 Charlie Robinson's '99 Riv
Rivit
Birdawgxx
sniperdude
ajgee2011
Johnny Malone
37 posters
Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 16 ... 24  Next
Charlie Robinson's '99 Riv - Page 9 Empty
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyThu Aug 22, 2013 7:12 pm
Try twisting the tube to make it grow (works on some flex tubes, maybe not all).
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyThu Aug 22, 2013 8:03 pm
Could very well be the wrong item or a packaging error. Send that picture to wherever you ordered it from and have them send you the right piece!
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyThu Aug 22, 2013 9:56 pm
I emailed em. Sons of bitches. Filter will be here any day now. I wanna get this thing built!
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySun Aug 25, 2013 10:50 pm
First port job.
I tried to get the edges down and even with the mounting plate but wussed out because I didnt want to thin out the welds. But i'm satisfied.
This should add at least 5HP, right?!
Can't wait to use the dremel to polish the genV. Not so sure i'm going to try porting that tho.
Charlie Robinson's '99 Riv - Page 9 20130815
Charlie Robinson's '99 Riv - Page 9 20130816
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Aug 26, 2013 1:18 pm
It'll be just fine. The ports on the stock heads are roughly same or smaller than 1 5/8 tube. If anything with powerlogs, i'd probably just do some cleaning up at the side edges since that's where the ports are widest and would be closest. You could probably start taking more material from the tube if you really needed to as they've done a full bead weld right on the outside of flange - so you can kinda do whatever you want on the inside. The batch of ssac headers I have, they didn't sit the pipe all the way flush to the flange like on your plog, instead set them back so they're maybe only half way in the flange so you have like a two-step thing happening which is great if you need the bigger porting so I cleaned it up kinda like what you did.
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyThu Aug 29, 2013 12:27 am
Thanks for the pro tips, Codith.
I took it another step and was surprised at the difference a 2nd round made.
I'll post another pic later
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySat Aug 31, 2013 5:09 am
They sent me another spectre tube. the ID on that was also 3.5" same as the first. I knew that's what was going to happen. So much for 4" intake.
PLOG and ceramic crossover are going on next.
Still gotta get a mount/bridge piece for the IAT sensor before I move forward with the intake project.
Charlie Robinson's '99 Riv - Page 9 20130817
Charlie Robinson's '99 Riv - Page 9 20130819
Merit : 180
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySat Aug 31, 2013 8:47 am
I tried the antenna mod today, no luck. I got worse reception with it like yours than with the antenna itself. Maybe I'll get one of those ones you stick across the top of the backseats?
Check out my antenna comments, they may help.
Merit : 17
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySat Aug 31, 2013 2:39 pm
Maybe it is 4" outside diameter?
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySat Aug 31, 2013 3:10 pm
I did read those. I just went back to the actual antenna. I just switched to bluetooth for the most part anyways because the station that was getting awful reception started playing crap music.
Merit : 20
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySat Aug 31, 2013 10:43 pm
Matt, i finally hooked up my metra hide-away antenna. The reception is better than stock antenna. I think i paid 25 bucks or so from sonicelectronix
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySun Sep 01, 2013 12:30 pm
you know what this means!
Charlie Robinson's '99 Riv - Page 9 20130910
and wow. you guys werent kidding about the supercharger whine being turned up! Sounds great!
My MAF numbers are a lot higher now too. That's all i can really report for now.
New intake is sweet so far. It's not completed. I still have to drop the filter under the fender well. Right now its just on top.
so far so good, tho.
$400 for a GenV LIM and N* throttle body parts, adapter plate, etc...
shipped
Good deal or pass?
Merit : 20
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Sep 02, 2013 3:41 pm
shipped
Good deal or pass?
I say snag dat shit
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Sep 02, 2013 8:23 pm
$400 is a fair deal on that stuff. You can piece it together yourself for probably a little less but it's a hassle to get the N* throttle body right. If it's all together, $400 is not bad at all.
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Sep 02, 2013 9:07 pm
Dude wants $200 for a used L32 LIM but then I find new for < $100?
Am I missing something?
http://www.amazon.com/ACDelco-12603871-Intake-Manifold-Assembly/dp/B0049Z11ZA
How much should I expect to pay for an L32 LIM?
putting this link here for my future reference:
http://www.amazon.com/gp/product/B002LWL3XI/ref=s9_simh_se_p263_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=auto-no-results-center-1&pf_rd_r=0XRVVW1D7V03MVM0XRVV&pf_rd_t=301&pf_rd_p=1263465782&pf_rd_i=12584411
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Sep 02, 2013 9:21 pm
If that's the right part # for L32 LIM, i'd order it quickly. $100 w/ core is about right, $200 without. You get to keep your core, so sell it for an even better deal.
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Sep 02, 2013 10:38 pm
Ordered.
Just need the LIM gasket, genV bolts, and N* throttle set up, and its time to evolve.
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Sep 02, 2013 10:45 pm
I've got that stuff on my watch list. Let us know how they fit, and I might be next in line. You can grab some gen V's on eBay for around $250 + $45 shipping (give or take). They're used and could probably use a good go over, but for the price you can't complain. Are you going for a full port and polish?
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyMon Sep 02, 2013 11:24 pm
That's the plan. I've got the Gen V, just collecting the rest of the parts now. Just buying them as I see good deals. No rush.
Then once I have all the parts, I want to do XP cam, LIM gaskets, and Gen V top + N* swap all at once.
Is $250 shipped a good deal for:
North star throttle body kit (North star TB, LQ4 MAF, Gen V supercharger adaptor plate)
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyTue Sep 03, 2013 4:46 pm
It's a little less than the going rate. Not bad.
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyFri Sep 06, 2013 1:22 pm
I ordered a 4" and got this?
Is this what 4" spectre flex tube looks like? box says 4" part # but ID looks 3.5"?
Did I get the wrong pipe in the right box?
Charlie Robinson's '99 Riv - Page 9 20130813
UPDATE:
I returned this and got a new one thinking I got the wrong product. The new one was exactly the same with a 3.5" diameter. I know some of you have these same part #9751 Can anyone confirm whether theres is 4" or 3.5" ID?
I am not too concerned about the 4" until I go GenV + N* but I am just curious why they advertise it as a 4" intake tube with a 3.5" ID.
Merit : 31
Is this what 4" spectre flex tube looks like? box says 4" part #9751 but ID looks 3.5"?
UPDATE:
I returned this and got a new one thinking I got the wrong product. The new one was exactly the same with a 3.5" diameter. I know some of you have these same part #9751 Can anyone confirm whether yours is 4" or 3.5" ID?
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySun Sep 08, 2013 9:45 pm
Got this lil guy this weekend. A 10" 1200W Dual 2-Ohm Subwoofer.
Charlie Robinson's '99 Riv - Page 9 20130914
Charlie Robinson's '99 Riv - Page 9 20130915
I am collecting parts for my stereo set up and found this little gem by chance. I'd like to build a back seat armrest mount for it. I have a box for it. Just gotta mod it.
Still collecting for that GenV top swap too, tho. freak
Here's one in action
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptySun Sep 08, 2013 9:57 pm
Ohhh yeas Charlie... ♪♪♪♪♪♪♪
Merit : 31
PostSubject: Re: Charlie Robinson's '99 Riv   Charlie Robinson's '99 Riv - Page 9 EmptyFri Sep 13, 2013 4:42 pm
Follow up on the spectre air intake tube:
We have always advertised this part as 4” O.D. that will fit over a 4” tube. As for using this ducting on a supercharged engine as an intake tube it is not recommended. Air duct hose is intended to be used to bring cold air to the air filter not to be used between the air filter and the throttle body.
Respectfully,
Guy Smith /Tech support-Custom intake designs
Uhhhhh... not recommended? Uh oh..
Page 9 of 24Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 16 ... 24  Next
