| Stripped Screws - MPS hub/pulley | |
T Riley Guru
| Subject: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 1:22 am | |
| I stripped the crap outta a few of the hex screws on my MPS hub... umm any ideas on how to swap pulleys now? FML | |
| Subject: Re: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 7:52 am | |
| http://www.zzperformance.com/grand_prix/products1.php?id=499&catid=111 _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
T Riley Guru
| Subject: Re: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 12:39 pm | |
| Well ya.. that is what im gonna do BUT... how do i get the dang screws outta there now? they are still threaded in | |
| Subject: Re: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 1:02 pm | |
| Drill and Easy Out, or bring to a mechanic who can. | |
| Subject: Re: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 1:14 pm | |
| Can you get vise grips on them? Maybe try pounding in a torx or flat head bit. Make sure you get the ZZP screws, they're the best. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 3:24 pm | |
| I assumed they were countersunk allen screws? | |
T Riley Guru
| Subject: Re: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 4:37 pm | |
| - Rickw wrote:
- I assumed they were countersunk allen screws?
they are counter sunk allen screws from the smoothflowpulleys dude | |
| Subject: Re: Stripped Screws - MPS hub/pulley Fri Jun 19, 2009 4:39 pm | |
| Then, - Rickw wrote:
- Drill and Easy Out, or bring to a mechanic who can.
T Riley Guru
| Subject: Re: Stripped Screws - MPS hub/pulley Sat Jun 20, 2009 3:43 am | |
| - Rickw wrote:
- Then,
T Riley Guru
| Subject: Re: Stripped Screws - MPS hub/pulley Sat Jun 20, 2009 3:44 am | |
| I dont' wanna fuck up the threads by drilling it out? | |
| Subject: Re: Stripped Screws - MPS hub/pulley Sat Jun 20, 2009 6:28 am | |
| You wont if you use a smaller drill bit and stay centered. The easy outs screw into the drilled hole and back the screw out. You'll need to pull the snout off to do this right. Send it to a machine shop if you're worried about messing up. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 5:26 pm | |
| Since Allen heads are basically pre-drilled, I should think that the right set of Grabit's would do the trick...
Hey, if you can't trust Billy Mays, who can you trust? Check out the specs and reviews. BTW the main type of link-function ( [url] http//.... [/url] ) wouldn't work...
LINK . | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 5:44 pm | |
| http://www.amazon.com/gp/product/B001A4CWHO/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0011EACZ2&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0FFVM46Z0YRS5K6NXEXKIt works, Eldo, but thanks for using the link code. It's much more board friendly. The [url ] code isn't the "main" way, but it's often the lazy way! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:03 pm | |
| How would i provide just a "Link" as Eldo did. I don't know how. | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:16 pm | |
| Give this a read: Links: keep them smallIt's a little lengthy, but good to know if you'll be posting a lot here. A little effort from each of us saves me from having to clean up after everyone. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:19 pm | |
| Well that's what I want to be. An educated user and hopefully make everyone's life a little easier. Thanks for the Link to the Links. | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:22 pm | |
| Thanks, Rick. Much appreciated. For anyone else who wants to be a considerate poster, take some time and read all of the sticky threads in the Board News forum. Thx!!!
Admin _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Chicken Aficionado
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:32 pm | |
| Travis,
Just leave the pulley you have on now. Start the car, open the hood, get a chisel and machine the hub the smaller diameter you want.....oh and please get pics. Thanks! | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:38 pm | |
| Oh Mark, He turned out to the real CHICKEN. He removed and replaced the whole supercharger with another one. Rather than fix or attempt to fix the bad one on the car he replaced it with a Gen 5. What a pussy. Heh. | |
Chicken Aficionado
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:44 pm | |
T Riley Guru
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:53 pm | |
| - Rickw wrote:
- Oh Mark,
He turned out to the real CHICKEN. He removed and replaced the whole supercharger with another one. Rather than fix or attempt to fix the bad one on the car he replaced it with a Gen 5. What a pussy. Heh. I guess 20whp is for pusssayz! | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 6:57 pm | |
| I was joking, can't you tell. It's pretty obvious when you swap a Gen 3 for a Gen 5. | |
T Riley Guru
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 7:04 pm | |
| - Rickw wrote:
- I was joking, can't you tell.
It's pretty obvious when you swap a Gen 3 for a Gen 5. lolz i know you were playin Rick!!! How long til you get your GEN V on? you Deek and i will be twins! or Triplets lol | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 7:08 pm | |
| I don't know, 20 HP is "nancy boy" compared to watching a chisel get snagged between SC pulley and belt... followed by the carnage that could possibly ensue. No pics, though. That's bad for business! - Quote :
- Triplets
You mean a threesome?!! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Stripped Screws - MPS hub/pulley Tue Aug 18, 2009 7:13 pm | |
| I'm not sure I want to be part of that. Especially if pic's or videos are involved.
Anyway, for me it will be a month or two, definitely before the winter. I still have wheels and tires to buy, then the N* kit, air intake set up and all gaskets, etc.
| Subject: Re: Stripped Screws - MPS hub/pulley | |
