| Could I swap my 97 Riv with a 3800 series 3 engine w/superch | |
dev919 Rookie
Name : Devin Age : 36 Location : washington dc.....clinton, md......in college down greensboro, nc Joined : 2009-05-27 Post Count : 19 Merit : 0
| Subject: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Mon Jul 27, 2009 2:24 pm | |
| I ran across a 2004 Pontiac Grand Prix engine, which is 3800 series 3 supercharges, and I wanted to know is it possible to swap these, and if so wats the pros and cons | |
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Mon Jul 27, 2009 3:36 pm | |
| L32 block is basically the same. few small changes like a different starter IIRC. The big difference is the gen V supercharger that is used vs our gen 3 blower. You can pick up a gen V for about $500 with all the necessary stuff to put it on the riv. (minus the tune) the benefit is more power due to a more efficient blower, so if you have the money and ability to tune the car then i say go for it! however it is much easier to swap just the S/C's rather than the entire motor, unless yours isnt running. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
dev919 Rookie
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Mon Jul 27, 2009 3:54 pm | |
| naw its running but my riv got about 225k on it and i figured it wouldnt last much longer, and the total swap would be cost efficient seeing that the engine has only 55k and it comes supercharged as well...
Also how much should just a Gen V SC be?
here is the website where i found the actual engines for sale
http://www.automotix.net/usedengines/2004-pontiac-grand_prix-inventory.html | |
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Mon Jul 27, 2009 4:13 pm | |
| As Mr. Riviera said above you can find a used Gen 5 supercharger and L32 intake manifold used sometimes for $500.00-$600.00 but you have to be looking otherwise I've seen some people ask a lot more and that's just SC and Manifold. If you can get a low mile L32 complete with SC for under a $1000.00 delivered, I'd say grab it and do the swap. | |
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Tue Jul 28, 2009 1:41 pm | |
| - Rickw wrote:
- If you can get a low mile L32 complete with SC for under a $1000.00 delivered, I'd say grab it and do the swap.
I agree. Even If you don't feel like doing the whole swap right away, you can keep the motor around. How's the transmission with those miles? Has it been replaced or rebuilt yet? | |
dev919 Rookie
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Tue Jul 28, 2009 1:54 pm | |
| Its still good actually...still got that punch...where could i find jus the gen V SC? | |
dev919 Rookie
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Tue Jul 28, 2009 2:18 pm | |
| also if i jus get the supercharger the only other thing i need is the coupling rite | |
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Tue Jul 28, 2009 2:33 pm | |
| You need to do a lot more reading on here Devlin. Go to the "Write Ups" section to start. There is someone on here currently doing the L32 engine with a Gen V SC swap. Follow his thread for a while and you'll get an idea what you are getting into. Also, If you can get that engine you talked about with the supercharger complete delivered to you for under a $1000.00, you will save a lot of money, time and aggravation in my opinion. | |
L8-2BNGO Enthusiast
Name : Devin Age : 37 Location : Orlando Joined : 2009-03-28 Post Count : 135 Merit : 2
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Tue Aug 04, 2009 9:14 pm | |
| hey hey hey theres only one Devin allowed on this forum and i was here first!!! lol jk | |
apu711 Special
Name : Devin Joined : 2011-01-05 Post Count : 6 Merit : 0
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch Sat Feb 05, 2011 6:40 pm | |
| hey my names devin too!! i have a 95 riv with a series one 3800 supercharged, how difficult is it to swap with a series 3 3800 supercharged?? | |
| Subject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch | |
