Name : Timo Age : 38 Location : Finland Joined : 2008-10-04Post Count : 732 Merit : 24
Subject: Re: Snowdog's Riv Sun Feb 22, 2009 7:56 pm
albertj wrote:
Regarding the "drives like when it had bad wires" - when I wash engine, I use compressed air and a blower nozzle to blow the water out of the wells where the spark plugs sit as well as off the wiring. A wet-dry vacuum with a blower cone should also work fine.
i did it tho. blowed most of the water off the engine whit compressed air.
Snowdog Addict
Subject: Re: Snowdog's Riv Sun Feb 22, 2009 9:46 pm
IFinaly figured out a way how to keep lows on when switch on hig's. this saves my hid's cos they do not need to have warmup after switchign back to lows and get more light outbut when have them bouth on.
i made some pictures and a video clip tho. so i show how i did. just need some wire, conectors and a reley. 1.connect one wire whit the Positive (+) do not mix the wires up use a red color wire for that.
2.take off the plug on the high beam bulb, take the cover off the wires. cut off whit a sharp knife some of the plastic cover on the positive wire(POSITIVE is allways a color, negative is BLACK). on right sides high beam is the positive wire yellow. connect another wire whit it, after conecting seal the connection whit tape.
3.pull of the right and left sides low beam plugs from the bulbs. cut off some of the positive wires cover on bouth sides and connect one wire whit them.( this ONE WIRE has to be connected whit RIGH and LEFT bulbs POSITIVE wire)
4.Then take another wire, good if you use black or gray. this will be the GROUND(negative (-) ) wire. connect it somewhere where you get good ground.
5. after that you should have 4 wires. Positive wire from battery (+)(RED) Negative wire from ground(-)(BLACK) One wire from Highbeams positive wire. 2 wires from Lowbeams (right/left)
If you did not do this before then connect right and lefts lowbeams wires whit eachother under one connector or what ever they are called in english. but connectors on all the wires. then you need a reley.(a siple 2 way reley whats normaly used for installign extra high beams on cars or what so ever)
6.connect the wires whit the reley. on the reley what i used low beams are in centre, ground on left, highs on right and positive is up.
7.seal the connections whit some tape again and connect the wiresagainst the cars body so they cant move/shake. after that when you turn on lights there will be lows on, when pull the lever the highs come on and lows stay.
works for me now. sorry about my BAD writing in english lol. hope you all get the point what i meaned.
Snowdog Addict
Subject: Re: Snowdog's Riv Sat Feb 28, 2009 3:05 pm
heya all today i spend some time again on car. got all the things changed now what i had buyed. right left inner and outer tierods.
was easy to change the outers. whit inners had problems, cos there is not much space for using any tools to open it. changing them made the carhandle sharo again.
then changed rear brake pads. that was very easy.
then pulley. was not a hard job tho. took just some minutes.
well anyways after that day had a pile of old parts lol.
there is still much what i want to do. there are some areas on the engine where the oil leaks out. the AC system dos not work cos its empty. need to go refill it, guess i need to get new brake rootors on front tho. feels like they are bended. and if i change them would like to get some sloted/cross trilled rootors and stainles steel covered tubes.
talked whit uno today alot tho about the car. i decided that i will let him paint the whole car. it as scratches everywhere. will not change the color just truy to find a same bearl green. think it look nice whit this color. some days ago found the sport muflers at a shop tho. i will buy them and start whit the exhaust building if i find someone who will sell me 3'' stainles steel pipes.
btw... dos rivs glowebox have a light inside it?? i see that there is a switch what should turn a light on when i open it?
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8606 Merit : 180
Subject: Re: Snowdog's Riv Sat Feb 28, 2009 3:54 pm
I'm out of ideas; must be something else.
Subject: Re: Snowdog's Riv Sat Feb 28, 2009 5:40 pm
The glove box light works only when the headlights or parking lights are on. To test it pull out the headlight know 1 or 2 stops, THEN open teh glovebox door. Light should be on. If not look to see if it is broken or missing.
Snowdog Addict
Subject: Re: Snowdog's Riv Sun Mar 01, 2009 12:26 am
i have opened the glowebox many times, even when engine and lights on...but newer have seen any light there. i truyed to to look inside it, but did not find a spot where the bulb is or could be. just have no idea. could anyone make somehow a picture of inside glowe box to see where the bulb should be. is it somewhere in centre? or on side?
Subject: Re: Snowdog's Riv Sun Mar 01, 2009 1:28 am
THe bulb is on the understructure of the dash, so that it lights up the glove compartmetn when open.
When I got my riv, mine did not work either and I had to hunt around there the socket and reinstall it in the holder under the dash. You will have to do that too I suspect.
I do not know that any RIvieras came *without* the glove box light. But maybe, if there was some sort of "light package" option. I don't know. I do know it took me some time to find the socket and re-install it. You have to empty the blovebox, and look and feel around for where it goes and where the fixture went.
I hope someone can post a picture if only to show that you don't really need a picture to fix this one.
Snowdog Addict
Subject: Re: Snowdog's Riv Sun Mar 01, 2009 1:32 am
well last time i truyed to find it. i truyed to feel whit hand where the bulb or the socket is. then truyed to go along the wire what comes from the switch of the glowebox. well its a small problem but i just dont like anything to be broken or not working hehe..well will go to unos place and check where it is.
Snowdog Addict
Subject: Re: Snowdog's Riv Sun Mar 01, 2009 1:44 pm
today cone to drive on SEA lol. cos its been like 2 months from -1 to -28C the sea as frozen. dont know how thick it is but saw a 5ton waighting tracktor driving on it. have never driven on it befor lol. but was fun. shame the ice had like 10-30cm of snow on it. foudn out thats its hard to get the riv slide side front cos its so long. could not drive very fast...truyed 90km/h but on some places there the ice had bended a bit up lol and made the car jump.
not very fun to look i guess but its a nice time to practice anythign hehe cos not much things in what to crach the car :p
Spoiler:
the water under the ince was like 4-6meters deep.
Snowdog Addict
Subject: Re: Snowdog's Riv Sat Mar 28, 2009 10:15 am
today decided to but summer wheels on. cos its been just 2 weeks of warm wethers...rod's where clean of snow and dry...but like last year!...after i buted summer wheels on my other car...even tho last time had been dry ower 2 weeks lol...it started to snow again lmao!.. and so happened today...dont know whats going on hehe... oh well will leave it so as it is...anyways more fun whit summer tyres on snow..extreem! hehe
Spoiler:
Spoiler:
Spoiler:
Spoiler:
Spoiler:
Spoiler:
Subject: Re: Snowdog's Riv Sat Mar 28, 2009 10:17 am
Those wheels look awesome! The 18" Thompsons, right?
Snowdog Addict
Subject: Re: Snowdog's Riv Sat Mar 28, 2009 10:26 am
i typed the name wrong last time.. they are Tomason TN 1 18'' whit 245/40 tyres
http://www.tomason.de/tn1_presentation.php
IBx1 Expert
Name : ILAN Age : 32 Location : College Station, TX Joined : 2007-12-30Post Count : 4304 Merit : 69
Subject: Re: Snowdog's Riv Tue Mar 31, 2009 4:18 pm
How are your exhaust tips that clean?!?! Are they new?
captshiner Junkie
Name : Andrew Age : 37 Location : Cincinnati, OH Joined : 2008-07-23Post Count : 756 Merit : -1
Subject: Re: Snowdog's Riv Tue Mar 31, 2009 4:32 pm
He also needs to tell me what kind of steering wheel cover that is.
Snowdog Addict
Subject: Re: Snowdog's Riv Tue Mar 31, 2009 11:07 pm
it's painted whit high thermo paint what i used on my calibers
about steering wheel cover. i do not relly know in what company its made or anything. but i guess it's some MADE IN CHINA again lol. buyed it from a Hong Kong shop here in finland .
EatDirtFartDust Fanatic
Name : The Josh Age : 40 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27Post Count : 284 Merit : 2
Subject: Re: Snowdog's Riv Tue Mar 31, 2009 11:19 pm
Is that wood grain factory, or stick-on pieces. You have a nice car by the way, I like that color, looks cool against the snow.
Subject: Re: Snowdog's Riv Tue Mar 31, 2009 11:25 pm
Nevermind my last post, I went through and found what you are talking about. My interior is red, just like the car that was modeling the kit you bought:
I think the kit looks alot better on your car than it does in the picture of the red interior.
Last edited by EatDirtFartDust on Wed Apr 01, 2009 12:10 am; edited 3 times in total
Snowdog Addict
thank you, its a dash kit what you can buy from some places. there are many colors and styles. the only peaces what rivs had from factory was the trimm araund radio and gear shifting lever.
in my tread i have even pictures of installing it.
and here is the place where i buyed mine: http://cgi.ebay.com/ebaymotors/BUICK-RIVIERA-96-97-98-DASH-TRIM-KIT-DASHBOARD-STYLING_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem250396172543QQitemZ250396172543QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Subject: Re: Snowdog's Riv Tue Mar 31, 2009 11:28 pm
Hmm, do you think the light burl wood:
would look too tacky or "seventies" on a red interior? I ask you because I like your taste in interiors.
Name : Codith Age : 36 Location : Villa Park, IL Joined : 2007-02-08Post Count : 3671 Merit : 140
Subject: Re: Snowdog's Riv Tue Mar 31, 2009 11:54 pm
This riv is so tight! Both the thompsons and the caddy rims look superb!
Snowdog Addict
Subject: Re: Snowdog's Riv Wed Apr 01, 2009 9:29 am
I think this one would look good on whit taupe(bege) and maybe whit medium gray. you should stay whit red colors. it will not look good when you get a trim what is brighter. the sides would show out easely araudn the gauges, vents and so on. I think the best for red interjor will be Japanese cherry wood and African Zebra wood. they bouth are a bit red so it would look more like it as come from factory whit it.
Hehe and ty Turtleman. if i ever will get some free monney...then i have some crazy plans whit the riv lol. will see what the future brings us.
IBx1 Expert
Yeah, either that or a piano black finish, which would be less expensive/somewhat easier to just paint on very carefully!
Snowdog Addict
Subject: Re: Snowdog's Riv Fri Apr 17, 2009 9:28 am
today desided to change the fuil filter. cos when i checked it...it seemed like it has been there since the car was buyed..that dam russian did not even change it ! i was sure it was very very old cos it even had rust on it!
was easy to change....just lifted up the car. unpluged the line what comes from fuiltank to the filter. leted the fuil floud out of the line to some pucket. then opened the filter from other side whit 20mm and 16mm tools. seemed this filter was so old tat instead of cleaning...(from tank came nice clean golden fuil in) it made it dirty(from other side cone black fuol out). cone out to test it later. and oh god..it feeled way diferent. run so smooth and did not vibrate on hills. guess on hills the charger made boost but not enaf fuil cone into the engine. the mixture was poor.
Spoiler:
thats the nice ''CLEAN'' fuil what came out of the filter.
Spoiler:
i don't want to know how dirty the injectors can be...
Spoiler:
my dog truyed to eat the new fuil filter on way to unos place..
then one day was boored and i started to make somekind heatsheld for the cone filter. used one aluminium tape, one aluminium plate and some erm...dont know how to call it but it was a 0,5cm thick materjal what was heatresisting. glued/taped it on the aluminium plate. later buted one ruber seal on top.
not sure how much it will keep the heat away from cone. but i hope it dos atleast something.
then truyed the 'chrom' door handle look. whit the aluminium tape. well i think they where ugly and removed it later.
Spoiler:
thats all for now. if i would ever have TO much free monney lol. then i would have big plans whit it.
