| Custom STB..anyone in Chicago area?? | |
BoattailBob Fanatic
Age : 57 Location : Bay Area, California Joined : 2007-06-05 Post Count : 268 Merit : 0
| Subject: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 11:52 am | |
| Has anyone tried the stb brackets from Donald Rome @ http://www.drcustomparts.com/HomePage.htm ?? They fit the regal so I'm thinking they may also work for the riv. I emailed him and he said he'd be willing to fab one if it didn't fit. He would need a riv to check thought. Anyone in the Chicago area interested in this? Ive never been happy with the way my STS bar fit and it looks like these brackets would be a better solution. | |
patillac Member
Name : Pat Age : 36 Location : Mentor ohio Joined : 2008-07-13 Post Count : 69 Merit : 1
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 12:27 pm | |
| if he can make you one would you sell the old sts one? | |
BoattailBob Fanatic
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 1:09 pm | |
| I would but I had to bend the tabs and open up the holes to fit onto my '97. It never was a good fit and needed about 4 washers to clear the brake fluid reservoir. Ill give it to you if you want it and can pay the shipping. | |
patillac Member
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 2:08 pm | |
| thanks that works for me just pm me when you are you are ready to get rid of it | |
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 4:34 pm | |
| I don't believe W body is a direct fit, no. And the problem with someone making a bar to fit our Rivs specifically, is that all our years seem to have slightly different fitments, based on the installation reports of the STS bar. Mine fit perfectly, OTHER than having to shim it with a couple washers. Holes were perfect. Some others have a problem with the bar being too high, and pushing their hoods up out of alignment. | |
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 4:45 pm | |
| Our suspension is WIIIIIDER than a W Body. Stuff made for the G Body fits though... (STS) | |
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 5:37 pm | |
| Here's his issue though. I'd also prefer a perfect fit, but the STS bar will do for me. - BoattailBob wrote:
...........Ive never been happy with the way my STS bar fit and it looks like these brackets would be a better solution. | |
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 9:48 pm | |
| Oh okay. I missed that part. Is it only the '98 and '99 that have the easy bolt-down option? '97 had studs too?
Those do look like nice ones. You could always go to grainger and get longer eye-bolts if it weren't long enough... | |
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 11:08 pm | |
| Also a number of guys had bolt holes that were way off and some modifications or fabrication had to be done to install. | |
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 11:11 pm | |
| oops, I mixed up. I meant to say that about the BMR STB's in that other STB thread... | |
BoattailBob Fanatic
| Subject: Re: Custom STB..anyone in Chicago area?? Wed Jul 23, 2008 11:55 pm | |
| [quote="1998 Riv"]Here's his issue though. I'd also prefer a perfect fit, but the STS bar will do for me.
The problem with mine was it was only being held on by about 2 threads on each bolt after stacking all the washers up. | |
| Subject: Re: Custom STB..anyone in Chicago area?? Thu Jul 24, 2008 12:17 am | |
| You're supposed to use longer bolts, not the stock ones. Or does the 97 have studs coming up from underneath? I don't recall what year that changed. | |
BoattailBob Fanatic
| Subject: Re: Custom STB..anyone in Chicago area?? Thu Jul 24, 2008 1:56 am | |
| They come from underneath | |
| Subject: Re: Custom STB..anyone in Chicago area?? Thu Jul 24, 2008 9:48 am | |
| Is it possible to replace them? I wouldn't care for the setup either, if only a few threads were available. | |
| Subject: Re: Custom STB..anyone in Chicago area?? Thu Jul 24, 2008 11:29 am | |
| Yeah, that's why the '95-'97 guys had to mangle the ends and slot the holes on the STS bar. For the '98-'99 it's a nice clean solution with longer bolts... So a custom made job should be really easy to do, and fit better. See if he'll make a hundred or so! | |
BoattailBob Fanatic
| Subject: Re: Custom STB..anyone in Chicago area?? Thu Jul 24, 2008 12:17 pm | |
| Im sure he would if he could sell em. Unfortunately Im in CA and he's in Chicago so it may not be as easy. Im sure we could figure something out. I may buy the ones for the regal and see how off they are. | |
whit2285 Enthusiast
Name : Mike Age : 49 Location : Illinois Joined : 2007-12-20 Post Count : 127 Merit : 3
| Subject: Re: Custom STB..anyone in Chicago area?? Fri Jul 25, 2008 11:54 am | |
| I'm just south of Chicago would 96 and 97 be the same | |
BoattailBob Fanatic
| Subject: Re: Custom STB..anyone in Chicago area?? Fri Jul 25, 2008 1:09 pm | |
| I believe 95-97 are the same (someone correct me if I'm wrong). Don Rome's shop is located at 4119 Luckie Court Zion, Illinois 60099. If you're at all close it may be worth the trip. Thanks! | |
whit2285 Enthusiast
| Subject: Re: Custom STB..anyone in Chicago area?? Fri Jul 25, 2008 4:57 pm | |
| im about 1.5 hrs away any one closer | |
| Subject: Re: Custom STB..anyone in Chicago area?? Fri Jul 25, 2008 5:10 pm | |
| The '95-'99 are all the same distance from tower to tower I believe, but the method of attachment needs to be different because the older ones ('95-'97) have studs coming up from underneath, the '98 and '99 have bolts down from the top. | |
Chicken Aficionado
| Subject: Re: Custom STB..anyone in Chicago area?? Fri Jul 25, 2008 6:27 pm | |
| Do it for the team, Whit2285!!! | |
| Subject: Re: Custom STB..anyone in Chicago area?? | |
