to be a rare purple item. These Eibach springs are super relic orange status. Still don't believe it's gonna happen but I finally got a UPS tracking number after paying someone for these. Let's see what happens! | |
| Subject: temp Thu May 02, 2013 6:26 pm | |
| Haha yeah I bought the Caddy STB last year, and plan on installing it this summer. I remember how hard it was to get ahold of. I can only imagine trying to locate a set of Eibachs. | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue May 07, 2013 2:14 pm | |
| I am going to attempt to plastidip my springs white. Anyone think this might mess something up? It might add 1/2 to 1 mm to their height? Shouldn't be a big deal, right?
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue May 07, 2013 2:35 pm | |
| No big deal, but don't be surprised if the dip flakes off after flexing a little bit. I think most progressive rate springs work on a principle that some of the coils bind before the rate changes. When this happens, your coating could scratch off. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue May 07, 2013 2:37 pm | |
| That's why I am going with plastidip, so it doesnt flake. It should move right with the springs. That's the idea, at least. Now, red or white... hmmmm...
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue May 07, 2013 3:06 pm | |
| I think it should work then. If you change your mind on color, just peel off and reapply! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue May 07, 2013 3:20 pm | |
| Aren't the Eibachs dipped in black already? I know the ones on my T-bird were.... AND, unless you're building a show car, what's the point? | |
| Subject: Re: FAQ: Aftermarket Lowering Springs Tue May 07, 2013 3:46 pm | |
| The Eibachs are probably painted/powder coated. Plasti-Dip is a coating of rubber that will peel off with some help.
I think the point is, from what I've heard, once you plasti-dip something, you must then dip as many other things on your car as possible. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: Aftermarket Lowering Springs | |
