charlieRobinson Expert
Name : Charlie Age : 38 Location : Toledo, OH Joined : 2011-05-17 Post Count : 3923 Merit : 31
| Subject: Re: Phenolic intercooler core Thu Apr 23, 2015 2:52 pm | |
| Cody, do you know if the '99 alternator is compatible with the Gen V swap?
Or does it too need to be modded to fit? | |
| Subject: Re: Phenolic intercooler core Thu Apr 23, 2015 2:55 pm | |
| Subject: Re: Phenolic intercooler core Thu May 14, 2015 10:58 pm | |
| - charlieRobinson wrote:
- Cody, do you know if the '99 alternator is compatible with the Gen V swap?
Or does it too need to be modded to fit? Answer is: the ground bolt needs to be shaved ever so slightly for clearance. If I raised the blower an inch via spacer, does this essential mean my belt length will be affected as if I added an inch to my SC pulley size? I.E., I would need the same belt/pulley configuration for a 3.8" pulley if I wanted to run a 2.8" + 1" spacer? | |
th3fr4nchi5e Addict
| Subject: Re: Phenolic intercooler core Thu May 14, 2015 11:22 pm | |
| The belt comes off both sides of the pulley so you would need 2" more if the belt came on and off the pulley perpendicular to the ground. You could prob figure it out but You could always just try a 2" longer belt and return it for a different size if it didn't work. Lol the circumference of the pulley changing size would be slightly different like pi/2" or similar depending on the belt. School ended today so Im gonna pass on figuring the exact math -_- | |
| Subject: Re: Phenolic intercooler core | |
