| Series 2 head gaskets. | |
bmcd9179 Fanatic
Name : Bryson Age : 27 Location : Utah Joined : 2013-09-21 Post Count : 288 Merit : 1
 | Subject: Series 2 head gaskets. Sun Nov 24, 2013 1:29 pm | |
| On my 96 riviera sc, I'm seeing oil around my head gasket seals, I'm thinking about replacing them asap, anyone ever replaced them, I can't find a wright up on it. | |
96_Juggernaut Fanatic
Name : Todd Balestrini Age : 40 Location : Beaufort S.C. Joined : 2013-07-08 Post Count : 293 Merit : 5
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 1:33 pm | |
| head gasket or do you mean valve cover gasket? valve cover gaskets are what usually leak. if your head gasket is leaking you have bigger problems | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 1:37 pm | |
| I'm pretty sure it's my head gaskets, I'm not blowin any smoke and my engine is pretty strong still, theirs not a lot of oil but I think their leaking | |
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 1:40 pm | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 1:45 pm | |
| Yup, I'm replacing my LIM gaskets very soon, but yes it's leaking out of my head gasket on the right next to that tube connected to that yellow thing. Right on the metal part, now I cleaned it off when I first bought the car 4 months ago, and it's slowly coming back, not to bad of a leak at all
I don't know much about my car yet so I'm still learning, thanks for posting that pic, that helps a lot I didn't know I could replace them when I replace my lower intake gaskets, thanks for the help, so what kind of problems were u talking about? | |
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 2:34 pm | |
| seeing the placement of the gasket in the pic,I can see a whole bunch of metal that can be remove from those heads! whoo doggy! | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 2:46 pm | |
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23 Post Count : 2170 Merit : 149
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 3:30 pm | |
| I highly doubt whether your head gaskets are leaking oil. When head gaskets go, they leak compression or coolant, or both, but not oil. Think about it, where would the oil come from? If you had oil above the piston rings, it would be burning in the combustion chamber, fouling your plugs, and blowing out your exhaust, and the oil would have to be above the piston rings to get past the head gaskets. I think you will just be wasting your money. It's a big job replacing head gaskets. The oil you are seeing is coming from the valve cover gaskets, or the front and rear seals on the intake. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 3:45 pm | |
| Hmm that's true I guess I'll look into it a lot more, I'm leaking a lot of violent when I sit and park and the engine is cold, after the engine is warmed up, I don't leak it's weird. I'm going to see where it's coming from bc it is not visible looking around the engine bay. Where would that oil come from tho? It's on the right beside the tube in that picture, I can't post a pic I only have access to my phone. | |
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 4:15 pm | |
| It drips down from the valve cover gaskets. Get yourself a can of engine cleaner and clean the engine. Then watch where the oil comes from. The only other place it can come from is those wide orange seals (in the picture). Those are the front and rear rail seals for the intake. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 4:21 pm | |
| Thats where it's coming from I can tell yah right now! Those orange seals! Awesome I thought those were valve cover gaskets, dang I'm stupid, I'm still learning a lot about my car | |
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 4:33 pm | |
| - bmcd9179 wrote:
- Thats where it's coming from I can tell yah right now! Those orange seals! Awesome I thought those were valve cover gaskets, dang I'm stupid, I'm still learning a lot about my car
The orange seals are part of the lower intake manifold gasket. They ALL eventually leak on these cars. | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 5:09 pm | |
| And they leak oil out of them? I'm running 4psi of boost right now could that be my reason? And all my vacuum lines are secure, I've sprayed starter fluid everywhere and nothing so, could that be my reason? | |
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 5:32 pm | |
| The lower intake gasket that goes to the head will usually leak coolant. The orange one will leak oil. The boost would not have anything to do with it. Seals just get old and eventually leak. | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Sun Nov 24, 2013 5:43 pm | |
| hm well thats my only prob, i wonder why my boost is so low.. it goes to negative 17psi then when i floor it it goes straight to 4psi
 | Subject: Re: Series 2 head gaskets. Mon Nov 25, 2013 10:04 am | |
| When you do the LIM gaskets they say to put big blobs of RTV in the corners where the intake seals (those orange strips) meet the head to LIM gaskets. I always use Permatex Ultra-black (best RTV ever) and in addition to sealing the corners I use my finger to put a thin smear across the thin edge of the block where the intake seals sit. They say you are supposed to leave the seals dry there, but I've often had them push their way out, and that thin bead of RTV there stops it from happening. | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Mon Nov 25, 2013 10:27 am | |
| Ok, I didn't know that thanks for that I'll be sure to do that | |
 | Subject: Re: Series 2 head gaskets. Mon Nov 25, 2013 11:32 am | |
| - bmcd9179 wrote:
- hm well thats my only prob, i wonder why my boost is so low.. it goes to negative 17psi then when i floor it it goes straight to 4psi
"negative 17 " is normal during idling or maybe cruising, but 4 psi is low. Also, they measure vacuum ( -17) in inches of mercury (inHg) instead of psi since you can't have negative pressure. just a tidbit of info. | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Mon Nov 25, 2013 6:48 pm | |
| Oh interesting.. Yah it's low, but I think it's my gauge, I'm buying the aerforce gauge from zzperformace, that will give me the best reading, also for knock retard to, I'll need that to start upgrading pulley sizes without tuning it, so I don't hurt my motor. First things first is those gaskets, I need to replace those ASAP I have a rough idle because of it. | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Mon Nov 25, 2013 6:49 pm | |
| * downsizing pulley sizes | |
Name : Aaron Age : 46 Location : C-bus, Ohio Joined : 2007-01-13 Post Count : 18440 Merit : 248
 | Subject: Re: Series 2 head gaskets. Tue Nov 26, 2013 5:46 am | |
| FYI, -17 is slightly high for vacuum. I regularly see -19 to -20.5 on the Aeroforce. It's probably not a big deal, but could indicate a slight vac leak. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^  | |
bmcd9179 Fanatic
 | Subject: Re: Series 2 head gaskets. Tue Nov 26, 2013 10:54 am | |
| That is true, and I don't have the aero force one yet I have a cheap glowshift one, and it's crap, the needle is off and everything, so when I get the aero force gauge that plugs directly in my obd2, I should see everything that goes on with my car, or at least most of it. | |
 | Subject: Re: Series 2 head gaskets.  | |
