| TRANSMISSION problems HELP PLEASE............ | |
+6Jason SC95Riv Ridin-Rivi TonySmooth89 deekster_caddy T Riley 10 posters |
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Thu May 15, 2008 9:57 am | |
| Wow, now THAT'S a warranty. Congrats! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
BillBoost37 Junkie
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Thu May 15, 2008 10:55 am | |
| That is one nice warranty. How many miles do you drive per year? | |
T Riley Guru
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Thu May 15, 2008 3:37 pm | |
| - BillBoost37 wrote:
- That is one nice warranty. How many miles do you drive per year?
no more than 10k...... but idk.... | |
T Riley Guru
BillBoost37 Junkie
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Fri May 16, 2008 7:26 am | |
| Hahahaha piggy back ride is the way to save on fuel costs.
My car had too many last year. Glad to see it's off to get fixed up. That warranty is perfect with you putting on 10K a year. | |
BKRIV Enthusiast
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Fri May 16, 2008 11:16 pm | |
| The 4t65e transmission is alot better than the earlier 4t60 but still prone to many of the same problems any front drive would encounter. ...before you do anything scan for a code before they pull the tranny or crack the case it could be as simple as a solenoid which can be fixed without pulling the tranny. but there are sealing rings and pistons that wear out just like in an engine, specify that your builder use only a Transtar master rebuild kit with a Transtec seal kit if you need a converter I suggest Dacco. It sounds like you trust your rebuilder but I can make some calls and help you locate a good one in your area if needed... thats probably the most important part of any rebuild...good luck! | |
T Riley Guru
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Fri May 16, 2008 11:47 pm | |
| - BKRIV wrote:
- The 4t65e transmission is alot better than the earlier 4t60 but still prone to many of the same problems any front drive would encounter. ...before you do anything scan for a code before they pull the tranny or crack the case it could be as simple as a solenoid which can be fixed without pulling the tranny. but there are sealing rings and pistons that wear out just like in an engine, specify that your builder use only a Transtar master rebuild kit with a Transtec seal kit if you need a converter I suggest Dacco. It sounds like you trust your rebuilder but I can make some calls and help you locate a good one in your area if needed... thats probably the most important part of any rebuild...good luck!
yah i found parts of my differential in my pan........... the guy will do everything perfect im not too worried...... im kinda mad he didn't park it inside over the weekend.... but it does look cool in front of his shop..... maybe if i didn't have performance sttickers on it. and racing stuff...... ugh oh well | |
T Riley Guru
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Thu May 22, 2008 12:44 am | |
| Riv is only a day or two from being BACK IN ACTION!!!!!!!!! i will have it in my possession BY friday........ sOOOOOO basically the :planetary: fried........ just went KABOOOM | |
| Subject: Re: TRANSMISSION problems HELP PLEASE............ Thu May 22, 2008 4:41 pm | |
| Hmmm too many burnouts? | |
| Subject: Re: TRANSMISSION problems HELP PLEASE............ | |
