| Write-Up: Installing KYB GR-2 Struts | |
+39Abaddon Sir Psycho Sexy matt270avian stan 96_Juggernaut al_roethlisberger dboydakid brutusk1 charlieRobinson denim themanwithsauce werdstrave J. Chris Davis robotennis61 Rickw manofmany ewolfe0050 96RIVMANN Sweepspear turtleman joe's riv Ash deekster_caddy 1995 Riv EASHER 97rivsc TonySmooth89 Buapo albertj newcastlefatz napalmpt 330racing T Riley Mr.Riviera Jack the R CeeKay 98riv 1998 Riv AA 43 posters |
denim Junkie
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Thu Jun 21, 2012 10:15 pm | |
| While researching around the board for assorted mods, I found several write ups missing all photos. Write ups included are this one, rear tower brace install, front tower brace install... more? Has a photo hosting site gone away? | |
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Thu Jun 21, 2012 10:42 pm | |
| - denim wrote:
- While researching around the board for assorted mods, I found several write ups missing all photos.
Write ups included are this one, rear tower brace install, front tower brace install... more? Has a photo hosting site gone away? Photo host gone? would not surprise me. How to monetize a free photo hosting site escapes me unless you are in effect confiscating folks' photos, over time, for stock and resale. | |
denim Junkie
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Thu Jun 21, 2012 11:03 pm | |
| The effect is dramatic. Not even the FSM is all text. | |
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Fri Jun 22, 2012 9:17 am | |
| They were lost when AOL closed their image hosting site. Unfortunately they cannot be recovered. One day, when I have nothing else to do, I might create a few illustrations to show the process. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
denim Junkie
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Fri Jun 22, 2012 9:35 am | |
| Thanks for the response. Fact is, I have other fish to fry before doing the mods I'd like to do (first the new heart). Sad the shots are gone. Guess we need our own server! | |
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Fri Jun 22, 2012 10:24 am | |
| The images were uploaded before this board even existed. Even if we had our own server (which I could in no way could), there would be the monumental task of moving all the images over and relinking them all. Currently, we are in the process of moving to a different system for displaying write-ups and FAQ info. It solves the problem of keeping images secure, but progress has been slow and tedious.
But since you're about to tackle the job, I see no better time to snap new pics than when you swap out your struts. Just send me the images, and I can plug into the write-up. Situation fixed! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
denim Junkie
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Fri Jun 22, 2012 10:32 am | |
| Engine first. Struts are probably original at 104K, but I haven't driven this heartless car yet. When I do something relevant, be glad to post shots. | |
charlieRobinson Expert
Name : Charlie Age : 38 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3923 Merit : 31
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Sun Aug 19, 2012 9:46 pm | |
| Aaron, the images to the write up on the front page are missing. Are you able to repair them?
Edit: never mind, just read previous entries. I guess I will have to photodocument my install for this write up. | |
brutusk1 Member
Name : Brutusk Location : Bothell, Washington Joined : 2011-01-23 Post Count : 97 Merit : 13
| Subject: "Cam Bolts" Where are they used and where can I get them ? Tue Aug 21, 2012 4:50 pm | |
| I've got some KYB GR2 Struts I'm getting ready to install on my '96. I read earlier in this thread where "slotting" of some sort is required to get a proper front end alignment after this installation unless you get some "cam bolts".
Where is this slotting done and where are these cam bolts used ? Does anyone know where I can find them ?
I want to have all my ducks in a row before I pull everything apart.
Thanks | |
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Tue Aug 21, 2012 5:35 pm | |
| A Cam bolt adjusts camber.whereas the OEM bolt is non adjustable. They usually specify A cam bolt if the car has been in a fender bender which might throw things out of alignment. A cam bolt is a good idea any time. Slotting refers to the cars Caster adjustment.Also not adjustable unless you SLOT the holes in the strut tower. If you get a service manual all these procedures will be outlined. If you have never done a shock swap you will most likely need an alignment afterwards. If you outline the area where the strut bolts onto the knuckle with a grease pen,you will be able to aproximately place the new strut without too much hassle.Problem is,the KYB strut has a different mounting profile than the OEM strut.so..the marked pattern might not be accurate.
If you are the third owner you might have a cam bolt allready in there.when you remove the bolt,look at it.if it has a sleeve thing on the bolt ,its a cam bolt.do a youtube search on how to install | |
brutusk1 Member
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Tue Aug 21, 2012 5:57 pm | |
| So the cam bolts attach the strut to the knuckle ? Where would I find these ? I checked ZZP but found nothing. Thanks | |
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Tue Aug 21, 2012 6:12 pm | |
dboydakid Enthusiast
Name : noah rose Age : 34 Location : WASHINGTON DC Joined : 2011-08-21 Post Count : 130 Merit : 0
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Wed Oct 03, 2012 7:27 pm | |
| anyway i can get the pics for this install?..they are not visible anymore | |
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Thu Oct 04, 2012 1:59 pm | |
| Read above. They were lost accidentally a long time ago. Waiting for someone to take new ones. Noah, you're up to bat. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
98riv Moderator
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Tue Feb 19, 2013 4:39 pm | |
| I am planning on replacing my front struts in the near future and was wondering how to tell if I also need to replace the springs? _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Tue Feb 19, 2013 4:57 pm | |
| I am sure that most members will tell you not to replace them unless they are rusted or in otherwise questionable condition. I replaced my back springs after 140k for the sake of balance because I had to replace my fronts. I wasnt able to tell a difference in ride quality with new back springs.
If I was in a situation where i HAD to replace my springs, I would definitely look into custom made coil springs. Might as well upgrade them if you are going to replace them. | |
98riv Moderator
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Tue Feb 19, 2013 5:00 pm | |
| - charlieRobinson wrote:
- I am sure that most members will tell you not to replace them unless they are rusted or in otherwise questionable condition. I replaced my back springs after 140k for the sake of balance because I had to replace my fronts. I wasnt able to tell a difference in ride quality with new back springs.
If I was in a situation where i HAD to replace my springs, I would definitely look into custom made coil springs. Might as well upgrade them if you are going to replace them. They aren't rusted. They only have around 65,000 miles on them but the front of the car likes to groan and make noises when it goes over speed bumps, etc. when it is cold outside. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| If the front end is sitting low, that's an indicator. There are mixed opinions on when to replace springs, from "after so many years" to "never". It really depends on the type of car, too. It seems smaller import brands are more likely to fail from breaking - obviously they need replaced. But heavier cars use beefy springs that aren't likely to snap, so if they aren't sagging too low, and the left and right ride heights are the same, I wouldn't see any need to replace.
As long as the spring mounts (insulators) are intact, I think your noises are coming from elsewhere. The strut controls the up/down movement of the control arm. The spring only supports the chassis against gravity. Might be the strut bearing, control arm, bushings, and sway bar components making the noises. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
98riv Moderator
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Tue Feb 19, 2013 5:15 pm | |
- If the front end is sitting low, that's an indicator. There are mixed opinions on when to replace springs, from "after so many years" to "never". It really depends on the type of car, too. It seems smaller import brands are more likely to fail from breaking - obviously they need replaced. But heavier cars use beefy springs that aren't likely to snap, so if they aren't sagging too low, and the left and right ride heights are the same, I wouldn't see any need to replace.
As long as the spring mounts (insulators) are intact, I think your noises are coming from elsewhere. Thanks. The car has made the noise for as long as I remember. Makes moans and groans when it is cold. I'll check the insulators. When do those need to be replaced? When they get cracks? _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
98riv Moderator
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Sat Mar 02, 2013 3:40 pm | |
| Changed the struts and upper insulators today. The old struts were completely shot. They fall under there own weight. I also bought two KYB SM5276 strut mounts and the bolt holes wouldn't line up on my car. They were to narrow. I had to reuse the old mounts because I had no other choice. What did everyone else use? Amazon and rockauto said the mounts should fit my car. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
98riv Moderator
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Sat Mar 02, 2013 4:50 pm | |
| Any experience with AC Delco replacement strut mounts? Rockauto lists two different numbers 901045 and 501243. Anyone know which one I need? 901045 501243 _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Sat Mar 02, 2013 7:13 pm | |
| Since AC/Delco isn't sure what part works, I'd get KYB's SM5276, which is $10-20 less per side. I've used the KYB with both of my installs successfully. Note: use the new mounting screws supplied with the new struts, as they can vary the thread style, even with the same strut model. If the mount kit includes screws, they may or may not work with your KYB struts. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
brutusk1 Member
| Subject: Stick with the KYB mounts Sat Mar 02, 2013 7:58 pm | |
| - 98riv wrote:
- I also bought two KYB SM5276 strut mounts and the bolt holes wouldn't line up on my car. It was too narrow.
That's what you ordered but that may not be what you received. I ordered SM5286's from Rockauto for my '96 and that's indeed what the boxes indicated when they arrived. However, instead of having "studs" protruding from the mount as would be expected for that application, the mounts came with holes for use with bolts. Further, the hole spacing was not correct on the mount and wouldn't have fit in any case. Rockauto had sent the correct boxes with the wrong parts in them. I took pictures of them, called Rockauto to explain the situation, and sent an email to Rockauto where they verified that someone messed up. They sent me a link for a pre-paid shipping label then sent me the correct parts once they verified the return was in Fed-Ex's inventory system and on its way back to them. That was the second time I'd ordered those parts from them and received the wrong ones. The first time they sent the completely wrong KYB part number although the correct one was indicated on the invoice. I didn't notice the discrepancy until I could no longer return them. I like Rockauto and will continue to buy from them. But you need to verify that you've received the correct parts from them unless you like surprises like the one you got. I would get replacements from Rockauto and stick with KYB mounts since AC Delco doesn't seem to know which part you need. | |
98riv Moderator
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Sat Mar 02, 2013 9:11 pm | |
- Since AC/Delco isn't sure what part works, I'd get KYB's SM5276, which is $10-20 less per side. I've used the KYB with both of my installs successfully. Note: use the new mounting screws supplied with the new struts, as they can vary the thread style, even with the same strut model. If the mount kit includes screws, they may or may not work with your KYB struts.
I had ordered the KYB SM5276, but they didn't fit. Wrong bolt spacing. Maybe someone put the wrong ones in the SM5276 boxes. - brutusk1 wrote:
That's what I was thinking, but I couldn't find any part number on the mounts to prove my theory. It is weird that both mounts would be the wrong ones. The boxes were correct and I didn't think I needed to check the fitment before I started. Maybe someone at KYB screwed them up. As for the AC Delco's, it looks like the main difference is that one of them includes the bearings and the other includes the spring seat. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: Write-Up: Installing KYB GR-2 Struts Sat Mar 02, 2013 10:18 pm | |
| - 98riv wrote:
- Any experience with AC Delco replacement strut mounts? Rockauto lists two different numbers 901045 and 501243. Anyone know which one I need?
901045
501243
For your '98 I would get **NEITHER** of those, instead get the Monroe Strut-Mate or Mevotech sets, they come with the spring seats *and* the bearings *and* the boot cap *and* the bolts. Monroe # 902972, Mevotech same number (it is a copy of the Monroe kit). You may need all those parts depending on who/how your last install was done. This comment is based on experience with all 3. I have not worn out a Monroe mount before the associated strut quit. I went thru 2 delco mounts (dealer installed - ouch) with a set of KYB struts and finally switched over to the Monroes. The OE Delco mounts I had were made in India, had cork (not rubber) plate insulators. They seemed good. I have always wondered if there was not some installation error (again -- dealer installed) with them. | |
| Subject: Re: Write-Up: Installing KYB GR-2 Struts | |
