 crazy bad coolant leak
6spd
8 posters
6spd
crazy bad coolant leak Empty
PostSubject: crazy bad coolant leak   crazy bad coolant leak EmptyMon Apr 07, 2008 4:24 pm
Found this site on RegalGS.org. Hoping someone can help me out. There are 2 black metal coolant lines under the alternator that I assume go to the heater core. I took the alternator off and the bottom one looks like it is leaking a ton of coolant! I can't see the leak itself though. Can anyone tell me what these lines are? and where I can get them? Or point me in the right direction of the correct place to look for parts like this. GM does not make them anymore. I've been looking for hours now.
Thanks in advance for any help!
James
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyMon Apr 07, 2008 4:46 pm
can you take a picture of were its leaking i can help you with this.
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyMon Apr 07, 2008 5:09 pm
Those are for your heater hoses. They are sealed with o-rings. By under the alternator, do you mean off the back or closer to the water pump and intake manifold? There are plastic elbows in front of the alt., and metal brackets behind the alt. All are sealed up by o-rings, so no harm in removing them and checking the o-rings.
I don't have part numbers, but it sounds like you don't know what you need yet.
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyMon Apr 07, 2008 5:13 pm
first, welcome to the site! what year riv do you have? and is it the supercharged motor?
i think the tensioner has coolant passages, and there is a coolant elbo under the snout of the bower that sometimes cracks. as for the actual rubber hoses for the heater core you may be better off buying hose and cutting it yourself b/c local stores will probably not carry any pre bent.
have you checked gmpartsdirect.com ?
or autozone ?
crazy bad coolant leak Dsc_0110
6spd
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyWed Apr 09, 2008 11:44 am
Its a Supercharged 95 which reminds me I need to buy a supercharger rebuild kit too.
It is those 2 metal pipes that are sealed with O rings. I wonder if I just need to replace the O rings? I should have taken some pictures. I will try and get some up.
Thanks very much for the help!!!!!!!!!
Edit: Its apparently not the orings.
6spd
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyThu Apr 10, 2008 2:17 pm
Hopefully this pic does the trick. I need help finding these two metal pipes.
The GM part numbers are 24503167 and 24500378. I think I can find the bottom pipe.
crazy bad coolant leak Coolantlines
Sag
Sag
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyFri Apr 11, 2008 11:02 am
If it is not the o ring check the w/p i wish you it's not it it is a pain to remove. good luck
6spd
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyFri Apr 11, 2008 11:32 pm
There is a hole in the line. I need to find another one.
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyFri Apr 11, 2008 11:44 pm
GM Parts Direct:
Item Number........MSRP...........Price
24503167............$21.14.........$12.17
PIPE ASM-
24500378............$21.11.........$10.67
PIPE
6spd
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyThu Apr 17, 2008 7:46 pm
I did a search on GM parts direct and came up with nothing. I sent them an email and a week later they still have not replied. How did you find those?
etosino2009
etosino2009
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyWed May 21, 2008 5:11 pm
i kind of have the same problem. i went to autzone today and told them i have a coolant leak that appears to be from the flush T and that maybe one of the hoses connected to it needs to be replaced which i can see it dripping from there sometimes. then he looked at the water pump pulley and told me it is loose and that i might need a new water pump which could be also causing the problem. but i have no idea how that could cause it?
BillBoost37
Merit : 26
PostSubject: Re: crazy bad coolant leak   crazy bad coolant leak EmptyThu May 22, 2008 8:58 am
Water pumps have a built in failure point called a weep hole. On our cars it is nearly impossible to look at and see it weeping coolant.
Your issue coudl be the hoses, or the waterpump.
» Coolant leak
» Radiator / Coolant Leaks
» Got A Coolant Leak! HELP!
» Rear coolant leak.
» help crazy idle
