BoattailBob Fanatic
Age : 57 Location : Bay Area, California Joined : 2007-06-05 Post Count : 268 Merit : 0
| Subject: Steering problems Fri Jul 11, 2008 5:54 pm | |
| I'll try to explain this the best I can. Its an intermittent problem so I'm having a tough time pinning it down. This usually happens when I first start driving and sounds almost the same as when the wheel is turned to the extreme right or left only its louder and happens no matter how much I turn the wheel. I also feel tension in the wheel so I'm suspecting my power steering pump, although the fluid is fine and no leaks. Or it could be a belt or pulley? The sound is pretty loud and almost sounds like a belt rubbing but they look fine. Could the tensioner pulley be causing this? The problem goes away usually within 5 min. New power steering pump? Any ideas? TIA | |
| Subject: Re: Steering problems Fri Jul 11, 2008 11:53 pm | |
| there was a service bulletin about the PS hoses - but I don't have it. Might want to ask a dealer.
BoattailBob Fanatic
| Subject: Re: Steering problems Sun Jul 20, 2008 12:58 pm | |
| Still haven't fixed this but had my wife turn the wheel while I checked around yesterday. My power steering pulley is wobbling when the wheel is turned, binding up the belt. Will investigate more today. | |
| Subject: Re: Steering problems | |
