NO 4 EVR Addict
| Subject: Changing PCV valve Fri Mar 09, 2007 9:45 pm | |
| My roommate alerted me to a usually cheap and easy part to replace, but also an important part to replace, the PCV valve. He is going to change his out on his truck and said we should check mine. Mine was pretty dirty (just did top engine clean) and it smelled of exhaust/gas. Should I change it? And when I say dirty, it was dirty from a dark liquid, not dry, is that normal? Anyone know part # by any chance? Thanks! | |
| Subject: Re: Changing PCV valve Sat Mar 10, 2007 11:01 am | |
| As long as the valve is not frozen with sludge or grit, it should still work all right. It just needs to be able to move to open/close. If you're concerned, should be an inexpensive part, and very easy to replace.
When you open up that plate, watch the spring! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
