 Leaking Tire
Rivnut
washu45
7 posters
washu45
washu45
Leaking Tire Empty
PostSubject: Leaking Tire   Leaking Tire EmptyWed Aug 07, 2013 7:04 pm
I got the new good used tired for $50.00 and I'm worried if I need to replace my tire again -_-; and it's very annoyed and I need your guys opinions if I need to replace this tire. I was wondering how can you tell if your tire leaking air do you hear it or find the hole? Or can it be the weight of the engine putting pressure of this tire Thank you for the help.
Leaking Tire 999726_595609363794923_1544317051_n
Leaking Tire 1098116_595609337128259_381765067_n
Leaking Tire 1150378_595609253794934_1800691248_n
Leaking Tire 1011503_595609213794938_861173575_n
Leaking Tire 1005462_595609203794939_812547166_n
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyWed Aug 07, 2013 7:23 pm
Hey Rachel hi
Some basic things to do to actually see if your tire is leaking air are to: check tire pressure and compare, listen for any hissing sound, or put the wheel in a tub of water and rotate. Here's why you might want to do each...
Tire pressure: Check tire pressure on one day. Next day, check it again. Check it again the next, and then the next. See if you find the number is dropping steadily. If so, you might have an issue
Listen for noises: I had a leaking valve stem on a tire once and you could hear a very faint hissing sound from around the valve stem. If you don't hear anything, that doesn't necessarily mean the tire is fine. It just would mean the leak is faint and gradual.
Water: If you have an area you can fill with water and spin the wheel around in, you can look at the water and see if any bubbles are being emitted from the tire at any particular area (the seal between the rim and tire, the valve stem, etc.). Just like if you are in a pool and let air out, bubbles rise to the surface. The same will happen with the tire.
To me that tire looks fine... not something you shouldn't drive on. But just check and see if you think you've got a problem! Have fun razz
Rivnut
Rivnut
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyWed Aug 07, 2013 7:28 pm
The first thing you want to determine is the age of the tire.  If it's over seven years old, it's not safe; internal deterioration that you can't see.
Check the pressure with a tire gauge each morning when the tire is cool.  If the pressure is going down, take it to a tire shop and have them look for the leak.
The money spent on good tires is a cheap life insurance policy.
Take time to read this, then check the age of your tires.
http://www.edmunds.com/car-care/how-old-and-dangerous-are-your-tires.html
Ed
PS, one quick way to find a leak in a tire is to mix some dish soap in water and put it in a spray bottle.  Spray the entire tire with the solution.  An air leak will cause the soap in the water to bubble.
http://www.rivowners.org
washu45
washu45
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyWed Aug 07, 2013 8:05 pm
Thank you all for the help happy
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyWed Aug 07, 2013 8:27 pm
I bought "good" used tires for several years and now no longer buy them. A set of low cost new tires at Wal-Mart aren't much more, and you'll know the tires will be fresh, which is important. Old tires aren't safe - you don't want to worry about a surprise blow-out on the freeway. Good luck!
washu45
washu45
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyWed Aug 07, 2013 8:29 pm
Thank you for the advice AA
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyThu Aug 08, 2013 8:48 am
To check for leaks, take the tire off and spray soapy water around the tire and bead. If it's leaking from anywhere, you'll know really fast. I have a mix of (only a little!) dish soap and water in a spray bottle by my tire machine. The soap foams up wherever there is a leak. (big bubbles for a big leak)
I'm also in the 'no used tires' camp - there are so many ways to damage a tire that even if there is good tread left you are taking a big risk on them - why were they tires replaced if the tread was so good? In some rare cases, it's because two were worn and two were not, and they were sold 4 new tires, but in more cases they were chasing out a vibration or tired of leaks, etc.
washu45
washu45
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyFri Aug 09, 2013 11:19 pm
Yeah I found a little leak on my right front tire and it's very small so I'm going to walmart to get it patch or plug it in. The leaking is on the tread so it's possible to get it fix for $6.00 to $10.00
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptySat Aug 10, 2013 1:19 am
yeah thats easy patches. i keep a kit with me to plug any( use more to help others than me lol) flats, think it was maybe 11 bucks and ive patched at least 5 peoples for them and still have about as many left
washu45
washu45
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptySun Aug 11, 2013 3:17 pm
I was able to get it plug at wal-mart and they did it for free and that's awesome. They found a nail in the tire it's was a very small nail. Well the plug is working and stopped the leak from coming out of the tire, it's good again.
Leaking Tire Empty
PostSubject: Re: Leaking Tire   Leaking Tire EmptyMon Aug 12, 2013 1:10 am
Check your tire pressures.
Radial tires always appear to bulge a little at the area of road contact. You **must** use a gauge to check the air pressure in the tire if you are to know what if anything is amiss.
Leaking Tire Empty
Leaking Tire
» Radiator / Coolant Leaks
» FAQ: Automatic Leveling Control (ALC) Concerns
» Leaking supercharger snout :(
» Leaking A/C Compressor, what all should be changed whil at it?
» LIM coolant elbow!
