 Does anyone know the diameter of the stock sway bar?
2 posters
Does anyone know the diameter of the stock sway bar? Empty
PostSubject: Does anyone know the diameter of the stock sway bar?   Does anyone know the diameter of the stock sway bar? EmptyFri Aug 10, 2012 1:00 am
I'm in the process of replacing some parts for my suspension. I wanted to replace the sway bar bracket to a Poly version. I just wasn't sure what the diameter is. I would say 30mm but would it be possible to use a 28.5 mm version? I'm just planning what to get tommorow.
Merit : 149
PostSubject: Re: Does anyone know the diameter of the stock sway bar?   Does anyone know the diameter of the stock sway bar? EmptyFri Aug 10, 2012 9:18 am
Looking at this spec sheet for the 97, it looks like 1.04" (kinda hard to read).
https://rivperformance.editboard.com/t162-need-info-and-specs-for-your-riviera
That would make it 26 mm or so. The stock rear bar is 17 mm, I believe. The Addco bars are 32 mm, and 22 mm.
PostSubject: Re: Does anyone know the diameter of the stock sway bar?   Does anyone know the diameter of the stock sway bar? EmptyWed Aug 15, 2012 10:42 pm
Thanks Larry, it fit great. I ended up gettin the Energy suspension Swaybar brackets with the grease fittings. They fit much tighter than the original brackets and look shinier. I got to finish up on some other stuff then Im gonna install the endlinks for the sway bar. I purchased the Energy suspension links as well. Next on the list is the Strut tower brace..
PostSubject: Re: Does anyone know the diameter of the stock sway bar?   Does anyone know the diameter of the stock sway bar? EmptyWed Aug 15, 2012 10:51 pm
I used the 1 1/16 inch bushings
» Stock Sway Bar Bushings
» Sway bar end links
» FAQ: Wheel & Tire, Lug, Bolt Pattern, Offset, Center Bore Info
» Write-Up: Cadillac STS Rear Sway Bar Install
» FAQ: G-Body Suspension Basics
