 Coolant Temp Sensor heat shield
2 posters
manofmany
Coolant Temp Sensor heat shield Empty
PostSubject: Coolant Temp Sensor heat shield   Coolant Temp Sensor heat shield EmptyFri Oct 07, 2011 7:50 pm
While having my engine apart, I lost the insulating heat shield that goes around this. What does everyone recommend as a replacement? I felt it after coming home today and it was extremely hot. Don't want the heat to cook it.
PostSubject: Re: Coolant Temp Sensor heat shield   Coolant Temp Sensor heat shield EmptyFri Oct 07, 2011 8:47 pm
You can probably get a spark plug boot insulator (Moroso) from a speed shop if there are any nearby. Seems like about the right size. But remember it gets hot from the inside out as well. I've seen a lot of them that are not protected and are just fine.
manofmany
PostSubject: Re: Coolant Temp Sensor heat shield   Coolant Temp Sensor heat shield EmptySun Oct 09, 2011 8:01 am
You're right, I may just leave it alone and see. I don't have any speed shops even remotely close.
» ZZP front exhaust log and crossover heat shield
» Write-Up: Installing FWI Filter, Heat Shield, Air Scoop
» coolant level sensor removal??
» Overheating? (bad coolant temperature sensor)
» FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)
