 trans possible issue?
3 posters
trans possible issue? Empty
PostSubject: trans possible issue?   trans possible issue? EmptyThu Dec 19, 2013 3:12 pm
First, every morning when i forst drive my car i hear a grinding noise going from 1st to second gear and i can feel it through the gas pedal.. any ideas?
Second. I checked my trans fluid and there are little bubbles in it. Any ideas. And should my car be running when i check that fluid?
PostSubject: Re: trans possible issue?   trans possible issue? EmptyThu Dec 19, 2013 6:07 pm
Yes, fluid should be checked with car running, at operating temperature and on level ground. If you have a grinding between shifts, it may be a sign of a damaged internal part. Fluid level problems will result in slipping but not grinding. I would guess you will need a rebuild or a swap for a used one. Sorry to hear of your misfortune, Good luck!
PostSubject: Re: trans possible issue?   trans possible issue? EmptyFri Dec 20, 2013 9:16 am
I'm thinking that if you can feel it in the pedal, you should probably check the trans mounts. The back one is probably wiped out by now if it's OEM and the movement of the metal on metal could create the sensation.
Like dave said, fluid check with engine running, warm, best after driving, idling in Park on level ground. Should be clear/red, not brown.
PostSubject: Re: trans possible issue?   trans possible issue? EmptySat Dec 21, 2013 12:02 am
Alright thanks guys, best place tofind a trans would be morad?
PostSubject: Re: trans possible issue?   trans possible issue? EmptySat Dec 21, 2013 12:05 am
Oh i forgot, went by two transmision places, i explained the noise to a local shop and the guy said it was my roller, cluth assembly, whatever that is, drove to aamco to get a freetest and guess what, they said the couldnt duplicate the noise, i said yeah because its at operating.temp lol
PostSubject: Re: trans possible issue?   trans possible issue? EmptySat Dec 21, 2013 12:28 am
http://www.ebay.com/itm/98-1998-Park-Avenue-Automatic-Transmission-114K-OEM-LKQ-/190997987745?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ABuick%7CModel%3ARiviera&hash=item2c785e01a1&vxp=mtr found this on ebay, says itll fit a riviera?!?
» ZZP trans pan
» trans temps
» Trans oil
» New to me RIv with trans problems, no 3rd or 4th
» Possible trans problem
