| Bad news!!! Looks like the Crank and bearings are next | |
96Super Member
Name : Anthony Location : Huntington Beach, CA Joined : 2009-08-07 Post Count : 57 Merit : 1
| Subject: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 4:26 am | |
| Bad news!!! Looks like the Crank and bearings are next on the to-do list!! Replaced all that stuff. (Oil Pump, Super Charger, Lower Intake Gasket set, Water Pump, Power Steering Pump, and all the money in related gaskets) Only to find with the proper oil, and a new oil pump, it still has low oil pressure at an idle!! So Friday I'll start that, if I can manage to remember to take pics I can maybe do a write-up if anyone needs. Luckily I can do it myself, I can only imagine what a shop would charge. Parts will total no more than 150.00 so that's not too bad.
But I would like to get a new oil pan if they are not too expensive, any tips? If not, I'll go pull one from the bone yard.
Wish me luck!!! | |
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 6:28 am | |
| How low is low? Have you put a mechanical gauge on it yet? Did you try a heavier oil?
Are you planning to replace bearings without turning the crank? I recommend against that.
I would not rebuild one of these. Just get a boneyard bottom end and replace it. It is pretty well proven over time that the bottom end of an average 3800 is good for well over 200K miles.
On the other hand, if you have access to the appropriate machinery, and can do it yourself, then I'm surprised to see you even have to ask most of these questions!
If you can, look for an oil pan from a later model - somewhere around '03 or '04 they switched to aluminum for the oil pan instead of plastic. | |
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 7:30 am | |
| PICS & WRITE UP, PLEASE!!!! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 7:45 am | |
| - 96Super wrote:
- But I would like to get a new oil pan if they are not too expensive, any tips? If not, I'll go pull one from the bone yard. Wish me luck!!!
New aftermarket oil pan can be ordered from ZZP for $79.00 and new OEM from monsterpartsonline is around $100.00. I looked into it recently myself because I have a chronic leaking oil pan gasket. Replaced gasket twice and still drips. I highly recommend you get a new one as opposed to used unless you can find an aluminum one. They are cheap enough. I'll look up the OEM P/N for you and post it a little later. Sorry to hear about your bearing issues. | |
BillBoost37 Junkie
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 8:25 am | |
| - deekster_caddy wrote:
- they switched to aluminum for the oil pan instead of plastic.
Maybe I read this wrong... laughed a bit though. The stock pan in his year is not plastic, it's steel. You should be able to use the aluminum pan off either a Bonneville or a GP. If you have the choice, I'd suggest the Bonne as it's nice and flat versus the rounded bottom of the GP. The flatness aids in jacking the motor for belt replacement etc. Rick, I had done the gasket about 4-5 times with every available goop and checking the pan etc. In the end I found it to be a loose rear engine cover. The bolts are on with something like 5 ft lbs of toruqe and appear to come loose on nearly every motor I've seen or talked to people about. Each time they complained about a bad pan gasket that didn't stop leaking with new gasket, it seems to be the rear cover. | |
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 9:01 am | |
| - BillBoost37 wrote:
- Rick, I had done the gasket about 4-5 times with every available goop and checking the pan etc. In the end I found it to be a loose rear engine cover. The bolts are on with something like 5 ft lbs of toruqe and appear to come loose on nearly every motor I've seen or talked to people about. Each time they complained about a bad pan gasket that didn't stop leaking with new gasket, it seems to be the rear cover.
Thanks for the tip Bill, I'll look at everything a little closer when i get it up on the lift. The previous times were on the ground and difficult to analyze. | |
ibmoses Aficionado
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 9:38 am | |
Rick, I had done the gasket about 4-5 times with every available goop and checking the pan etc. In the end I found it to be a loose rear engine cover. The bolts are on with something like 5 ft lbs of toruqe and appear to come loose on nearly every motor I've seen or talked to people about. Each time they complained about a bad pan gasket that didn't stop leaking with new gasket, it seems to be the rear cover. Just tighten up the bolts on the rear engine cover? Thanks Bert | |
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 10:00 am | |
| is the oil pressure sending unit good?
BillBoost37 Junkie
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 10:58 am | |
| The tough thing about the rear cover is ...it's not visible, and the seeping only appears to happen right near the oil pan, so even my first look....I swore it was the pan gasket. It's one of those things that after you figure it out, you share with all your friends.
You could tighten the bolts..if you could get to them. Only way to get to them is to pull the engine or trans.
On the bearings, I also agree that you should not try to change them w/o machining. Most likely they won't last long. | |
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 11:40 am | |
| - Quote :
- The flatness aids in jacking the motor for belt replacement etc.
Are you suggesting the pan be used as a jack/support point? I never do this; I use the block instead. It would seem the oil pan gasket would be more prone to leaking after compressing the gasket by supporting the engine's weight by the pan. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
96Super Member
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next Wed Aug 12, 2009 8:58 pm | |
| Thanks for all the replies. I plan on buying a crank/bearing set. Would be a new/machined crank with new bearings. But, compared to what I just did, I would say this will be faster and easier. | |
| Subject: Re: Bad news!!! Looks like the Crank and bearings are next | |
