| no start | |
| Subject: no start Fri Mar 16, 2007 7:55 am | |
| Yea i can't start this thing. Put the key in, turn, i get all the lights ans instruments on, fuel pump and everything sounds, turn to start and NOTHING. This is the 3rd time this happened. The first time, it just started working about in about a minute. The second time, I messed with a lot of stuff and got nothing until i lowered the steering wheel height, then it worked again. Now i tried that little trick that worked before and i didn't work. The batt/connections are fine, no blown fuses. I am thinking its the ingnition switch / lock cylinder type deal but i really dont know. any ideas please | |
| Subject: Re: no start Fri Mar 16, 2007 8:26 am | |
| It's not in gear, is it? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: no start Fri Mar 16, 2007 8:27 am | |
- It's not in gear, is it?
no i tried in P and N and the others to be sure | |
| Subject: Re: no start Fri Mar 16, 2007 8:30 am | |
| Sounds like it's in the column somewhere. From your description I'm thinking it's mechanical, would check out that lock cylinder first. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: no start Fri Mar 16, 2007 8:46 am | |
| Update I just used a wire and and connected the R and main terminals on the starter and it starts fine, runs for about 3sec and shuts off
This is making me think it has something to do with this a/m remote start thing now | |
99Rivman Aficionado
| Subject: Re: no start Fri Mar 16, 2007 10:21 am | |
| Could be a pass-key problem. I had that on my '92 once, had to replace the lock cylinder. There are ways around that to though, putting the correct resistor in the system will do the same thing. | |
| Subject: Re: no start Fri Mar 16, 2007 10:38 am | |
| well i got it workin again. I dropped the plastic bottem piece above the drivers foot well and saw the gr888888 grade A wire job the "pros" did so the mystery is solved i guess. Now i suppose i gotta go in there and improve the connections | |
akh Member
| Subject: Re: no start Sun Nov 11, 2007 1:29 pm | |
| I had the no start thing wait 3 minutes and it starts it was the pellet in the key. Replaced it and problem was fixed. | |
| Subject: Re: no start | |
| no start | |
