 Timing gear question.
3 posters
Merit : 149
Timing gear question. Empty
PostSubject: Timing gear question.   Timing gear question. EmptyFri Oct 07, 2011 7:56 am
Just a question on the timing gears in our engines. I know on alot of the older engines that I am familiar with, the OEM cam gear had nylon or plastic tips on the teeth. My question is, do any of the 3800 engines have the same thing, and if not, when did they discontinue using them. On our older engines, the tips usually break off and end up in the pan. Anyone know?
PostSubject: Re: Timing gear question.   Timing gear question. EmptyFri Oct 07, 2011 10:35 am
Last time i had the front of my motor apart it was all metal teeth. Not sure when that changed.
Timing gear question. Dsc_0110
PostSubject: Re: Timing gear question.   Timing gear question. EmptySat Oct 08, 2011 3:46 am
I can't recall if the S1 3800s had the nylon teeth but all of the Series II 3800s have been metal. I honestly haven't seen a timing chain failure in a SII 3800.
As I recall it was only the old RWD Buick V8s that had the nylon cam gear. Don't know if the turbo 6 3.8s had metal or nylon.
» Timing Chain replacement & timing
» Stock 99 Riv timing Vs. Similar Stock Timing Tunes
» FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)
» Timing Chain
» Dont know what to do now, Timing?
