chitown_riv98 Fanatic
Name : Ruben Age : 42 Location : Illinois Joined : 2008-03-10 Post Count : 399 Merit : 4
| Subject: Does anyone know the diameter of the stock sway bar? Fri Aug 10, 2012 1:00 am | |
| I'm in the process of replacing some parts for my suspension. I wanted to replace the sway bar bracket to a Poly version. I just wasn't sure what the diameter is. I would say 30mm but would it be possible to use a 28.5 mm version? I'm just planning what to get tommorow. | |
| Subject: Re: Does anyone know the diameter of the stock sway bar? Fri Aug 10, 2012 9:18 am | |
| _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Does anyone know the diameter of the stock sway bar? Wed Aug 15, 2012 10:42 pm | |
| Thanks Larry, it fit great. I ended up gettin the Energy suspension Swaybar brackets with the grease fittings. They fit much tighter than the original brackets and look shinier. I got to finish up on some other stuff then Im gonna install the endlinks for the sway bar. I purchased the Energy suspension links as well. Next on the list is the Strut tower brace..
| Subject: Re: Does anyone know the diameter of the stock sway bar? Wed Aug 15, 2012 10:51 pm | |
| I used the 1 1/16 inch bushings
| Subject: Re: Does anyone know the diameter of the stock sway bar? | |
