 Rattling rear self leveling
4 posters
Denton_NOLATX
Rattling rear self leveling Empty
PostSubject: Rattling rear self leveling   Rattling rear self leveling EmptyTue Jan 14, 2014 11:53 pm
My 98 Riviera has had a rattle when the self leveling is running. I would like to know if anyone has an EASY way to make the rattling stop?
PostSubject: Re: Rattling rear self leveling   Rattling rear self leveling EmptyWed Jan 15, 2014 12:49 am
If there's a rattle, it means something is moving. Find the source and dampen it. If it's a loose part, tighten, bend, or remove the part. It could be the pump itself is making the noise, in which case the pump would need to be removed. There are inexpensive manual fill valve kits available for our cars. Good luck!
PostSubject: Re: Rattling rear self leveling   Rattling rear self leveling EmptyWed Jan 15, 2014 8:30 am
The pump is located in the rear passenger side of the car. Get on the ground and look up behind the rear tire. Check the rubber bushings that the pump is mounted on. Also check the bolts on the pump and the shield.
Denton_NOLATX
PostSubject: Re: Rattling rear self leveling   Rattling rear self leveling EmptyMon Feb 03, 2014 11:41 pm
Thank you! I'll have a look when I rotate my tires this coming weekend!!
PostSubject: Re: Rattling rear self leveling   Rattling rear self leveling EmptyTue Mar 18, 2014 6:49 pm
Hi Denton,
Take a close look at the pump and it's mounting bracket. It's behind the pass. side rear wheel. You can see the black nylon air lines from the rear shocks leading you right to it. While you are under there inspecting it, turn the key on and watch what happens when the pump self-tests.
Hope this helps. Saw your PM.
Denton_NOLATX
PostSubject: Re: Rattling rear self leveling   Rattling rear self leveling EmptyFri Feb 06, 2015 1:04 am
I know that it has been a year since this thread started. I looked at the pump but I could not get the shield off. I left it thinking it would eventually quit working then I'll worry about it then, It still runs and performs correctly but is just loud! I recently was locked out of my car when both of the door handles broke within the same day. Currently she is in the shop getting repaired with non-matching handles. I guess have another fun Plasti-dip day coming up!
» Write-Up: Rear Self-leveling Air Shocks
» 1995 Riviera Self Leveling rear suspension operation.
» Self-Leveling suspension
» rattling noise
» Tire Rattling
