 weird drone
4 posters
lyonsperformance
lyonsperformance
weird drone Empty
PostSubject: weird drone   weird drone EmptyMon Aug 03, 2009 7:09 am
I was heading home yesterday, It was nice in buffalo so i let the windows down, and immediately noticed that when i was braking there was a loud low pitched hum coming from what suspect was the rear of the car. Anyone experience this, or have any Idea what it could be?
weird drone Empty
PostSubject: Re: weird drone   weird drone EmptyMon Aug 03, 2009 10:01 am
Is it just drone, or is it vibration?
Could be a front hub/bearing. See if you can make the same noise by turning the car hard around a corner left or right (without braking) at cruising speed.
lyonsperformance
lyonsperformance
weird drone Empty
PostSubject: Re: weird drone   weird drone EmptyMon Aug 03, 2009 7:31 pm
It does do that but rarely, i drove it today to work and the was no noise at all, i get within 100 feet of my front door and it happens again.
weird drone Empty
PostSubject: Re: weird drone   weird drone EmptyMon Aug 03, 2009 7:33 pm
Could be CV joint.
or you could just roll your windows up!
weird drone Empty
PostSubject: Re: weird drone   weird drone EmptyWed Aug 05, 2009 1:34 pm
Is your ABS/Trac light on? If so a garage with the appropriate computer can tell you which wheel speed sensor isn't working, which is likely the bad wheel bearing...
otherwise you need to do some careful listening with windows open in a vacant parking lot making some low speed turns and braking experiments until you figure out for sure.
weird drone Empty
weird drone
» FAQ: Mufflers?
» weird, maybe someone knows....
» here's a weird one
» Weird noise
» weird fuel
