| What other transmissions will fit 95sc? (did search) | |
+3T Riley robotennis61 exclusivedetail 7 posters |
exclusivedetail Special
Name : bryan Joined : 2009-11-29 Post Count : 6 Merit : 0
| Subject: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 12:16 pm | |
| Hey guys came here after much searching and couldnt even find it on here.
I am looking to see what cars transmissions I can use for a swap.
I have a 95 SC which would make it a 3800 series 1 with the 4t60-e
What other cars would be a direct bolt on replacement?
I have had conflicting reports Thanks guys | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 5:21 pm | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 6:17 pm | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 6:30 pm | |
| tear is right I have been searching all day | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 6:37 pm | |
| i mean its a standard 4t60-e tranny those are everywhere why wouldn't they work out of another car | |
T Riley Guru
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 6:45 pm | |
| drop in a series II and a 4T65E HD... | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 6:47 pm | |
| im beginning to loose faith in the membership of this board | |
T Riley Guru
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 7:22 pm | |
| - exclusivedetail wrote:
- im beginning to loose faith in the membership of this board
Ohhhh You came in and asked a question.. you got a few replies.. mine was very good opinion.. its super easy to swap in a Series II/III motor and a tranny and just swap in the donor pcm.. pretty simple... Now i'm being nice. | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 7:32 pm | |
- Hey guys came here after much searching and couldnt even find it on here.
I have had conflicting reports Thanks guys Sometimes you have to wait a while before the person with the right answer comes along. Sometimes nobody knows the right answer. For example, I got a 4T65E-HD for my '98 from a Grand Prix, and it turned out they make different external castings, and the rear trans mount was different, and I ended up cracking the case of my replacement trans. I don't know if anybody here knows about the '95s and what other cars, but a lot of used parts dealers have access to a guide called 'hollanders' or something like that, that would be the best place to check. Also try the website "www.car-part.com" - put in year/make/model and it will list all the used replacement options in your area. You should be able to figure out from that what kinds of cars the transmissions are from. Other cars that had 3800s in 1995 that I know of - Bonneville, Park Ave, Regal, LeSabre, some big oldsmobiles (drawing an olds blank)... that's all I can think of, and I have no idea if they had the same transmissions or not. Good luck! -Derek | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:02 pm | |
| derick thank you for your response | |
L67 Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:08 pm | |
| 1996 Riviera trans should work as well. | |
Karma Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:25 pm | |
| (I've removed a number of posts that should never have appeared in this topic. There was a page of crap before any useful responses to the poor guys question.
This is the series one 3800 tech section, where people should be able to ask questions in their own thread, where others can refer to it later if they have the same problem, Without having to sift through a page of unrelated banter. There are other sections on the forum for you to have your "exchanges" with each other.
Smarten up guys. ) _________________ | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:27 pm | |
| if memory serves me right nothing will work with the 95. i went through this with my cuz who is a tranny specialist and he sed there was no upgrade available for the 95. could he be wrong? i dont know ,maybe. but if anybody knows for sure i would be interested in that too | |
Karma Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:32 pm | |
| I'm not sure if bryan was looking for an upgrade? or just a direct replacement?
If hes looking for a direct replacement, as was said earlier, the 96 should work, or perhaps another 4T60e for some other car but it would be a bit hit and miss as to if the external castings were the exact same. _________________ | |
L67 Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:35 pm | |
| - robotennis61 wrote:
- if memory serves me right nothing will work with the 95.
i went through this with my cuz who is a tranny specialist and he sed there was no upgrade available for the 95. could he be wrong? i dont know ,maybe. but if anybody knows for sure i would be interested in that too He might have been referring to the 4T65E-HD (which would be an upgrade) since its not vacuum controlled like the 4T60E-HD that came in the 95-96 Rivieras. The 4T60 in the 96 is the same as the 95 except for a few parts that were beefed up. | |
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:38 pm | |
| damn my cuz don't know everything. don't tell him that though,it will ruin his Xmas. when you say "beefed up" what did they improve on? | |
Karma Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:39 pm | |
| As far as an upgrade (if thats what he's looking for)... there is a shift kit for the 4t60e that I'm going to be trying in a year or so.. but needs the whole trans to be rebuilt at the same time.. also some machining to various parts of it can be done at the same time as specified in the instructions of the kit. I ended up finding about it ages ago an some buick site...
http://www.transmissionpartsusa.com/TRANSGO_4T60E_SHIFT_KIT_1991_99_p/500-000037936.htm _________________ | |
L67 Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:41 pm | |
- damn my cuz don't know everything. don't tell him that though,it will ruin his Xmas.
when you say "beefed up" what did they improve on? I cant recall exactly, the 95 trans is the 4T60E- HD, but I read on bonnevillepro or another site while researching the transmission and found that the 96 is a little beefier than the 95. Unfortunately I dont remember the exact pieces
| damn! here i took my cuz's word for it. he is definitely going in the book now | |
Karma Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:46 pm | |
| - Quote :
- I cant recall exactly, the 95 trans is the 4T60E-HD, but I read on bonnevillepro or another site while researching the transmission and found that the 96 is a little beefier than the 95. Unfortunately I dont remember the exact pieces
Actually, I recall the same thing... and something about that even the transmission pans on some were not stamped as 4T60-hd, but still had some of the HD parts in them. (l67 - my bad, hit edit instead of quote...) _________________ | |
L67 Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Sun Nov 29, 2009 10:57 pm | |
| Here's a good thread with some info on the 4T60 vs the 4T65 with some good info on the 60... http://www.bonnevillepro.com/forums/viewtopic.php?f=28&t=4959&hilit=4t60 | |
T Riley Guru
| Subject: Re: What other transmissions will fit 95sc? (did search) Mon Nov 30, 2009 5:37 am | |
| - Karma wrote:
- (I've removed a number of posts that should never have appeared in this topic. There was a page of crap before any useful responses to the poor guys question.
Smarten up guys. ) You a mod now or what? edit... apparently you are a mod for the series I section.. hmm | |
Karma Aficionado
| Subject: Re: What other transmissions will fit 95sc? (did search) Mon Nov 30, 2009 8:24 am | |
edit... apparently you are a mod for the series I section.. hmm (I've been quietly a mod for awhile now...) _________________ | |
T Riley Guru
| Subject: Re: What other transmissions will fit 95sc? (did search) Mon Nov 30, 2009 8:47 am | |
jamie Fanatic
Name : Jamie Age : 36 Location : Truro, NS Joined : 2008-06-17 Post Count : 283 Merit : 1
| Subject: Re: What other transmissions will fit 95sc? (did search) Thu Dec 24, 2009 9:19 am | |
| According to Hollander interchange the only transmission that will work for a 95 SC riviera is the transmission out of another 95 sc riviera. | |
| Subject: Re: What other transmissions will fit 95sc? (did search) | |
