| Subject: Re: Write-Up: XP Cam & Valvetrain Install Fri Jul 25, 2008 10:02 am | |
| whoa! What kind of header wrap is that? It looks like a polished stock heat shield. | |
BillBoost37 Junkie
| Subject: Re: Write-Up: XP Cam & Valvetrain Install Fri Jul 25, 2008 10:33 am | |
| Derek,...it's pre wrap. - turtleman wrote:
- The above picture is after I cleaned it up.
| Subject: Re: Write-Up: XP Cam & Valvetrain Install Fri Jul 25, 2008 11:37 am | |
| installed definitelly looks a lot fatter if nothing else. I did notice that a little while after baking, the outside surface of it was room temperature but the inner pipe and flanges would burn my fingers. That can't be bad. | |
Chicken Aficionado
| Subject: Re: Write-Up: XP Cam & Valvetrain Install Fri Jul 25, 2008 12:57 pm | |
T Riley Guru
| Subject: Re: Write-Up: XP Cam & Valvetrain Install Wed Jul 30, 2008 12:08 pm | |
| Subject: Re: Write-Up: XP Cam & Valvetrain Install Wed Jul 30, 2008 12:13 pm | |
| - 98riviera98 wrote:
- how is she running?
85-90 degrees out with varying but generally high humidity = not terribly impressive. When its 70 or cooler, is when you'll see if you look into my car and a bunch of my direction from the cars around | |
BillBoost37 Junkie
| Subject: Re: Write-Up: XP Cam & Valvetrain Install Thu Jul 31, 2008 7:46 am | |
| - turtleman wrote:
- a bunch of my direction from the cars around
I love it.. Roll past a converitble and give it just enough to whine. | |
| Subject: Re: Write-Up: XP Cam & Valvetrain Install | |
