 Fuel Pump/Sending Unit
3 posters
Stealofcentury
Fuel Pump/Sending Unit Empty
PostSubject: Fuel Pump/Sending Unit   Fuel Pump/Sending Unit EmptyWed May 27, 2009 7:33 pm
I have looked around the site and haven't been able to find the answer I am looking for. My Riv's fuel pump is working fine, but the dash gauge is not reading correct, sometimes reads correct down to half a tank, but then fluctuates back to full. I already checked source voltage and verified ground at the pump harness. Has someone else had this problem in the past? I know I would have to pull the pump/sender, not that big of deal, I just wondering if anyone has repaired the sender to function correctly again, or is it just a better idea to buy a new pump unit for $300+ ? Thanks for any help!
PostSubject: Re: Fuel Pump/Sending Unit   Fuel Pump/Sending Unit EmptyWed May 27, 2009 8:24 pm
Welcome to the site.
Yes, others have had the same problem. The sending unit (rheostat) goes bad.
Try typing "Fuel Pump" in the Search engine on this site, there are multiple write ups concerning replacing just the sending unit and some info on getting a pump assembly for less than $300.00.
I found an OEM AC/Delco unit new on EBay a while back for $ 75.00, but that could have been just a fluke.
What year is your car. Add some info to your signature, it helps us help you better.
Stealofcentury
PostSubject: Re: Fuel Pump/Sending Unit   Fuel Pump/Sending Unit EmptyWed May 27, 2009 11:04 pm
Thanks for the info, I will search. Sorry I forgot to mention, 1997 Riv.
manofmany
PostSubject: Re: Fuel Pump/Sending Unit   Fuel Pump/Sending Unit EmptyThu May 28, 2009 3:27 pm
Thats a steal! I ended up putting a new unit in mine.
Stealofcentury
PostSubject: Re: Fuel Pump/Sending Unit   Fuel Pump/Sending Unit EmptyThu May 28, 2009 4:17 pm
After doing some research on here, I figure that is probably the best idea. I haven't seen anything off someone fixing just the sender. Will replace it all this summer.
» Fuel Pump Sending unit arm needs adjustment
» Write-Up: Fuel Pump/Sending Unit (NA Series II)
» Write-Up: Fuel Pump/Tank Sending Unit Replacement
» Write-Up: Fuel / Oil Pressure Sending & Gauges
» fuel line leak. need to disable fuel pump. Fuse or relay?
Riv Performance ::   General Tech :: Engine Bay-
