Write-Up: 95sc Changing the coupler in an Eaton m62 5 5 2
Goto page : 1, 2, 3, 4, 5  Next
Special Fo U
Merit: 0
PostSubject: Series 1 S/C coupler Repair HELP!!!!   Thu Jul 12, 2007 7:32 pm
Ok hi all. From what I understand the 1995 series 1 s/c coupler repair is done differently than the 1996 and up series 2. I have a 1995 that is rattling badly and I cant seem to find to much info on how to do it. Has anyone on the board done this on a 95 series 1 and if so How do you check the oil? Where do you refill it? And a little advice on the general procedure on changing the coupler. And how difficult is it? I'm somewhat mech inclined and have the tools Im shure so thats not an issue. Any help at all would be appreciated. Thanks Ray
Merit: 9
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Thu Jul 12, 2007 8:27 pm
http://www.cardomain.com/id/kennlee
Merit: 87
PostSubject: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Nov 04, 2008 1:21 pm
Write up: 95sc Changing the coupler in an Eaton m62
There are two methods that the coupler can be changed on the Eaton M90 supercharger. It can be changed with the SC both on or off the car. This is not true for the Eaton m62. The M62 has a bolt that goes through the alternator and tensioner pulley bracket which makes removing the snout with the body still attached to the LIM very difficult. I suppose you could try and remove the bracket, however it is attached in a large number of places and even when swapping my LIM, I left it in place. This write-up is going to assume that the supercharger is off the car. If you need to find out how to remove your supercharger, have a look at the write up for swapping the LIM in the write-ups section. Follow the directions in that writeup in the removing of the vacuum lines, electrical connectors, and throttle body bracket. Once the supercharger is free of the LIM, it can be gently lifted up off its alignment pegs, slid away from the alternator bracket, and then can be lifted straight up. With the supercharger off, this might also be a good time to do a good throttle body scrubbing too.
The first thing to do is have a look at all the nice bolts holding the snout onto the supercharger. Go ahead and find a 10mm deep socket.
Photobucket
Before removing the bolts, open the oil drain plug and pour out all that foul smelling stuff.
Photobucket
Now remove all the bolts noting where each came from. The first picture in this writeup can be used to get the bolts with special heads back where they belong. Once all the bolts are out, gently pull straight out on the nose section. If it won't move, carefully pry using a small block of wood and a large slot screwdriver at the rectangular recessed part that is in the upper middle of the above picture near the tip two bolts. Once you have carefully broken the seal you should be able to pull the rest of the nose off by hand. Enjoy the smell and try and clean up all the oil with a clean rag from both sections.
Below is the old coupler, there was about an 1/8” of play in it. By just holding the pulley and rocking it back and forth on the car, it did not feel like so much.
Photobucket
Here we see both halves after a quick clean down.
Photobucket
Remove the old coupler and give it another quick oil cleaning.
Photobucket
Press the new coupler down by hand and prep the surface for re-sealing. I don't recommend using a gasket scraper as the mating surface is VERY well machined and any scratch would wreak that surface. I used acetone to further clean both mating surfaces.
Photobucket
Now add the smallest bead of Red Gasket maker that you can along the lower mating surface. Try and keep near the outside edge. Note that the SC is up on end so that leftover oil will not run down onto the clean and prepped surface.
Photobucket
Ensure that the pins are lined up for the nose drive to slide into the coupler correctly and gently lower the nose drive down onto the bottom section. Do not wait for the gasket maker to set, but torque all bolts in order( I used clockwise) to around 11 ft/lbs( I went with “tight”).
Photobucket
Rag off the gasket maker that squeezed out. You should have a little less than is in the above picture. Let the SC sit for 24 hours in the below position before installing.
Photobucket
Don't forget to put in new GM SC oil and use a new SC gasket before re-installing the SC. Felpro gasket # is FEL MS9574.1Also the SC might enjoy a bath before putting it back onto the car.
Merit: 65
PostSubject: S/C coupler question.   Tue Mar 17, 2009 8:10 am
Alright, well, when I had the camshaft position sensor replaced, the mechanics noted that they heard some noise from the S/C like a bearing problem. I was in doubt first, but as I hear it I realize that this sound has always been there while I had the car. The S/C feels fine but there's definitely the sound of a loud bearing. I'm wondering what I should do, should I change the oil? Buy a durable ZZP or something replacement? What's everyone's best advice, and what's the worst that could happen if I leave it as it is and continue driving?
Merit: 83
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 8:37 am
It's probably the coupler, not the bearing. An $11 part. It sounds like a bad bearing, but it isn't.
Merit: 65
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 8:43 am
Ahh right, that's the real name, the coupler, haha I forgot that! To swap it you need to take the S/C off and apart right? Not something I could do.
Merit: 87
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 9:23 am
Since your nose of your SC has a post that sticks into the alternator/tensioner bracket, it means you would have to pull the SC off the engine to change the coupler. Its really not too hard actually, you could do it with a few hand tools and a SC gasket. As long as you take your time, take pics of where the vaccum connections are, its pretty straight forward. Once the SC is off, you will need a coupler and some SC fluid.
http://rivperformance.editboard.com/series-i-engine-transmission-f13/write-up-95sc-changing-the-coupler-in-an-eaton-m62-t4421.htm
99prixgt
Apprentice
Merit: 1
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 11:07 am
If you break that gasket on the mating surface make sure you use anaerboic gasket maker since the s.c is aluminum.
Merit: 65
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 4:58 pm
Well there's no way I'm doing it myself. Anyone know what kind of damage this could cause in the long term? I'm gonna save up for now until I have some money in my pocket to get it done.
Merit: 172
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 5:06 pm
Likely no damage will result. I ran mine noisily for over a year before fixing. If the coupler were to fail, it would frag inside the snout, and the blower stops working. It's a sort of a mechanical "fuse".
- John R. White, Boston Globe
Merit: 87
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 5:26 pm
yeah, it just makes a knocking for the most part. To see how far out it is, you can take the belt off and just turn the SC pulley back and forth to see the play. Mine had maybe less than 1/16 of play and that was enough to make it audible. I've heard them being out as far as 1/4" with no I'll effects, although at that point it would sound like raining cannon balls and I woulden't let it go much further.
Merit: 65
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Tue Mar 17, 2009 6:08 pm
I'm used to that rattling sound actually, it only comes up when I let off the gas so it sounds kinda neat! Gives away the secret to anyone riding in the car who doesn't know but that's not a big problem anyway.
Merit: 37
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Wed Mar 18, 2009 1:06 am
Am i correct to assign this as the cause of a very loud idle? It's not "marbley" really, just very industrial and noisey.
Merit: 172
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Wed Mar 18, 2009 8:31 am
Yes, that's likely the cause, in combination with an opened intake (esp FWI). When you fix the coupler, the rattle noise will go away, but there will still be the breathing sound from the intake.
Merit: 89
PostSubject: Re: Write-Up: 95sc Changing the coupler in an Eaton m62   Wed Mar 18, 2009 9:09 pm
Yea with a FWI, that noise is not pleasant!
Page 1 of 5Goto page : 1, 2, 3, 4, 5  Next
» Changing Zetec Camshafts
» Write-Up: Changing Supercharger Oil
» Write Up: Transmission Fluid & Filter Change
» Write-Up: Brake Master Cylinder Install & Bench Bleed
» Write-Up: Flexible Tube Fenderwell Intake
