| tortuga | |
+52Rivit 98riv rivparadise ironclyde th3fr4nchi5e Birdawgxx 96_Juggernaut 69GSColorado chitown_riv98 Sir Psycho Sexy matt270avian albertj joshuadalegrimes sniperdude LARRY70GS llamalor2112 denim RidzRiv setsuna57 J. Chris Davis Hometown Hero Z-type pbrktrt Dragnet charlieRobinson Turbocharged400sbc gmann3001 95rivy 97 park ave 97buickriviera ghpcnm nothincame2mind deekster_caddy nebstewart07 bigdave Eldo Abaddon sburch23 BMD DEMonte1997 flyineagle96 Karma ibmoses Rickw robotennis61 T Riley IBx1 AA Snowdog L67 stan turtleman 56 posters |
llamalor2112 Junkie
Name : Evan Age : 31 Location : Granite Falls, WA Joined : 2012-07-13 Post Count : 852 Merit : 13
| Subject: Re: tortuga Sat Dec 15, 2012 7:41 pm | |
| That dimpled "liner" is actually just the underside of the hood. No liner on there at all. His is just pretty because of his fancy green paint rip off your ratty, toasted liner and you'll have the same dimpled hood underneath. But you lose the logo of course, and the extra noise dampening I suppose | |
denim Junkie
| Subject: Re: tortuga Sat Dec 15, 2012 7:55 pm | |
| Holy Moly, I had no idea! Thanks for that enlightenment. Still, I have the option of using the logo liner, yet. | |
llamalor2112 Junkie
denim Junkie
| Subject: Re: tortuga Sat Dec 15, 2012 8:09 pm | |
| Eeww, silver Sharpie is a leap of logic! I'll go with that when I get there. Thanks! BTW, that's one clean engine shot! | |
llamalor2112 Junkie
| Subject: Re: tortuga Sat Dec 15, 2012 8:15 pm | |
| Haha I know! It's lasted really nicely though to my surprise. And thanks, poor car lives outside in Washington so I keep it as obsessively clean as I can Sorry for the derail Codith! | |
| Subject: Re: tortuga Mon Jan 07, 2013 2:50 pm | |
| Latest on the turt
Oil pressure sending unit which was replaced with a new one about a year ago along with the latest engine build took a shit. Two good streams coming out the connector fast enough to pretty much empty the oil pan in about 15min or so of running which I nearly did. I saw my oil light come on as I was pulling into the parking lot at work. My roommate dropped off all my random bottles of oil and similar stuff which I put in so I could drive the car home to fix it. I know these pressure sending units do this but one year? cmon! The original one with tons of miles/years was fine as far as I know. I replaced it as a precaution. Am I unlucky or does the aftermarket ones suck? | |
| Subject: Re: tortuga Mon Jan 07, 2013 2:56 pm | |
| ps: don't ever use the nut-less npt unions right on the oil filter extension for adding an oil pressure gauge unless you want a whole new world of butt-hurt when you have to take it off! | |
| Subject: Re: tortuga Mon Jan 21, 2013 11:14 pm | |
| Codith, did you ever solve the issue with KR at cruise, but none at WOT? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Tue Jan 22, 2013 1:51 am | |
- Codith, did you ever solve the issue with KR at cruise, but none at WOT?
Yup! raised the KR enable rpm to 3000. So no not really. I was testing/playing with stuff left and right and getting nowhere. The next thing if I don't find a problem and/or convert the pcm/knock sensors to 98+ might be to bring the car to PRJ. That's if I don't get anywhere with it by Mayish. I really want to get kinks worked out this year and see what this turt can do! | |
| Subject: Re: tortuga Tue Jan 22, 2013 2:09 am | |
| I was reading about EGR the other day and learned it is one of the ways engines can run extreme timing (30-40° BTDC) at low RPM for cruising. Our timing tables allow 38° BTDC with TCC lock-up. These are max load conditions, and if your EGR is blocked or otherwise disabled, might be causing the issue at low RPM cruise, while not at WOT. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: tortuga Tue Jan 22, 2013 12:07 pm | |
- I was reading about EGR the other day and learned it is one of the ways engines can run extreme timing (30-40° BTDC) at low RPM for cruising. Our timing tables allow 38° BTDC with TCC lock-up. These are max load conditions, and if your EGR is blocked or otherwise disabled, might be causing the issue at low RPM cruise, while not at WOT.
I did a fair bit of scanning with EGR 'desired' and 'duty cycle' and found that it doesn't really work at all until you're at a higher speed cruise/light accel, something with some throttle & loading and TCC lock-up helps like you said however KR was pegging basically as soon as I touch the throttle most of the time. I'm talking 1-2% tps, enough to get over 1000rpm, car's not even hardly moving at that point. And of course once it's pegged it can only decay slowly unless you let off. Also one of the first things me and James tried tuning-wise was back timing off in those ranges a little, then a lot. There was zero affect - it didn't care. | |
charlieRobinson Expert
Name : Charlie Age : 38 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3923 Merit : 31
| Subject: Re: tortuga Tue Jan 22, 2013 12:45 pm | |
| Codith, do you have your EGR blocked off? And what is a Karma GenV? Did you just get it from Karma or did he port and polish it, or what?
| Subject: Re: tortuga Tue Jan 22, 2013 1:06 pm | |
| - charlieRobinson wrote:
- Codith, do you have your EGR blocked off? And what is a Karma GenV? Did you just get it from Karma or did he port and polish it, or what?
Yeah, the EGR is gone. It dirties up the intercooler so pretty much everyone always deletes it with an IC install. The blower outlet was done by Andrew (Karma). The lower half of page 7 of this thread has pictures of that. All the inlet porting/polishing I did is in the supercharger porting/polishing thread. | |
| Subject: Re: tortuga Tue Jan 22, 2013 1:24 pm | |
| Would you recommend using the EGR module on the Gen V until an intercooler is installed then block it or block it right after the Gen V swap? | |
| Subject: Re: tortuga Tue Jan 22, 2013 1:34 pm | |
- Would you recommend using the EGR module on the Gen V until an intercooler is installed then block it or block it right after the Gen V swap?
I would definitely leave it on until the IC install. It's a good thing to have when it's not hurting anything (the intercooler core). In fact, I was thinkin about keeping mine on even with the IC but James talked me out of that. | |
| Subject: Re: tortuga Tue Jan 22, 2013 2:16 pm | |
| I'm running an EGR on my GenV and it has no problems. Good for efficient cruising as far as I can tell. | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2187 Merit : 149
| Subject: Re: tortuga Tue Jan 22, 2013 2:45 pm | |
| EGR reduces peak combustion temperatures. In the early days of emissions control, deleting the EGR alone would make an engine sound like a diesel. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: tortuga Tue Jan 22, 2013 2:52 pm | |
Karma Aficionado
| Subject: Re: tortuga Tue Jan 22, 2013 3:02 pm | |
| Blocks off the superchargers silencer holes. Reduces heat and improves efficiency according to Eaton themselves. Welding risks warping the rotor bore, and filling with something like JB weld has a high chance of coming loose. (The cobalt guys had a bunch of issues with that.) That was the first version made for the GenV. The new version is similar to the latest M62 plates: And since I'm sure you are going to ask about the porting shape on the Turt blower, the outlet was opened by a bit more than was blocked with the holes. The shape was made to optimize the airstream for a GenV like this one running a tiny SC pulley. _________________ | |
| Subject: Re: tortuga Sun Jan 27, 2013 7:18 pm | |
| I don't really think the blower is notably louder with the vents blocked off and the outlet work but it actually boosts more than the ported gen3 I had. When I took the gen3 off I had a 3.2 pulley on it and it would peak around 11psi, usually saw more like 10-10.5psi. The new setup with this gen5 makes about 12.5psi all the time with the same size pulley. Also the new cam and heads flows more than the old setup so that's pretty significant. I was expecting too see about the same boost at WOT and instead found more. It's possible my old gen3 was really worn and tired but I wouldn't think that much, the coating on the rotors was decent and it was fully ported. | |
T Riley Guru
| Subject: Re: tortuga Mon Jan 28, 2013 2:34 pm | |
| 80# injectors Cody lol???? aren't those a bit big? whats your duty cycle at? | |
| Subject: Re: tortuga Mon Jan 28, 2013 2:36 pm | |
| - 98riviera98 wrote:
- 80# injectors Cody lol???? aren't those a bit big? whats your duty cycle at?
What kind of injectors are needed for E85? I thought fatties were necessary? | |
T Riley Guru
| Subject: Re: tortuga Mon Jan 28, 2013 2:51 pm | |
What kind of injectors are needed for E85? I thought fatties were necessary? Bigger ones are needed.. but IMO 65's aren't too big and aren't too small for his setup.. but maybe he has plans on a 2.6 pulley soon or something | |
| Subject: Re: tortuga Tue Jan 29, 2013 1:30 am | |
What kind of injectors are needed for E85? I thought fatties were necessary? Bigger ones are needed.. but IMO 65's aren't too big and aren't too small for his setup.. but maybe he has plans on a 2.6 pulley soon or something the nitrous, it's fueled through the injectors too | |
T Riley Guru
| Subject: Re: tortuga | |
| tortuga | |
