| Write Up: Transmission Fluid & Filter Change | |
+43IFallsRon Tajis rivierafrenchboy rk0ehn robotennis61 werdstrave manofmany charlieRobinson BMD dtrumbo DEMonte1997 BlownRiv BKRIV Jason L67 Bawb2u playa LARRY70GS moldymac beninohio BatMobile Ash flyineagle96 albertj VJD2 Eldo Cam Rickw Abaddon Mr.Riviera 96RIVMANN ibmoses 98riv captshiner deekster_caddy lionfish SpaceBar Buapo dreww turtleman pwmin AA SoCal Riv 47 posters |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri May 21, 2010 8:07 pm | |
| Now I know why they only say to add 1%. It's made primarily for hydraulic systems, and it reduces friction. Not something I would recommend putting in an automatic transmission, with all those clutches...
If you wanted to try an additive, I'd use either TransX or Lucas. | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri May 21, 2010 9:20 pm | |
| I use Dexron VI. No need for additives that I'm aware. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri May 21, 2010 9:24 pm | |
| - Eldo wrote:
- Now I know why they only say to add 1%.
If you wanted to try an additive, I'd use either TransX or Lucas. Where did you do the research regarding friction reduction.? Just curious. I Know that's much different than friction modifier, and I agree with the use of TransX based on the amount of usage he has out of this car since Trans overhaul. Never had TransX hurt anything, only help. But I will go back to my previous 3 posts. Drop the fluid and change the filter, gasket and fluid. I don't care how few miles it has on it. Then take the car on a nice long, and i mean about a 100 mile or longer ride, enjoy a Sunday cruising the country side and see how it performs before condemning the Transmission. Hell, the fuel system needs to be run and new fuel put in it as well. If you don't have the time to it, give the car to someone you trust and have them run it by driving normal and giving a couple of wide open throttles spurts after warm up to clear ir out and get things circulated. | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri May 21, 2010 10:18 pm | |
| - Rickw wrote:
It's made primarily for hydraulic systems, and it reduces friction. Not something I would recommend putting in an automatic transmission, with all those clutches... If you wanted to try an additive, I'd use either TransX or Lucas. Where did you do the research regarding friction reduction.? Just curious. I Know that's much different than friction modifier, and I agree with the use of TransX based on the amount of usage he has out of this car since Trans overhaul.Never had TransX hurt anything, only help.
...Then take the car on a nice long, and i mean about a 100 mile or longer ride, enjoy a Sunday cruising the country side and see how it performs before condemning the Transmission.
I simply Googled HydraMaxx and went to their site. Yes, we agree on TransX. As far as 'exercising' the tranny, I think I'd actually recommend some serious urban driving. The cruising will warm up the fluid, but all those fresh friction surfaces need to be used by shifting up & down... | |
VJD2 Fanatic
Name : Vinny Location : Connecticut Joined : 2010-02-21 Post Count : 310 Merit : 5
| Subject: Re: Write Up: Transmission Fluid & Filter Change Wed Jun 23, 2010 2:14 pm | |
| Does any of the usual auto stores provide a kit with a good filter and gasket combo. (autozone, napa, advance, etc?) I read that cork is a no no and something about the inside of the filter? No paper or something?
I need to change the fluid asap, it looks like a light brown now. Nasty. | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Wed Jun 23, 2010 2:21 pm | |
| - VJD2 wrote:
- Does any of the usual auto stores provide a kit with a good filter and gasket combo. (autozone, napa, advance, etc?) I read that cork is a no no and something about the inside of the filter? No paper or something?
I need to change the fluid asap, it looks like a light brown now. Nasty. most do. If you want to shop around look at rockauto.com on line then decide. If not, just go to NAPA - it won't be cheapest (if they give you a choice don't get the cheapest one) but it will work fine. Albertj | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Wed Jun 23, 2010 6:19 pm | |
| NAPA offers the metal gasket that is sandwiched between rubber. Also, Get their NAPA GOLD Filter, it is just as good, if not better than factory. That's what i have been using. And the gasket is a re-usable gasket. Just like the OEM gasket and is cheaper, about $12.00, that's what i used recently. I also got a drain plug from them. You will have to drill a hole in the lowest portion of the pan and install the kit they offer, but it makes it real easy to change the oil in the future. The Drain plug Kit was about $10.00. I figure, i will drain the fluid now once per year after having drained, installed a new filter and drain plug. Because i only drive about 8,000 miles a year, I'll do a fluid change once in the Fall (with the drain plug it takes about 7.5 to 8 qts ) and then change the fluid and filter every other Fall. With the better gasket, all you have to do is wipe it clean and re-install it. With my mileage, I'll be getting a Trans Fluid change every other year and the same with the filter. You can adjust frequency depending on the amount of miles your driving annually. Rick | |
flyineagle96 Junkie
| Subject: Re: Write Up: Transmission Fluid & Filter Change Wed Jun 23, 2010 9:30 pm | |
| Very good,that's what I've been doing, to my cars.Flush trains fluid every year,fluid + filter every other.I was pulling off a trains line,starting her and letting her pee.Thanks for the plug info.That"s how i will be draining her now.Well worth the money,much nicer. SWEET | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Wed Jun 23, 2010 9:45 pm | |
| - Rickw wrote:
I also got a drain plug kit from them. You will have to drill a hole in the lowest portion of the pan and install the kit they offer, but it makes it real easy to change the oil in the future.
I always do the same thing to my cars, the first time I change the fluid/filter... Just don't forget the hole-saw!
VJD2 Fanatic
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 1:47 pm | |
| Cool, thanks for the tips guys. I appreciate the info. Off to NAPA!
Rick, that is a great mod! That would make changing out the fluid so much easier!
James, I'm a little leary of letting the fluid drain like that. Would there be any damage if things ran dry with the car running? | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 2:05 pm | |
| Only caveat to the drain plug is, you can't fit a new filter through the hole!
You can run the car and use the lines to pump out the old fluid, as long as your intake line is sucking in the new fluid. Pumps don't like to operate dry, so be sure you use both lines if you try this. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 2:21 pm | |
| Nice thing about the drain plug is that you can get most of the pan's fluid out, which is generally enough for an annual thing, and when you DO drop the pan it's much much less messy. | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 2:26 pm | |
| True, can't much argue with that. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 2:56 pm | |
| - deekster_caddy wrote:
- Nice thing about the drain plug is that you can get most of the pan's fluid out, which is generally enough for an annual thing, and when you DO drop the pan it's much much less messy.
Right, which makes it a lot more likely that you will change it more often... | |
flyineagle96 Junkie
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 6:26 pm | |
| I've done it to my cars for years, never had any problems.The fluid runs out quickly,shut down quick,usually i ad back, about 8 quarts...Not completely empty i no, but works for me.Every time i refill i use two bottles of Lucas.the rest high pres.fluid, like B&N. | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 6:34 pm | |
| After you disconnect the line to pump out the fluid and reconnect it - do you then drop the pan to replace the filter like the rest of us? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
flyineagle96 Junkie
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 10:19 pm | |
| When i change the filter; i drain the trans, from loosing the pan bolts!! Now when i do it, i will loosen the drain plug. | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 10:51 pm | |
| - flyineagle96 wrote:
- When i change the filter; i drain the trans, from loosing the pan bolts!! Now when i do it, i will loosen the drain plug.
Well, no one else has said it yet, soooooo: WHY THE HELL DON'T THOSE MORONS PUT A DRAIN PLUG IN AT THE FACTORY?!?That extra dollar per car is gonna' break 'em worse than their management? OK, I feel better now... . | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 11:18 pm | |
| - Quote :
- WHY THE HELL DON'T THOSE MORONS PUT A DRAIN PLUG IN AT THE FACTORY?!?
Probably because they didn't expect 99.9% of Riviera owners to ever change their own trans fluid. Many never had the fluid changed, and almost everyone else had it done at the dealer, or at a local mechanic, who would put the car on a lift and asily remove the pan. It might be less messy with a drain plug, but would take slightly longer than just dropping the pan. Not a big enough deal to spend the extra $1 for the bolt + modifying all the trans pans to accept the plugs. It only made sense for the oil pan, which doesn't use an internal filter. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Thu Jun 24, 2010 11:44 pm | |
| You know, Aaron, sometimes your logic can be extremely annoying.... (But I"m still tired of getting drenched in tranny fluid ) | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Jun 25, 2010 9:39 am | |
| ...doesn't make it wrong I hope. I might use the drain plug if it were installed from the factory, or I might not bother. Pan has to come off anyway. It's one of those jobs that looks a lot messier than it actually is, and how often do you do it? Sorry to piss on your plug parade. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Ash Enthusiast
Name : Marty Age : 46 Location : S. Central Indiana Joined : 2008-05-21 Post Count : 115 Merit : 4
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Jun 25, 2010 11:40 am | |
| I can see your logic Aaron. When I dropped my transmission pan and replaced the filter and most of the system fluid (~68k miles), I thought about installing a drain plug. I could have very easily bought a kit, drilled, and welded in the bung at work. Though I chose not to for the reasons you listed. Also, I typically put less than 4,000 miles on my car a year. And with the nice pan gasket that our transmission came with, it's not like you have extra work scraping away old gasket material....and in many cases, even buying a new pan gasket.
Cheers | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Jun 25, 2010 1:10 pm | |
- Quote :
except it has nothing to do with Riviera owners per se - when was the last time you saw an auto trans from the factory with a drain plug? Now our old saturn - drain plug AND an external spin on filter. Talk about easy! But other than that... ??? | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Jun 25, 2010 1:14 pm | |
| A drain plug with an external filter would make a lot more sense. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
VJD2 Fanatic
| Subject: Re: Write Up: Transmission Fluid & Filter Change Fri Jun 25, 2010 6:15 pm | |
| So I'll be picking this up tomorrow and installing hopefully on Sunday. Can't wait to get this done. Poor transmission!
http://www.napaonline.com/Search/Detail.aspx?A=ATP15927_0271079044&An=599001+101997+50008+2008026
While the drain plug sounds good, I think I might pass on it this round.
Anyone have a favorite / preferred brand of ATF? | |
| Subject: Re: Write Up: Transmission Fluid & Filter Change | |
