| Need 1996 Riv Bin File | |
+10Bowersk 54_nailhead L67 T Riley DEMonte1997 Mr.Riviera ericde BillBoost37 AA TURBO87 14 posters |
TURBO87 Member
Name : Dave Age : 58 Location : Sarasota Fl Joined : 2007-10-05 Post Count : 52 Merit : 0
| Subject: Need 1996 Riv Bin File Sat Oct 13, 2007 6:59 pm | |
| Now that I know I can get a powertuner for my 96 riv is there someplace I might find some bin files or do I start from stock and play with it? I was hoping the spark and fuel cal files are the same in the later rivs and that I could copy those. Even tuning TR's with FAST boxs it was nice to start with a program that was close.
Dave | |
| Subject: Re: Need 1996 Riv Bin File Sat Oct 13, 2007 7:06 pm | |
| When you buy the PowrTuner, DHP should send you a starter BIN 1.5. This has some improvements, or you can just start from stock. When you get your tuner, I can send you exported data that you can copy/paste into your tables. Let me know what you need. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
TURBO87 Member
| Subject: Re: Need 1996 Riv Bin File Sat Oct 13, 2007 7:53 pm | |
- When you buy the PowrTuner, DHP should send you a starter BIN 1.5. This has some improvements, or you can just start from stock. When you get your tuner, I can send you exported data that you can copy/paste into your tables. Let me know what you need.
Thanks, I look forward to playin with it. I seen some screen shots and it looks kinda like the early cal com DFI software. Dave | |
BillBoost37 Junkie
| Subject: 1996 Riv Bin file Thu Mar 05, 2009 6:30 pm | |
| Sorry t link..but I finally got the DHP 1.5 file I had promised to a couple folks
http://www.bonnevillepro.com/forums/viewtopic.php?f=192&t=8803&p=110048#p110048 | |
ericde Enthusiast
| Subject: Need a 1996 PCM bin file Tue May 26, 2009 7:11 pm | |
| does anyone have a bin file for a stock 96 riviera for performance shifts an turn on fans for 180 sec after turn off? pretty much a dhp 1.0 if so please let me know | |
| Subject: Re: Need 1996 Riv Bin File Tue May 26, 2009 7:24 pm | |
| you'd have to ask tony or devin for one. devin could maybe send you my bin file. it's not stock, but not far from it. i changed shift points, few code deletes, speed limiter removed, torque management update and fan turn on temps changed.
the riv's will not run the fans after the car is off like W-bodys do.
do you have a dhp tuner to write to the pcm? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
DEMonte1997 Aficionado
| Subject: Re: Need 1996 Riv Bin File Sun Jul 19, 2009 2:44 pm | |
| I might be in the market for one of these .bins too if anyone can pass it along. My email is: blktourer@gmail.com I have a Powrtuner. | |
T Riley Guru
| Subject: 1996 DHP tuning PCM Sat May 29, 2010 1:40 pm | |
| Fellow member on this board needs his ride tuned.. its a 96, I recall finding where to get the correct .BIN for a r96 riv.. but i can't find this thread/info anywhere.. Link/help please "mr riviera,dreww, whoever!!!" KTHX GUIZ!! | |
| Subject: Re: Need 1996 Riv Bin File Sat May 29, 2010 4:05 pm | |
| i can send you my bin file to start with. what's ur email? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
L67 Aficionado
| Subject: Re: Need 1996 Riv Bin File Sat May 29, 2010 7:04 pm | |
T Riley Guru
| Subject: Re: Need 1996 Riv Bin File Sat May 29, 2010 8:18 pm | |
| - Mr.Riviera wrote:
- i can send you my bin file to start with.
what's ur email? holmtransamws6@yahoo.com thanks mang | |
| Subject: Re: Need 1996 Riv Bin File Sat May 29, 2010 10:32 pm | |
| email sent _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
T Riley Guru
| Subject: Re: Need 1996 Riv Bin File Sat May 29, 2010 10:36 pm | |
| - Mr.Riviera wrote:
- email sent
sweeeet just got it! Is this the DHP 1.0 file plus some adjustments from you? | |
| Subject: Re: Need 1996 Riv Bin File Sat May 29, 2010 10:45 pm | |
| this is my custom tune from like 8mo ago. it's not what i'm using now, but it should be a good start for a slightly moddified 96. I believe it did start out as a 1.5 tune from a vender then has the trans setting adjusted, little tweaks like tq mngt and cooling. VE tune, table modifier, extra fuel etc. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
54_nailhead Enthusiast
Name : Luke Age : 47 Location : Waconia, MN Joined : 2007-06-15 Post Count : 126 Merit : 3
| Subject: Re: Need 1996 Riv Bin File Mon May 31, 2010 12:50 pm | |
| I love this place, thanks for helping me get my 96 tuned guys. | |
| Subject: Re: Need 1996 Riv Bin File Mon May 31, 2010 1:33 pm | |
| if you havent already done so, you may want to get the adjustable trans modulator since our pcms cant adjust trans pressure _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
T Riley Guru
| Subject: Re: Need 1996 Riv Bin File Mon May 31, 2010 1:39 pm | |
| - Mr.Riviera wrote:
- this is my custom tune from like 8mo ago. it's not what i'm using now, but it should be a good start for a slightly moddified 96.
I believe it did start out as a 1.5 tune from a vender then has the trans setting adjusted, little tweaks like tq mngt and cooling. VE tune, table modifier, extra fuel etc. when you upload the .bin to your pcm does DHP ask you anything wierd? I thought i heard that some DHP software was unable to tune 96's? | |
| Subject: Re: Need 1996 Riv Bin File Mon May 31, 2010 2:01 pm | |
| Both tony and i have been able to upload MANY tunes to 96's. I do seem to remmember there being some hickup the very first time the DHP reads the 96 or does a full write. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
Bowersk Enthusiast
Name : Bowers Age : 44 Location : Okawville, Il Joined : 2011-01-19 Post Count : 219 Merit : 7
| Subject: Anyone have a stock 96 .bin? (16.4 LTFT problem STILL) Thu Apr 19, 2012 10:42 pm | |
| I'm still fighting this 16.4 LTFT problem. Now its to the point where its around 8/9 at idle, but as soon as I give it any gas it jumps up to 16.4. I'm tired of messing with this f'n car and tired of smelling like fuel. I'm going to try a stock .bin and if that doesn't change anything I'm going to go with new injectors. No vacuum leaks anywhere although I do question how I have the vacuum lines ran. O2 sensor works fine, only thing I can imagine could POSSIBLY be wrong there is the extension is messing with something. I'm thinking removing the CAT and rear 02 was a mistake as well. | |
| Subject: Re: Need 1996 Riv Bin File Fri Apr 20, 2012 7:51 am | |
| Can you send me your current MAF table? Just curious.
I have a new email address, so PM me for that.
Thanks -Derek | |
whit2285 Enthusiast
Name : Mike Age : 49 Location : Illinois Joined : 2007-12-20 Post Count : 127 Merit : 3
| Subject: Re: Need 1996 Riv Bin File Fri Apr 20, 2012 11:54 am | |
| Just curious what bin are you using now
Bowersk Enthusiast
| Subject: Re: Need 1996 Riv Bin File Fri Apr 20, 2012 12:14 pm | |
| Using the 1.5 bin as a base with my personal modifications to it. Idle rpm and such. Haven't touched anything other than the MAF table to account for the LQ4 MAF because of the LTFT issue. I over wrote my stock tune before even knowing what I was doing. I've returned everything to stock using DHP but I'm not sure I trust that they are actually the stock settings. I was just wanting to compare. | |
whit2285 Enthusiast
| Subject: Re: Need 1996 Riv Bin File Fri Apr 20, 2012 12:19 pm | |
| Ok..I understand now. If you don't get a stock table pm me your email., I have mine but I would be able to get it to you til Sunday evening.. | |
69GSColorado Fanatic
Name : Jordon Joined : 2011-07-16 Post Count : 406 Merit : 29
| Subject: Re: Need 1996 Riv Bin File Tue Nov 20, 2012 11:53 pm | |
| Does anybody have a copy of the 1996 Riviera DHP 1.5 Bin they would be willing to send me? I've tried registering at the Bonneville Pro forums and the DHP forums weeks ago and I'm not receiving anything back.
My email is jordonshultz@gmail.com. Thanks! | |
Bowersk Enthusiast
| Subject: Re: Need 1996 Riv Bin File Tue Nov 27, 2012 8:31 am | |
| To be honest, there isnt much for the 96 that 1.5 bin file is good for. What worked for me is just starting with stock and using Jerry's Tuning notebook which I sent you. If you have questions about any parameter in particular just ask here.
Sitting here just thinking about it, I think all that bin does is things like max speed, fuel injector cut outs, idle rpm and stuff like that which I just tuned manually in the stock bin. For a 96 there really isnt a whole lot of options there to change so its pretty easy to tell what you wanna change and what not. | |
| Subject: Re: Need 1996 Riv Bin File | |
