| Stock 99 Riv timing Vs. Similar Stock Timing Tunes | |
charlieRobinson Expert
| Subject: Stock 99 Riv timing Vs. Similar Stock Timing Tunes Thu Aug 28, 2014 12:10 am | |
| Why ya think factory timing settings so different? That crazy timing peak at cruise is crazy. '99 Riv timing '04+ GTP timing
Last edited by charlieRobinson on Fri Sep 05, 2014 12:25 am; edited 2 times in total | |
| Subject: Re: Stock 99 Riv timing Vs. Similar Stock Timing Tunes Thu Aug 28, 2014 8:21 am | |
| Series II, Series III.
Some different internals, different induction, different S/C. Aside from it being a 3800, it's a different engine. | |
| Subject: Re: Stock 99 Riv timing Vs. Similar Stock Timing Tunes Thu Aug 28, 2014 8:50 am | |
| Two things to bear in mind, like Scott said, very different animals in terms of tuning. SeriesIII is throttle by wire, different fuel system, etc. which will make for a little different factory tuning strategy. That being said the second thing is the base timing table is not without a handful of timing modifier tables that are also gonna be different and for all I know offset that seemingly hotter timing most of the time in real life. You would kinda have to scan an L32 car driving around to see if it really does all that timing there. | |
| Subject: Re: Stock 99 Riv timing Vs. Similar Stock Timing Tunes Thu Aug 28, 2014 9:08 am | |
| what timing are you guys running in your cruise cells? or from 0,0 to 2,200RPM, .24(g/cyl)? | |
| Subject: Re: Stock 99 Riv timing Vs. Similar Stock Timing Tunes Fri Sep 05, 2014 12:24 am | |
| Ok here's one. 99 Riv VS 99 Regal GS Here's the Regal. See 1st post for Riv. 99 RiV 99 Regal GS | |
| Subject: Re: Stock 99 Riv timing Vs. Similar Stock Timing Tunes Fri Sep 05, 2014 1:24 pm | |
| Here's mine as of today vs stock | |
| Subject: Re: Stock 99 Riv timing Vs. Similar Stock Timing Tunes Fri Sep 05, 2014 4:45 pm | |
| I once read that 27.5 was the ideal idle timing. Have you ever heard this?
Interesting to see the differences between stock 97 and 99 timing tables.
| Subject: Re: Stock 99 Riv timing Vs. Similar Stock Timing Tunes | |
